666W VBios 4090 for Science
608 (0.12/day)
St. Louis, MO
System Name Desktop
Processor AMD Ryzen 7800X3D
Motherboard MSI X670E MEG ACE
Cooling Corsair XC7 Block / Corsair XG7 Block EK 360PE Radiator EK 120XE Radiator 8x EK Vadar Furious Fans
Memory 64GB TeamGroup T-Create Expert DDR5-6000
Video Card(s) MSI RTX 4090 Gaming X Trio
Storage 1TB WD Black SN850 / 4TB Inland Premium / 8TB WD Black HDD
Display(s) Alienware AW3821DW / ASUS TUF VG279QM
Case Lian-Li Dynamic 011 XL ROG
Audio Device(s) Razer Nommo Pro Speakers / Audio-Technica ATH-R70X
Power Supply EVGA P2 1200W Platinum
Mouse Razer Viper, Logitech G600
Keyboard Razer Huntsman Elite
Sooo I decided to mess around with the Galax 666W VBios for the 4090 last night.
Backed up my current one and then flashed.
I was happily surprised that I was able to pull that much power through my 3-pin to 12VHPWR cable.
Though I would admit it didn't do anything other than make the card run hotter than it was before. Maybe 1-2% increase in performance for 25%+ power increase...
On my stock VBios, I would occasionally see 400W and my core clock would be between 2950-3025Mhz full boost... With the Galax VBios I could get get up to 3075-3125Mhz... but it was pulling 600W-650W.
The temperatures were drastically different.... my 10C delta between core and hotspot (typically 55C-65C, respectively) shot up to a 20C delta (75C-95C) when using the Galax VBios....
Yeah, it definitely isn't worth it, and I put my stock VBios back in place. I also watched a couple YouTube videos for the giggles to compare.
Please.... my fellow 4090 owners.... Just leave it alone, it isn't worth the extra heat and wear on the card. Use the Nvidia/MSI OC Scanner and enjoy...
43,025 (6.72/day)
Hey put your stock bios back on and gpu-z screenshot it, i want to see a few details of it.
666w is like co2 or ln2 territory
1,594 (3.78/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Well yeah, Galax GPUs are usually binned specifically for their cards higher tier. I'd expect no less from it :)
608 (0.12/day)
St. Louis, MO
System Name Desktop
@eidairaman1 Here you go
43,025 (6.72/day)
Yeah i found 2 of your files in the collection 480W is your max, pg 139 sku 330 is the board part number, you can always try the liquid cooled msi card bios in the 4090 range which has like a max of 520W.
And thank you for being logical about this, many do a flash and then wonder why their fans run faster or the card starts throttling to try and not go super nova
Solaris17
Super Dainty Moderator
27,178 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
I flashed mine back after playing with the galax bios, even ran the release 600w bios instead of the patched (post release updated) bios for my card (530w) for awhile. just wasnt worth tbh. now im sitting on post release vbios; just wasnt worth it.
1,417 (0.31/day)
Processor i7-13700k
Motherboard Asus Tuf Gaming z790-plus
Cooling Coolermaster Hyper 212 RGB
Memory Corsair Vengeance RGB 32GB DDR5 7000mhz
Video Card(s) Asus Dual Geforce RTX 4070 Super ( 2800mhz @ 1.0volt, ~60mhz overlock -.1volts)
Storage 1x Samsung 980 Pro PCIe4 NVme, 2x Samsung 1tb 850evo SSD, 3x WD drives, 2 seagate
Display(s) Acer Predator XB273u 27inch IPS G-Sync 165hz
Audio Device(s) Logitech Z906 5.1
Power Supply Corsair RMx Series RM850x (OCZ Z series PSU retired after 13 years of service)
Mouse Logitech G502 hero
Keyboard Logitech G710+
Yea there is a point with processors that you need many double digit % in power to get single digit boosts.
3,280 (4.77/day)
Russian Wild West
System Name DLSS / YOLO-PC / FULLRETARD
Processor i5-12400F / 10600KF / C2D E6750
Motherboard Gigabyte B760M DS3H / Z490 Vision D / P5GC-MX/1333
Cooling Laminar RM1 / Gammaxx 400 / 775 Box cooler
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333 / 3 GB DDR2-700
Video Card(s) RX 6700 XT / R9 380 2 GB / 9600 GT
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 / 500 GB HDD
Display(s) Compit HA2704 / MSi G2712 / non-existent
Case Matrexx 55 / Junkyard special / non-existent
Power Supply Thermaltake 1000 W / Corsair CX650M / non-existent
Software Windows 11 / 10 / 8
10 FPS for +60% wattage. This overclocking is not worth it anymore no matter the brand, the make, anything. Enjoy your mighty GPU!
