My 3 front fans of my case don't work
1 (0.01/day)
System Name Danijk beast
Processor Ryzen 5 7600x
Motherboard Gigabyte B650M GAMING X AX
Cooling AG400
Memory Kingston FURY Beast DDR5 5200MHz 16GB 2x8GB CL36
Video Card(s) RX 6750XT
Storage Kioxia EXCERIA PLUS G3 1TB SSD M.2 2280 PCIe Gen4 x4
Display(s) 1920x1080 60Hz (1)
Case UNYkach Mir 100 Case ATX Gaming (3 front fans) (1 back)
Power Supply Nox Urano VX 750W 80+ Bronze 140MM PWM
My 3 front fans don't work, I don't know if its the PSU, the motherboard (the motherboard detects the 3 sys_fans but there are at 0), the connector or a BIOS config, the 3 fans came with the case and there from the same brand but the BIOS config of the fans does nothing. The fans do not spin when I turn on the system or when there are high temperatures, these fans are also ARGB and I don't know if that influences them not working.
Please let me know if there is any solution.
Case:
(UNYkach Mir 100 Case ATX Gaming) (3 front fans and 1 backwards included)​
1,131 (6.77/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Case Fractal Design Torrent
Mouse Razer Viper (Original)
Software Windows 11 Pro (23H2)
1. Try other headers, if you haven’t yet.
2. Try feeding them (or at least one of them) from the PSU directly via a molex adapter, if you have one.
3. Try setting them to 100% RPM in BIOS and then spinning them up manually with your finger. The motor might be stuck on something.
4. Try a known working fan in the same header, if you have one.
