Ver. 3.0.2.5 Firmware Update to NEC(Renesas) USB 3.0 controller-unloading fix
2,334 (0.44/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
716 (0.13/day)
C:\Kitteh
Processor i7 2600K | Phenom II 840
Motherboard ASUS P8Z68 Deluxe | ASUS M4A88T-M
Cooling Corsair H60 | Scythe Samurai ZZ
Memory 4x4GB Samsung Green 1600 @ 1866 | 2x2GB Corsair XMS3 1333
Video Card(s) Evga GTX 670 FTW | On Board AMD
Storage 2 x 64GB Samsung 830, Velociraptor 300GB,1TB Black,1.5TB Black |10TB server
Display(s) HP 2509m 25" 1080p
Case Lian Li PC-V1020A | Lian Li PC-V354A
Audio Device(s) Azuntech Bravuria 7.1 | On-Board (Disabled)
Power Supply Seasonic X-series 760 , Seasonic X-series 760
Software Windows 7 Ultimate X64 | UnRaid (CentOS)
I know some people (Mussels) were having issues with gigabyte boards and charging phones:
*NOTE: Due to certain mobile phone limitations, users may need to connect the mobile phone to their PC before the PC enters S4/S5 mode to enable a quick charge from non ON/OFF Charge USB ports.
Maximum 3 devices can be charged at the same time. Charging current may vary with PSU 5V stand-by spec.
http://www.gigabyte.us/MicroSite/185/on-off-charge.htm - Overview
http://www.gigabyte.us/support-downloads/Utility.aspx?cg=2 - Driver direct download (on/off charge)
95Viper
Super Moderator
12,996 (2.21/day)
See page 6 of PDF...note example firmware 4015???
That 4015 firmware has been seen in boards like, Z68X-UD7-B3, with the dual usb 3.0 chips.
But, have not seen it for download.
Something to Sherlock!:)
1,958 (0.26/day)
The Kingdom of Norway
Processor Ryzen 5900X
Motherboard Gigabyte B550I AORUS PRO AX 1.1
Cooling Noctua NB-U12A
Memory 2x 32GB Fury DDR4 3200mhz
Video Card(s) PowerColor Radeon 7800 XT Hellhound
Storage Kingston FURY Renegade 2TB PCIe 4.0
Display(s) 2x Dell U2412M
Case Phanteks P400A
Audio Device(s) Hifimediy Sabre 9018 USB DAC
Power Supply Corsair AX850 (from 2012)
Software Windows 10?
after updating these it seems my USB ports no longer charge my devices through USB... i'ma have to look into why that is.
you have to set "USB selective suspend setting" to Disabled
btw you might also disable power saving in device manager on the nec controller
not sure that realy is needed but still, nec is annoying :p
1,958 (0.26/day)
Case Phanteks P400A
mark09
7 (0.00/day)
Done!
See the instructions here: http://forum.oszone.net/post-1722285.html#post1722285
The forum is in russian (use google translate). Download the file linked in that post (I used JDownloader). Than translate the how to with google translate as well. If you find garbage text when you open it, you have to switch to the right encoding (I used Notepad++ and selected OEM 866 in the Encoding - Charset - Cyrillic menu).
Bye!
228 (0.04/day)
System Name Adult Entertainment
Processor i7 2600K 4.4Ghz
Cooling CM Hyper 212 Evo with two Noctua 12cm fans
Memory 8GB (2x4GB) Corsair Vengeance LP 1600
Video Card(s) EVGA Geforce GTX 690
Storage two 3TB hard drives
Display(s) 27" Asus
Case Bitfenix Prodigy
Audio Device(s) Motherboard Soundcard FTW!
Power Supply Seasonic X850
Software Windows 10 64bit | Linux Mint | Windows XP 32bit
Benchmark Scores Score: OMFGWTFBBQSPEED!
Download using an obscure download manager from an obscure Russian website? How about supplying or linked the file here instead and save everyone the trouble?
mark09
7 (0.00/day)
Jdownloader is not that obscure. It's very popular. I used that because I don't know any word in russian so I was not able to download directly from the website. I've tried that on my mobo ASRock 890FX Deluxe 4.
Anyway, in that package you will find all the tools needed for the update, except for the updated firmware that you can find on station-drivers.
Now it's up to you if you want to try. I did it and it works. If you want to update that is the only way if you have multiple controllers (it's just about using some command switches of the updater and adding two lines to the cfg.ini, everything written in detail in the howto).
Bye.
228 (0.04/day)
Display(s) 27" Asus
Maybe TPU can look into this and supply it on their website. >.>
839 (0.14/day)
System Name GB
Processor Core i7-4790K
Motherboard Gigabyte GA-Z97X-SOC Force
Cooling XSPC RayStorm D5 EX240 (Liquid Ultra)
Memory G.Skill F3-2933C12D-8GTXDG @ 3100 (CL.12) @ 1.66V
Video Card(s) Evga GTS 450SC
Storage 2xSSD Corsair Force GS 128 (RAID 0), WD Caviar Black 1TB
Case NZXT Phantom 630 Ultra Tower
Power Supply Gigabyte Superb 720W
Software Win 7 SP1 x64;Win 8 x64 (6.3)
2 (0.00/day)
Regarding the driver version 2.1.25.0
I have firmware revision 3025 on an Asus Sabertooth X58 with BIOS1201 and currently run driver 2.1.19.0 on Windows 7 x64.
I tried updating to this newer driver but experienced a clash with the Nvidia driver 285.27 beta and my GTX570s in SLI.
This new driver has problems with my setup and stops the graphics driver from operating in SLI correctly. Non-SLI seems to be OK but as soon as SLI is selected, the driver crashes out and reverts the screen resolution to low with the graphics hardware reported as stopped in device manager. Update/clean install of Renesas driver 2.1.25.0 same result.
Back to previous build and all is OK.
FYI
2,334 (0.44/day)
Keyboard Dell
I had a problem as well with 285.27 Beta and Skype. 460GTX, single right now
I thought it was Beta Driver, so I went back to previoius version. Skype now works.
Now I am thinking it is the 2.1.25.0 Driver. UNSURE???
2 (0.00/day)
The Renesas/NEC driver installed OK but disables SLI and forces the hardware to release the driver. With SLI disabled, all seems OK.
This may be purely a bug with the Nvidia beta driver. The only way to test would be to go back to a previous Renesas/NEC driver ( I'm running 2.1.19.0 without error in tandem with the beta Nvidia driver).
The USB 3.0 host controller driver is the easiest to remove/re-install, so get the one supplied by your motherboard manufacturer and uninstall 2.1.25.0 and put the older one on. Then re-install (cleanly) the beta driver and check everything is OK. If not, then it's the Nvidia beta and not the Renesas/NEC driver.
A WHQL will be along shortly in any case from Nvidia.
My problem was with SLI.
839 (0.14/day)
System Name GB
:laugh:
590 (0.11/day)
Latvia
System Name Zen2600
Processor Ryzen 2600
Motherboard MSI B450-A Pro MAX
Cooling Captain120EX
Memory 2x8 GB Patriot Viper Steel 360000 @3400MHz [18-19-19-39-80] DDR4
Video Card(s) Sapphire RX5700XT Nitro+ @stock
Storage WD Black 500GB NVME
Display(s) LG 32GK850F
Case NZXT H440 EnvyUS
Audio Device(s) Custom HP AMP + Sennheiser HD380
Power Supply Thermaltake Toughpower GF1 650w
Keyboard ElE Game1
Thanks for info of new drivers!:toast: (MSI hsn't updated their downloads page for a while)
Bad thing: Readme says basically that if something is wrong, it won't run firmware update, but in my case that means it stops flashing process in the middle, freaking me out, then introduces memory leak, which forces hard restart. (that happens when you try to flash 4015 firmware to uPD720200 chip:D)
Good thing: successfully updated latest Firmware(3028) and Driver(2.1.25.0) for my MSI Star USB3 PCIE card.
11 (0.00/day)
planet earth
System Name chronic inc.
Processor intel core 2 quad q6600
Motherboard asus p5b deluxe wifi-ap
Memory v-gen ddr2 800 cl5 8gb
Video Card(s) sapphire hd 5850 xtreme
Storage wd2002faex, wd20ears
Display(s) dell s2209w
Case thermaltake jr.
Power Supply seasonic x-660
Software windows 7 pro sp1 x64, ubuntu 12.04 x32
thanks for the info on new renesas driver on intel site and firmware from station-driver.
unfortunately this cheap pcie x1 to usb 3.0 addon card is still not compatible with wd my passport essential 500gb usb 3.0 external drive or vice versa. :(
disable the usb 3.0 power management didn't help too, the system could not detect any drive at all.
Mussels
Freshwater Moderator
58,413 (7.94/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
does it have an internal molex power connector? might need it.
11 (0.00/day)
planet earth
already plugged in. it's using 7207200a chip. from the renesas site, this one is a power safer compared the old 7207200 one.
gigabyte ga-890fxa-ud5 v2.1 use the old chipset and it can powered wd passport essential 500gb usb 3.0 using both original short cable from wd and cheap 1.5m usb 3.0 cable long flawlessly.
i've tested with my vendor regarding the pcie x1 usb 3.0, and it can only detect usb 3.0 flashdrive, not portable hard drive. the wd sure was powered but the system could not initialize it.
95Viper
Super Moderator
12,996 (2.21/day)
Updated: Renesas Electronics USB 3.0 Driver version 2.1.27.0 Intel download page
File name: USB3.0_allOS_2.1.27.0_PV.exe
Version: 2.1.27.0
Date: 10/13/2011
Operating Systems: Windows 7, 32-bit*, Windows 7, 64-bit*, Windows Vista 32*, Windows Vista 64*, Windows XP Home Edition*, Windows XP Media Center Edition*, Windows XP Professional x64 Edition*, Windows XP Professional*
I found no release notes, yet... still looking.
If I find any I will post them; and, if, anyone gets them for this version 2.1.27.0... please post them.:)
2,334 (0.44/day)
Keyboard Dell
ecchymose
1 (0.00/day)
Not sure it is compatible with original chips: uPD720200 & uPD720200a
It isn't. The uPD720201 & uPD720202 are the next version of the Renesas USB 3.0 chips and are incompatible with uPD720200(a). For one thing, they add features like USB 3.0 Debug (which, at long last, may make USB a viable replacement for serial ports) and they use internal flash ROM, as opposed to external for uPD720200.
Now, while the drivers have been made public, it doesn't look like anybody (except the few people who got advanced samples directly from Renesas) will be able to get their hands on these controllers before 2012, as uPD720201 & uPD720202 based products won't be available for the general public before then. As such, having access to the uPD720201 & uPD720202 drivers is currently quite useless...
angushades
4 (0.00/day)
Hey guys i currenty have the ROG maximus z68 which controller do i have , i couldn't find the info anywhere? Oh and is there any work around the duel USB3 controllers yet for updating.
Mussels
58,413 (7.94/day)
Oystralia
my NEC USB 3.0 controller keeps going yellow triangle on me in device manager after using sleep mode :(
839 (0.14/day)
System Name GB
