120mm case fans best for push/static/CFM on radiators?
ixi
1,451 (0.39/day)
Kaze flex II 120 there are three models, take the loudest one :]
CFM ~ 90.28
mmH2O / Pa ~ 26.28
Lei
1,143 (0.97/day)
usually in my shirt
Processor 3900x - Bykski waterblock
Motherboard MSI b450m mortar max BIOS Date 27 Apr 2023
Cooling αcool 560 rad - 2xPhanteks F140XP
Memory Micron 32gb 3200mhz ddr4
Video Card(s) Colorful 3090 ADOC active backplate cooling
Storage WD SN850 2tb ,HP EX950 1tb, WD UltraStar Helioseal 18tb+18tb
Display(s) 24“ HUION pro 4k 10bit
Case aluminium extrusions copper panels, 60 deliveries for every piece down to screws
Audio Device(s) sony stereo mic, logitech c930, Gulikit pro 2 + xbox Series S controller, moded bt headphone 1200mAh
Power Supply Corsair RM1000x
Mouse pen display, no mouse no click
Keyboard Microsoft aio media embedded touchpad (moded lithium battery 1000mAh)
Software Win 11 23h2 build 22631
Benchmark Scores cine23 20000
So this is a12x25 with 2.34 mm H₂O static pressure
And this is nf12 with 2.61 mm H₂O
To add in salt to injury, the one with higher static pressure has max rpm of 1500, while the other one is 2000
2,373 (0.58/day)
Audio Device(s) A LOT
Don’t trust manufacturer specs, and especially don’t compare specs between manufacturers. You don’t know what the testing conditions are for either, or if the manufacturer changed over time.
VSG does some excellent reviews here — I’d recommend looking there. Even then, the numbers don’t tell the whole story, like the terrible motor noise on NF-F12s or the awful noise against Arctic fans make when next to a filter.
More, static pressure and CFM in and of themselves don’t tell the whole story — it’s why the NF-A12 was designed the way it was and outperforms both the NF-P12 and NF-F12, and why the GT design has become the de facto standard for performance against radiators or filters.
Lei
1,143 (0.97/day)
usually in my shirt
It's why the NF-A12 was designed the way it was and outperforms both the NF-P12 and NF-F12, and why the GT design has become the de facto standard for performance against radiators or filters.
Well here it says NF-F12 is optimal for rad, not NF-A12x25
2,373 (0.58/day)
Don’t trust the company trying to sell you their fans. The F12 pushes less air through a radiator with more noise. Noctua is just resting on the reputation of a fan that’s more than a decade old and isn’t even as good as a GT.
idk what happened to Ed but he was great too
I am 90% certain SPCR tested the F12 bundled with a heatsink but can’t find the review :(
  • Like
Reactions: Lei
