- Aug 20, 2007
- 21,802 (3.41/day)
- Olympia, WA
System Name | Pioneer |
Processor | Ryzen 9 9950X |
Motherboard | MSI MAG X670E Tomahawk Wifi |
Cooling | Noctua NH-D15 + A whole lotta Sunon, Phanteks and Corsair Maglev blower fans... |
Memory | 128GB (4x 32GB) G.Skill Flare X5 @ DDR5-4000 (Running 1:1:1 to FCLK) |
Video Card(s) | XFX RX 7900 XTX Speedster Merc 310 |
Storage | Intel 5800X Optane 800GB boot, +2x Crucial P5 Plus 2TB PCIe 4.0 NVMe SSDs, 1x 2TB Seagate Exos 3.5" |
Display(s) | 55" LG 55" B9 OLED 4K Display |
Case | Thermaltake Core X31 |
Audio Device(s) | TOSLINK->Schiit Modi MB->Asgard 2 DAC Amp->AKG Pro K712 Headphones or HDMI->B9 OLED |
Power Supply | FSP Hydro Ti Pro 850W |
Mouse | Logitech G305 Lightspeed Wireless |
Keyboard | WASD Code v3 with Cherry Green keyswitches + PBT DS keycaps |
Software | Gentoo Linux x64 |
I'd assume they had a backup generator, but that backup generator failed for an hour.
The problem with backup plans is that backup plans are rarely tested. It could be as simple as "backup generator's gasoline went busted" or "not enough oil to start the engine", and bam, you have actual downtime.
Or if its a battery-backup system, then "batteries couldn't hold a charge as long as expected", or similar effect that you won't figure out until you actually experience a mains outage. An aged battery will have a lower amperage for output, and that alone can cause an outage and/or issues. (Ex: you get 110V @ 50Hz instead of @60, so you have 18% less power than expected).
Yeah, at this point though this excuse has been used too many times for them not to be testing this system regularly. It's a "negilgence" type scenario even if it is true, as I said. They just decided it was cheaper to let it happen to jack up the costs, or outright fake it. Take your pick, both are bad.
