So you want PWM control of your 3-pin fan?
2,555 (0.40/day)
Illinois
Processor i7 2600k@4.6ghz
Motherboard MSI z68ma-ed55
Cooling Silentx Extreem 120mm
Memory 2x4gb XMS 7-8-7-20 1600
Video Card(s) HD6870
Storage 2x128gb Kingston Hyper-X (Raid0), 2x750gb RE3 (RAID1), 2x750gb RE3 (RAID1)
Display(s) Soyo 24", Gateway 22"
Case Fractal Design Arc Mini 6x120mm fans.
Power Supply Zalman 750w
Software Windows 7
Ok just trying to get it straight. You don't need to "boost" the PWM signal. What is your reason for the 556?
2,555 (0.40/day)
Illinois
Software Windows 7
Then either I'm misunderstanding what your doing or your misunderstanding how the circuit functions. You don't need to boost the PWM signal. Intel's PWM spec is more then enough to sink gate drive.
2,555 (0.40/day)
Illinois
Software Windows 7
It is true that the PWM signal has a limit but this circuit only uses the PWM signal to switch the mosfet's gate on and off. What's on the other side of the mosfet is invisible to the PWM signal from the board. You can connect as many fans as you want as long as the total current draw is less then 50% of the mosfet's rating -and- you keep the mosfet within it's thermal limit.
The way they are buffering the PWM signal (via. 556) is overly complex. You could do it with 2 transistors and two resistors. I only result to IC solutions when a circuit is to complex to make a discrete solution fit the task -and- a production IC dedicated to the task is available.
Velict
24 (0.01/day)
...really. I had no idea. Is this because it's not multiple PWM fans? It's only going to drive one mosfet, not multiple?
2,555 (0.40/day)
Illinois
Software Windows 7
Correct. Multiple PWM fans running off a single PWM signal can cause issues because the PWM spec calls for very little current on that pin. Spec calls for a PWM fan to provide no more then 5.25v at no more then 20ma of current (if I remember right). This is probably used for detecting the presence of the fan and limited to 5.25v in order to communicate with logic-level components on the board. The 20ma current limit is likely due to the device switching the signal being very small like a surface mount transistor or an IC. If you were to parallel, say, 5 PWM fans, the combined current could be too much for the device to switch and the device would be unable to sink (ground) the signal.
A board simply grounds PWM pin (in short pulses) to slow the fan. The resistor in my mosfet circuit pulls the mosfet gate high (to turn it on) but only as high as the zener will allow. When the motherboards PWM pin ground the gate, the mosfet turns off. So all it's really doing is buffering the PWM signal to a level capable of driving fans directly.
It's really a pain in the ass that Intel made it as complicated as they did. It uses much fewer components overall if they had just low side switched 3-pin fans. Some boards can control speed on 3-pin headers.
Velict
24 (0.01/day)
That is a very good explanation, thank you. Also, yes I wish more motherboards had 3 pin control. This whole project is to prepare for socket 2011-3 and x99 chipset.
Velict
24 (0.01/day)
I used an NTE2985 (30a TO220) because I had them on hand. Make sure you use a logic-level n-ch mosfet. The diode is a zener rated for 5.1v NTE5010A. Sorry for the quick drawing but that should get you going.
G = gate
D = drain
S = source
P = PWM
T = Tach
+ = 12v
- = GND
Hey man! Parts came in. I built it today, tested it on one fan (still waiting on headers)
So what should I be looking at running it without PWM attached at the moment, just running only power?
What I saw was running stock, fan not attached to the circuit, NOTHING, i was able to start my fan at about 3volts, ran smooth and super low rpm.
When fan is attached to circuit, pwm not attached to motherboard YET, my fan starts spinning at around 4.8 volts, and is very very smooth and slow. Is this what I should be looking for?
Edit: Of course, at 12 volts, they were madmen... and i love it!
2,555 (0.40/day)
Illinois
Software Windows 7
The fan should be running at full speed if the PWM signal isn't attached. Check for ~5v between gate and source.
Aquinus
Resident Wat-man
13,147 (2.93/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
In Intel's defense, running a low voltage and not a PWM + 12v makes it less likely that the motor will actually spin at low fan speeds. Applying short bursts of 12v versus constant low voltage will result in more consistent low speeds since the motor itself still realizing 12v, just less of it where a really low voltage like 3v or 2v might not even make the fan spin. So there are reason why a 4-pin design was made, but not if you don't want fine control of fan speeds and just rough control of it.
2,555 (0.40/day)
Illinois
Software Windows 7
The reason they use PWM is because it's a switched-mode method of controlling analog devices like motors, lamps, LEDs, etc. and that's second nature to digital electronics. It's also more efficient and cost effective then a linear voltage regulator. The switching devices (carrying the current loads) are located in the fan so really all Intel is providing is a pulse train. They left the actual control circuit in the hands of the fan manufacture. This leaves them free and clear of any issues caused by the design variations of fan manufactures. As for start-up, that's on Intel's side. The PWM signal from the board ramps from 100% to X% on start-up.
Velict
24 (0.01/day)
update: i'm at work now, I'm testing for 5v across gate and source. I'll be back in 20 minutes.
Velict
24 (0.01/day)
Alright! I tested the gate and source, but when I did, my multimeter would short out the mosfet and turn the fan off... so i did a bit of troubleshooting and I didn't connect the source to the diode and resistor... oops. Now, i'm seeing about 4.7 volts. All is well :D Also, the previous issue of the fan starting at a higher voltage has been solved. Fans properly start at ~3v
Edit: uploaded pictures....
That grey stuff is dow corning 3145
2,555 (0.40/day)
Illinois
Software Windows 7
Glad you figured it out. How is it handling the load of so many fans?
Velict
24 (0.01/day)
Still waiting for the headers to test more than 1 fan.
but I have a question about your second schematic. The 30% modulated one.... is the fan on this schematic also supposed to run at max RPM when PWM is not connected? The same issue is happening, too. I'm using the 3904s and tip3055
Edit: R1 and r4 are receiving 12 volts, but r2 is only recieving 6v. Could I just replace the 10k resistor in this schematic with a variable 100k resistor?
2,555 (0.40/day)
Illinois
Software Windows 7
None of the fans are modulated by that circuit itself. The circuit is just a switch being modulated by the motherboard's PWM pin.
As for the PWM pin...
PWM high (5v or not connected) = Fan at 100%
PWM low (grounded by motherboard) = Fan at 0%
PWM 50% = Fan at 50% (6v)
The schematic you just posted is the mosfet version. A bipolar transistor version -can- maintain a minimal fan speed by keeping the transistor in a partially conducting state so when PWM pin is low, the fan doesn't completely turn off. You could also do this with a resistor but it will get hot since that is a linear method of idling the fans.
I drew them some time ago. The transistor one was only an example of how the fan can be high-side switched so that the negative lead remains connected to the motherboard so the tach would function correctly.
The RIGHT way to do any of this (if you want complete control over everything) is to make a separate circuit that creates a PWM signal and have that circuit controlled by the motherboards PWM signal. An RC network could convert the motherboards PWM to a voltage and have that voltage control your PWM generator.
It's electronics. There's always 101 ways to skin a dalmatian. No wait...
Velict
24 (0.01/day)
understandable, I have 556 timers to make my own pwm generator. But, i'll probably wait to do that. For now, what should I be seeing on the 30% circuit with the pwm not attached to the motherboard.
My 50% circuit works amazingly. I'll be taking pictures of it tomorrow
2,555 (0.40/day)
Illinois
Software Windows 7
Looking at the schematic in post 7, you can probably eliminate R1 and Q2 and place the zener where Q2 was. When PWM calls for full speed, you should see ~11.45v on the fan due to the C-E voltage drop across Q1. When PWM calls for 0, the minimum speed is set by the 100k variable resistor.
Remember though, the post 7 circuit is linear when PWM calls for 0 fan speed and you have the 100k set to keep Q1 partially on. It needs a proper heatsink.
The mosfet one shouldn't get hot at all and may work well without a heatsink at all.
6,882 (1.02/day)
USA
Cooling Noctua NH-D15S, 2xThermalRight TY-143, 4xNoctua NF-A12x25,3xNF-A12x15, 2xAquacomputer Splitty9Active
Video Card(s) EVGA Geforce 3060 XC Black Gaming 12GB
Storage 1x Samsung 970 Pro 512GB NVMe (OS), 2x Samsung 970 Evo Plus 2TB (data 1 and 2), ASUS BW-16D1HT
Case Lian Li O11 Air Mini
Power Supply Super Flower Leadex Platinum SE 1000W 80+ Platinum White
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
I am looking at running all 6 of my H1011's off of my motherboard's PWM CPU channel and doing away with my fan controller, could your circuit handle this? The fans are 12 volt .52amp 6.24 watts 3 pin.
6,882 (1.02/day)
USA
Mouse Zowie EC3-C
2,555 (0.40/day)
Illinois
Software Windows 7
I'm going to add another circuit to this thread that may help you guys.
This circuit CREATES a PWM signal that can be used to manually control 4-pin fans. The potentiometer is labeled "throttle" because this was part of a DC motor controller I'm designing.
Frequency is controlled by C1. R7 may not be required. By replacing the potentiometer with a thermistor, the circuit can monitor temperature and control the fans accordingly. R5 and R6 would then have to be adjusted to suit your thermistor and the temperature range.
VCC is incorrectly labled 5v. The circuit runs on just about anything but was designed for 12v operation.
6,882 (1.02/day)
USA
Mouse Zowie EC3-C
Lazzer, can you give me feedback on whether this circuit looks okay and won't blow up my motherboard?
I used Velict's diagram
Thank you.
2,555 (0.40/day)
Illinois
Software Windows 7
Did you bench test it?
