[Realtek 8822CE] Modded Wireless Drivers with Enabled Advanced Features
51 (0.03/day)
System Name Asus TUF Gaming FA506IU Laptop
Processor AMD Ryzen 7 4800H with Radeon Graphics
Motherboard AMD K17.6 FCH, AMD K17.6 IMC
Cooling Dual Fans Design with Self-Cleaning Cooling
Memory Samsung DRR4 - 3200Mhz 16GB(8GBx2)
Video Card(s) GeForce GTX 1660 Ti (6 GB)
Storage WDC PC SN530 SDBPNPZ-256G-1002 + SHGP31-500GM-2 + ST1000LM035-1RK172
Display(s) LM156LF-2F03 144HZ Adaptive SYNC
Audio Device(s) Realtek ALC256 @ AMD K17.6
Power Supply ASUS Power Brick 180W
Mouse ROG SICA Gaming Mouse
Benchmark Scores CineBench R23 Single core:- 1290 points CineBench R23 Multi core:- 11111 points
Just to be clear for everyone use it at your own risk
Let me say it again... use it at your own risk
The drivers that I will be providing it to you today are only made for Realtek 8822CE Wi-Fi module chip that is present to almost all OEM/Vendor laptops [Mostly on AMD based laptops]. Unfortunately stock drivers locks down any advanced features available to the user and doesn't allow you to have full control to your Wi-Fi chip capabilities.
Only compatible with PCI\VEN_10EC&DEV_C822&SUBSYS_081011AD and PCI\VEN_10EC&DEV_C822&SUBSYS_42111A3B but I will try to add more on the future if the time allows.
Today I present you my so called "Unlocked" or "Unhidden" drivers by editing .inf files to be able to makes those options visible to the user. Alright here we start... I have the confidence to share my modded driver for Realtek 8822CE which enables advanced options and might provide extra networking performance as well.
Let me show you the options that the stock drivers provides...
And now my modded drivers which provides unlocked or unhidden options
The changes that is made are renaming the Wi-Fi display name (to distinguish between official drivers and modded ones) and added/edited lines on .inf file drivers to unlock Realtek Advanced features*.
Installation:-
Since modifying drivers will cause the drivers to be unsigned and hence you need to disable Driver Signature enforcement on Windows. How to do that? Follow this link... https://www.thewindowsclub.com/disable-driver-signature-enforcement-windows
  • After you disable Driver Signature enforcement.. Download the file.. extract it's content and then go to "Device Manager" and navigate to "Network Adapters".
  • By then on Device Manager you should find your Wi-Fi driver named something like "Realtek 8822CE...." double click on it and choose "Drivers" Tab and click on "Update Driver".
  • A new windows will pop out … choose "Browse my computer for drivers" and then choose "Let me pick from a list...." by then click on "Have Disk..." and click "Browse" and navigate to the extracted content that you downloaded.
  • Click on "netrtwlane.inf" and then press "Ok" after that press "Next".
  • During the process of installing the driver it will pop up a warning... choose "Install this driver software anyway".
  • Reboot your computer after all above step is done. And you are Done :)
You can enable back Driver Signature enforcement without any issues by following the same link that I provided above.
*I can't guarantee every single feature will work but I can say that it did provide increased network performance and slightly lower latency according to my testings.
Download link [MediaFire]:-
RTK Killer Wi-Fi 5 8822CE Xtreme 802.11ac
51 (0.03/day)
The download link have been changed to a folder for easier management for the future updates :)
51 (0.03/day)
I have updated the drivers with additional features unlocked/unhidden with new version that was around + I also added more support to different Wi-Fi chips. Those are the hardware ID's that is supported on the new driver.
PCI\VEN_10EC&DEV_B822&SUBSYS_29501A3B
PCI\VEN_10EC&DEV_B822&SUBSYS_29521A3B
PCI\VEN_10EC&DEV_B822&SUBSYS_080811AD
51 (0.03/day)
Bump...
New driver release have been updated including full feature releases on the same download link.... enjoy :)
51 (0.03/day)
Bump...
51 (0.03/day)
Bump...
5,538 (1.43/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
Pretty cool Boss, can you do the same or similar for bluetooth drivers ?
Reason I am asking is that I am having some issues on my machine with the (Intel) bluetooth card only able to connect 2 or 3 devices at once, and my mouse (Logi MX Master 2) routinely stutters for a few seconds if I am not constantly moving it around. I have applied all of the most recent updates/firmware etc on all devices, but nothing seems to help...
238 (0.05/day)
Processor 3700X
Motherboard X570 TUF Plus
Cooling U12
Memory 32GB 3600MHz
Video Card(s) eVGA GTX970
Storage 512GB 970 Pro
Case CM 500L vertical
Thanks for your work. Hopefully the AMD+Mediatek collaboration will produce better stock drivers.
51 (0.03/day)
Can you lead me to the drivers that you are using currently? I might take a look into it if it is even possible :)
Yea let's hope they do :D
Thank you for the nice words :) also just to add on top of the changes I made... those drivers are Mesh WiFi compatible drivers since I recently got my Mesh WiFi setup on my home I realized that stock drivers are completely horrible dealing with Mesh WiFi's [Unusable at all] so I made the required adjustments to make switching between the Mesh WiFi nodes more smoothly and without any kind of performance loss either ping or throughput along with other fixes and optimization for Mesh WiFi :)
5,538 (1.43/day)
Motherboard AZW SEI
Like this ?
Thinking perhaps it is a power-plan related issue, I've also changed the power plan settings to make everything NOT be allowed to sleep/hibernate/power down... ie the network interfaces, the pcie subsystems, the displays, the cpu & iGpu etc, but that did not fix anything :(
I've also updated the firmware on all periphs again, but notta...and today I tried using a USB BT adapter & everything worked great, even with 5 devices all in use at once !
Fortunately my mouse & KB can also use 2.4Ghz wireless transceivers, so I have resorted to that for now, but that sucks cause it uses up 2 USB ports that I would really rather have available for other things.....
I'm tempted to think that the BT card is at least partially defective or just not powerful enough to use with more than 2 peripherals at once, but in all my years of building/using computers, this is the 1st time I've come across anything like this..
So if there is anything else you can think of that might help, I'd really appreciate the effort :)
51 (0.03/day)
Like this ?
I believe that it has some kind of a driver problem or rather be a limitation to the driver itself from the Vendor/OEM/Manufacturer but not a hardware thing... I am optimistic so I will look into it as soon as I have free time to spare :) I promise
Bump...
AAF Optimus
Account Closed - Will not update Projects
1,163 (0.44/day)
Rio de Janeiro, Brazil
System Name NEW AAF OPTIMUS RIG
Processor AMD Ryzen 5 5600X (6C/12T)
Motherboard ASUS TUF Gaming B550M-Plus
Cooling DEEPCOOL Gammax L120T
Memory CRUCIAL Pro Gaming 32GB DDR4-3200 (@3733) (2x16GB)
Video Card(s) NVIDIA GeForce RTX 3060 12GB MSI Ventus 2X OC LHR
Storage ADATA Legend 700 PCIe Gen3 x4 256GB; ADATA Legend 800 PCIe Gen4 x4 2TB; GoldenFir SSD 1TB
Display(s) AOC VIPER 27" 165Hz 1ms (27G2SE)
Case DARKFLASH DK100-BK
Audio Device(s) REALTEK S1200A (ALC1200) with AAF Optimus Audio
Power Supply REDRAGON RGPS 600W 80 PLUS Bronze Full Modular
Mouse CLAHM CL-MM386 7200DPI
Keyboard MOTOSPEED CK-108 Mechanical Keyboard
Maybe I can help you with a digital signature if that's your preference.
51 (0.03/day)
I would love that! sorry for the late reply.. I wasn't available that much due to multiple reasons :) I have sent you PM about it and hopefully I wasn't too late or something :)
51 (0.03/day)
Installation:-
Thanks to @AAF Optimus the new release driver is signed! so the procedure above is not needed any more! the new way of installing it is so much simpler now :)
Installation:-
- Uninstall your current Realtek driver with checkbox selected
- Then simply open Setup.bat file
- Reboot or Restart Your PC/Laptop
- Done!
New driver release have been updated including full feature releases on the same download link + It is Signed! All thanks to @AAF Optimus
Enjoy :)
51 (0.03/day)
Bump...
New driver release have been updated including full feature releases on the same download link + It is Signed! All thanks to AAF Optimus
Now it supports all Realtek 8822CE models.. rather from Acer, Asus, Lenovo, MSI, HP and others... as long as they are 8822CE model.. it is completely fine.
Installation:-
- Done!
enjoy :)
51 (0.03/day)
Bump...
Enjoy :)
51 (0.03/day)
Bump...
Please redownload the latest Realtek driver version as I fixed some advanced features that wasn't functioning properly and decreased overhead for wifi scanning & performance which should improve ping stability and lower latency thanks to the patches and fixes from Lenovo's driver. Thank you.
It's been tested...
51 (0.03/day)
Bump...
New version has been uploaded with latest realtek driver version available.
Enjoy :)
3,189 (0.59/day)
Czech republic
Processor Ryzen 5800X
Motherboard Asus TUF-Gaming B550-Plus
Cooling Noctua NH-U14S
Memory 32GB G.Skill Trident Z Neo F4-3600C16D-32GTZNC
Video Card(s) Sapphire Radeon Rx 580 Nitro+ 8GB
Storage HP EX950 512GB + Samsung 970 PRO 1TB
Display(s) HP Z Display Z24i G2
Case Fractal Design Define R6 Black
Power Supply Seasonic PRIME Ultra 650W Gold
Mouse Roccat Kone AIMO Remastered
This looks nice.
There's something about 8822 though, it's not even listed on Realtek's website, what's up with that? Only 8821.
51 (0.03/day)
This looks nice.
I think because it is never made for public release or made it to the consumer markets. It is only sold to OEM/Vendors. I think that is why you see different custom version drivers from different OEM/Vendors from Lenovo, ASUS, HP, Dell, and others. Don't take my words for it as I am not very sure about it but that's what I think :)
Although if you checked the .inf you will see there is the official version generic for 8822Cx but it never changed through out the history of drivers updates.. only the OEM/Vendors provides updates and fixes for there own specific HW ID model on there own current laptop line up specifically.
My driver combines them all those customs changes/updates/fixes and applies and use it to all kind of 8822CE models. Let's not mention that every OEM/Vendors applies there own settings what advanced feature to be displayed to the users or not. With my drivers... I simply unlocks them all and let the user have full control of there WiFi chip capabilities.
PoolBrews
8 (0.01/day)
It appears the link for this driver is no longer valid - where can I get it?
Thanks!
51 (0.03/day)
PoolBrews
8 (0.01/day)
Got it! Thanks so much! Is there a guide for recommended settings on the advanced section? I have a Lenovo IdeaPad 5 Pro, and it seems to take a while to re-connect when waking up.
573 (0.45/day)
Connecticut, USA
System Name Personal rig & Folder
Processor R9 5900X (VRM-B2) @ 180W/160A/140A | Mfg Wk03/2022
Motherboard Gigabyte B550 Aorus Pro V2
Cooling Thermalright PA120 w/ 3x P12, MX-6
Memory 2x16GB Crucial Ballistix 8Gbit Rev.E (DR) @ 3800CL15-18-8-17-34-54-540-1T @ 1.45v, 1900MHz FCLK
Video Card(s) PowerColor Red Devil 6600XT @ C2800MHz/M2300MHz (Samsung) @ 192W TGP | MX-6, TP-3
Storage 1x SK hynix Gold P31 1TB (boot), 1x 2TB TeamGroup MP33 Pro, 1x 4TB Seagate Ironwolf HDD 5900RPM
Display(s) 1x Gigabyte M27Q, 1x Dell 2007WFP, 1x Dell E152FPg
Case Phanteks P500A (non-digital) w/ 4x 140mm Arctic P14 PWM PST CO fans
Audio Device(s) FiiO E10K-TC (USB) -> beyerdynamic DT770 Pro (80ohm)
Power Supply Super Flower Leadex III Gold 750W
Mouse Logitech G203
Keyboard Kingston HyperX Core RGB
Software W10 Pro
Benchmark Scores https://hwbot.org/user/machinelearning/ ~ https://hwbot.org/team/warp9_systems/
Solaris17
Super Dainty Moderator
25,954 (3.79/day)
Alabama
System Name Rocinante
Processor I9 14900KS
Motherboard MSI MPG Z790I Edge WiFi Gaming
Cooling be quiet! Pure Loop 240mm
Memory 64GB Gskill Trident Z5 DDR5 6000 @6400
Storage 1x 500GB 980 Pro | 1x 1TB 980 Pro | 1x 8TB Corsair MP400
Display(s) Philips Evnia 49M2C8900
Case LANCOOL 205M MESH Snow
Audio Device(s) Moondrop S8's on Schiit Hel 2e
Power Supply ASUS ROG Loki SFX-L 1000W
Keyboard Monsgeek M3 Lavender, Akko Crystal Blues
VR HMD Quest 3
