Too low power for Covid-19?
561 (0.27/day)
Canada
System Name HP Pavilion a6552f
Processor Intel Core 2 Quad Q9400
Motherboard Asus IPIBL-LB / HP Benicia-GL8E
Cooling DeepCool Gammaxx 200
Memory 8gigs Kingston 4x2gigs DDR2-800
Video Card(s) Zotac GT630 "Fermi" 2gb DDR3 128bits Synergy Edition
Storage Western Digital Green 7200rpm 1tb
Display(s) LG Flatron EW234 Super LED
Case HP Pavilion
Power Supply Thermaltake TR2 430w
Mouse Razer Abyssus Mirror Special Edition Blue LED
Keyboard Thermaltake Tt eSPORTS Commander Red LED Backlighting Mechanical Keycaps Membrane Gaming Keyboard
Software Windows 7 Home Premium 64bits
I would like to use a computer for Covid-19 24/7 but i'm not sure about this low setup could be really useful.
HP stock 1155 mobo
Dualcore G620
GT630 ddr3 2gigs
500 gigs wd blue
with an antec Green 380watts bronze plus
What do you think of it?
993 (0.19/day)
Processor Intel Core i5 8400
Cooling Silverstone AR05
Display(s) Dell U2415
Case Silverstone RVZ02B
Keyboard Ducky One Red Switch
Software Windows 10 Pro 1909
Every bit helps imo
781 (0.35/day)
Would be great to get a GT 1030 in there or something, but I can't really suggest that when HPs commonly reject better graphics cards.
561 (0.27/day)
Canada
Case HP Pavilion
Its covid and not all have money to buy better stuff. Feeding my family first.
12,317 (1.89/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
I agree with Flanker. Every little bit helps.
Raevenlord
3,755 (1.32/day)
Portugal
System Name The Ryzening
Processor AMD Ryzen 9 5900X
HP stock 1155 mobo
Dualcore G620
GT630 ddr3 2gigs
500 gigs wd blue
Every little bit helps. Take care of yours first, don't go on spending money you don't have, and connect your PC to Folding@Home. No matter how small, enough drops eventually fill a cup.
Thank you for considering donating your processing power to the world!
8,072 (1.39/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
I was surprised to find that yes, the GT630 is on F@H's whitelist. What I would suggest is only run F@H on the GPU and don't run anything on the 65 watt TDP 2c/2t CPU.
newtekie1
Semi-Retired Folder
28,472 (4.21/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
It might be on the whitelist, but I don't know that it will be fast enough to actually finish a WU in time before it expires. I guess the OP can just try it and see.
937 (0.29/day)
System Name The Banshee
Cooling CM Hyper 212 Plus
Memory 16GB 2x8 G.Skill Trident Z 3600 CL16 1.35V
Video Card(s) RTX 3060M 6GB @ 1750-2100MHz Core / 1875MHz Mem
Storage 1TB Kingston NV2 & 1TB Mass Storage HDD
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 10 Pro 64-Bit
The Kepler GT 630 should be able to finish WU's before time out but the Fermi based one will have no chance.
561 (0.27/day)
Canada
Case HP Pavilion
Until now I found out by myself that if you fart in a cookie jar you close the lid then after 3 days you take a sniff the covid dies.
