Upgrade from 9700K to 7600X + B650 mobo for current RTX 3080. Advice needed, which parts to pick?
JrRacinFan
Served 5k and counting ...
20,073 (3.20/day)
Youngstown, OH
System Name Dual Build Streamer
Processor Ryzen 7900x3d : Ryzen 4600G
Motherboard AsRock B650E Steel Legend : Giga B450i Aorus
Cooling Custom Water 1x420 : Stock
Memory 32GB T-Force Deltas : 16GB Dominator Platinums
Video Card(s) PowerColor 7900 XTX Liquid Devil: iGPU
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Custom White Painted Phanteks Enthoo Pro 2
Audio Device(s) Onboard : Onboard
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Hyperx Origins 65
I don't know which Mobo to get now to avoid problems like this
My Asrock b650e Steel Legend has been rock solid since day 1. Highly suggest that or something from MSI.
Depending on the games, some dip into the 30s and 40s
Not too shabby. Recently picked up a 49" ultrawide 5120x1440p and replaced the 2 27's. Went ok with the 3070 ti but i have a 7900 xtx on the way.
Sorry @droid99 for derailing the thread a little.
51 (0.09/day)
System Name Evolv Beast
Processor 7600X
Motherboard Asus Strix B650E-E
Cooling Deepcool AS500 PLUS
Memory Corsair Vengeance RGB 2x16GB DDR5-6000 CL36-36-36-76 CMH32GX5M2D6000Z36K
Video Card(s) MSI RTX 3080 Suprim X 10GB
Storage Samsung 990 PRO 1TB
Display(s) Acer Predator XB3 XB253QGWbmiiprzx, 24.5" 1080p 280Hz (UM.KX3EE.W01)
Case Phanteks Evolv X + 6x Phanteks M25 140m PWW D-RGB fans
Power Supply Fractal ION+ 860W Platinum
Mouse Razer DeathAdder V3 Pro
Keyboard Razer Huntsman V2 Red optical switches
Don't worry, it's all ok
T
I got used to to Asus feature called Q-Release. Ez GPU swap. I'm surprised that other brands didn't apply that. So sad.
5,550 (2.67/day)
California
System Name His & Hers
Processor R7 5800X/ R9 5950X Stock
Motherboard X570 Aorus Master/ROG Crosshair VIII Hero
Memory 32 GB 4x8GB 4000CL15 Trident Z Royal/ 32 GB 3200 CL14 @3800 CL16 Team T Force Nighthawk
Storage lots of SSD.
Display(s) LG G2 65/LG C1 48/ LG 27GP850/ MSI 27 inch VA panel 1440p165hz
Keyboard Corsair K95 RGB Platinum/ Logitech G Pro
I think some gigabyte boards have a similar feature.
It does seem really nice though.
40,435 (6.56/day)
The B550 version with a 5800 OEM with Crucial Ballistix Gaming Red 3600 32GB kit with W11 has been running with no issue since 2021, I never updated the mobo bios either, just booted right up, set XMP/AMP/DOCP and that was it.
51 (0.09/day)
Processor 7600X
hello
i'm coming back with my issue, i need better mobo than Asus, Intel NiC 225 is so bad, its plague already on market. Now i would like to switch motherboards
There is 2 options with Realtek NiC
1) MSI B650 Tomahawk WiFi for 210 euro but i heard lately bios from MSI not good and bad quality, (maybe im wrong and last bioses from them are perfect)
2) Asrock B650E Steel Legend WiFi for 280 euro,
MSI seems has good an price/perfomance offer
Which one to get?
Thank you for help!
32 (2.46/day)
System Name MAVERICK
Processor Ryzen 7 5700X
Motherboard MSI Tomahawk X570 Wifi
Cooling Corsair ICue H100i Elite Capellix RGB Platinum 240mm
Memory Corsair Vengeance RGB Pro SL 4x16GB ( 64GB ) CMH32GX4M2Z3600C18
Video Card(s) MSI RTX 3060 Gaming X 12GB DDR6
Storage Samsung 980 Pro 1TB NVme M.2 | HDD : Seagate 1TB & WD 2TB
Case LIAN LI LANCOOL 205
Power Supply Seasonic Focus GX-550
Keyboard Vortex Series GT 9
Software Windows 11 Professional 64 bit
hello
Which one to get?
Thank you for help!
I prefer MSI board.
i had bad experience with Asus too, but mine is Asus ROG B450f Strix. i build with AM4 Ryzen 5 3400G in early 2022. 3 days after its broken. the issue is the PC is on and its going black screen, cannot do anything, have to restart manually ( by power off and on again ). Bring back to Asus store and after they are checking the board, the board is dead. After this im avoid to using Asus product anymore.
Now im use MSI X570 Tomahawk Wifi, its solid board until nowadays im pairing with Ryzen 7 5700X. its running flawless.
1,894 (0.32/day)
Processor RyZen R9 3950X
Video Card(s) RTX 3050
Storage Samsung 2TB SSD
Case Zulman MS800
Audio Device(s) On Board
Power Supply Seasonic 650W
Software Windows 11 64bit
hello
Which one to get?
Thank you for help!
It’s worth pointing out that a USB 2.5GbE NIC is easy enough to source and is typically cheap. I have a QNAP QNA-UC5G1T USB 5GbE NIC connected to an old QNAP NAS and it works fine. The 2.5GbE NICs are probably like ~$20 USD or maybe ~$25 USD.
BTW, my ASRock B650E PG Riptide WiFi motherboard has been fairly rock solid. The release BIOS / UEFI had some issues but after the second or third update its been perfect. FWIW, the ASRock B650E PG Riptide WiFi motherboard has a Killer E3100 2.5 GbE NIC And it’s never given me a moments worth of trouble. I will say that most of the ASRock boards in this price range seem very similar though:
When the 7800XT video cards were released I upgraded my old video card for one. The motherboard’s included video card support bracket really came in handy there. The ASRock Phantom Gaming 7800XT is a heavy card that will definitely sag without some kind of additional support.
