- Feb 24, 2013
- 193 (0.04/day)
System Name | Vaksdal Venom |
Processor | Ryzen 7 7800X3D |
Motherboard | Gigabyte B650 Aorus Elite AX V2 |
Cooling | Thermalright Peerless Assassin 120 SE |
Memory | G.Skill Flare X5 DDR5-6000 32GB (2x16GB) CL30-38-38-96 |
Video Card(s) | MSI GeForce RTX 3080 SUPRIM X |
Storage | WD Black SN750 500GB, Samsung 840 EVO 500GB, Samsung 850 EVO 500GB, Samsung 860 EVO 1TB |
Display(s) | Viewsonic XG2431 |
Case | Lian Li O11D Evo XL (aka Dynamic Evo XL) White |
Audio Device(s) | ASUS Xonar Essence STX |
Power Supply | Corsair HX1000 PSU - 1000 W |
Mouse | Logitech G703 Hero |
Software | Windows 10 Home 64-bit |
Having built quite a few PCs I usually have a standard routine for inserting new internal drives. I plug them in, then go into Windows Disk Management and partition/initialize/format them.
Admittedly I haven't inserted an HDD for many years (only SSDs), and certainly not as big as this. Anyway, this was for a friend on his Asus TUF B360-PRO Gaming motherboard.
I plugged the SATA cable into the connector numbered 1 on the mobo and then to the disk, and connected power from the PSU. Then I breifly checked the BIOS on boot, it was registered correctly there. I then proceeded into Windows only to discover something I hadn't experienced before: The disk shows up in Device Manager but not in Disk Management! So basically I couldn't make use of it.
Screenshot of device manager and disk management below (Norwegian OS in case you're wondering). The Kingston drive (C: ) is an M.2 drive.
Has anyone of you experienced this before? I will contact Seagate support, but I just thought I'd try my luck here first.
The only thing I tried so far was to switch connector on the mobo (from 2 to 1). Same result. I haven't tried changing SATA cable, although I'm not sure it'll help given that it seems to be correctly registered in both the BIOS and Device Manager.
Oh, and I also just to be sure downloaded and installed the SATA drivers for the mobo. Same result.
Cheers
EDIT: The screenshot doesn't show the disks in Disk Management, but there was only one there, DISK 0, and that was the Kingston M.2 drive.
Cheers
