Thermaltake Launches Jing Silent CPU Cooler
halfwaythere
70 (0.01/day)
Synthetic heatsink testing is relevant for people using a heated piece of metal instead of a cpu. For the others I think using an actual cpu is better. I'm pretty sure tweaktown folks are nice people and well intentioned but unfortunately I don't find their testing methods good enough.
2,318 (0.41/day)
Texas
System Name Mr. Reliable
Processor Ryzen R9 5950x
Motherboard MSI Meg X570s Ace Max
Cooling D5 Pump, Singularity Top/Res, 2x360mm EK P rads, EK Magnitude/Alphacool Blocks
Memory 32Gb (4x8Gb) Corsair Dominator Platinum 3600Mhz @ 16/19/20/36 1.35v
Video Card(s) MSI 3080ti with Alphacool Block
Storage 2 x Corsair Force MP400 1TB Nvme; 2 x T-Force Cardea Z340; 2 x Mushkin Reactor 1TB
Display(s) Acer 32" Z321QU 2560x1440; LG 34GP83A-B 34" 3440x1440
Case Lian Li PC-011 Dynamic XL; Synology DS218j w/ 2 x 2TB WD Red
Audio Device(s) SteelSeries Arctis Pro+
Power Supply EVGA SuperNova 850G3
Mouse Razer Basilisk V2
Keyboard Das Keyboard 6; Razer Orbweaver Chroma
So you would rather them use a cpu that has voltage variations/fluctuation and stress testing software that also has variations, running on an OS that also has variations, in a case that has variations in ambient temp, running fans that have RPM fluctuations to move the air with the fluctuating temps?
Seems like a lot of variables that are out of control in a "controlled" test.
Athlon2K15
HyperVtX™
7,909 (1.23/day)
O-H-I-O
Processor Intel Core i9 11900K
Motherboard MSI Z590 Carbon EK X
Cooling Custom Water
Memory Team DDR4 4000MHz
Video Card(s) ASUS TUF RTX 3080 OC
Storage WD WN850 1TB
Display(s) 43" LG NanoCell 4K 120Hz
Power Supply Asus Thor 1200w
Mouse Asus Strix Evolve
Keyboard Asus Strix Claymore
then maybe you should test each cooler for yourself and stop trolling the news section
43,587 (6.69/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
Ok, enough.
1. Do NOT call other people names/insults.
2. Cooler testing methodology from another website has nothing to do with this particular cooler or techPowerUp. If you want to discuss a website's testing practices, do it on their website.
3. Your discussion on this subject is getting worn out. You can go back and forth all you want and it will accomplish nothing. No one is going to change their mind here so I suggest you move along or take it to PM's. Arguing and childish behavior in the News section isn't going to be tolerated.
4. This is your warning, there will be no others given before further action is taken.
3,427 (0.67/day)
System Name My baby
Processor Athlon II X4 620 @ 3.5GHz, 1.45v, NB @ 2700Mhz, HT @ 2700Mhz - 24hr prime95 stable
Motherboard Asus M4A785TD-V EVO
Cooling Sonic Tower Rev 2 with 120mm Akasa attached, Akasa @ Front, Xilence Red Wing 120mm @ Rear
Memory 8 GB G.Skills 1600Mhz
Video Card(s) ATI ASUS Crossfire 5850
Storage Crucial MX100 SATA 2.5 SSD
Display(s) Lenovo ThinkVision 27" (LEN P27h-10)
Case Antec VSK 2000 Black Tower Case
Audio Device(s) Onkyo TX-SR309 Receiver, 2x Kef Cresta 1, 1x Kef Center 20c
Power Supply OCZ StealthXstream II 600w, 4x12v/18A, 80% efficiency.
Software Windows 10 Professional 64-bit
Where is the fans blowing in opposite directions? One fan blows air through the HS< the other pulls it out. The air is alll flowing one direction.
^ what fans are blowing in opposing directions? There are 2 fans on the cooler, one is pushing air through it and the other is pulling air through it (hence push pull). Air is not going to get trapped in the middle.
I would say watch the video if you don't understand how that works.
The video helped answer my question, I didnt realise that the coolers fan on the left hand side blades were inverted so it blows hot air out.
p_o_s_pc
F@H&WCG addict
13,006 (2.09/day)
Newark ohio
System Name el'lappy|Cruncher | Cruncher 2
Processor intel C2D T6400 | i7 3770k @4.2ghz | AII X2 220 @3.4ghz
Motherboard some Acer | Asus P8Z77-V Pro |Gigabyter GA-M61p-S3
Cooling dual 80mm cooling fan | WC'ing ) |cheapo
Memory 2x2gb ddr3 | 2x2gb Ripjaws 1600 |4x512mb D9s
Video Card(s) onboard | 60 1GB(hd7770 ) |8800GTS
Storage Momuntus xt 320gb |Kingston Hyper X 120gb SATA III|500gb WD
Display(s) 17in | 42" 1080P HD 3D TV
Case lappy case | CM HAF XB |none yet
Audio Device(s) onboard | onboard | onboard
Power Supply Dell brick w/ acer end end | Antec EW 650w |Antec SP 350w(upg.soon)
Software Windows 7 Ult. 64bit---->------->
maybe this will help you guys some.
here is a test done by ME A USER AND OWNER of the Jing. read the note in the SS for more details.
BTW the room temp is 83f
PS i'm not trying to argue with anyone just providing some results that i have got with the cooler to help people that think the reviews are BS or whatever other reasons.
Also the rig has been crunching for about an hour before i took this SS so it has had time to heat up.
here it is in the rig i tested it in and the green has been removed.
http://i166.photobucket.com/albums/u88/p_o_s_pc/S5031183.jpg
9,899 (1.76/day)
Essex, England
System Name My pc
Processor Ryzen 5 3600
Motherboard Asus Rog b450-f
Cooling Cooler master 120mm aio
Memory 16gb ddr4 3200mhz
Video Card(s) MSI Ventus 3x 3070
Storage 2tb intel nvme and 2tb generic ssd
Display(s) Generic dell 1080p overclocked to 75hz
Case Phanteks enthoo
Power Supply 650w of borderline fire hazard
Mouse Some wierd Chinese vertical mouse
Keyboard Generic mechanical keyboard
Software Windows ten
Do regular fans just clip in too?
Neat.
