6700XT - POST Issues
drdn0
6 (0.40/day)
Specs:
  • ASUS AM4 ATX ROG STRIX B550-A
  • 5700X3D
  • MSI RX6700XT 12GB MECH 2X
  • 32GB Corsair (2x16) DDR4
  • RM750X
Further information:
  • RAM on DOCP profile
  • Latest BIOS
  • Latest drivers
  • RAM/PSU have been swapped for others and no change.
  • No other issues with the PC whatsoever since it was built.
  • 2x monitors - AOC 32" 1440p via HDMI, Samsung 27" 1080p via DP.
  • Certificed HDMI/DP cables (which oddly matters)
Issue:
Coming in from being shut down, the computer will go into a continuous loop of attempting to POST, throwing a VGA error, resetting and continuing. No video output happens during this time. However, if I power cycle once, everything works fine and the computer boots normally.
System has been extensively stress tested, and there isn't a single issue during use - I can max load every component in my system with zero issues. The ONLY issue is failing to POST without a power cycle beforehand.
The issue has been reported frequently with 6700XT's, and it was suggested it may have something to do with the GPU failing to handshake monitors with power saving features, which causes the VGA error. I have turned power saving features off on my monitors but the problem persists.
Any suggestions?
7,448 (3.20/day)
California
System Name His & Hers
Storage lots of SSD.
Are those aoc monitors identical? Do you have a TV you can test the pc with to verify the same behavior.
I've had issues with amd cards and specific monitors but it's been pretty rare.
drdn0
6 (0.40/day)
I have one AOC monitor and one Samsung monitor.
I have swapped the 27" out and it made no difference
3,450 (4.92/day)
Russian Wild West
System Name DLSS / YOLO-PC / FULLRETARD
Processor i5-12400F / 10600KF / C2D E6750
Motherboard Gigabyte B760M DS3H / Z490 Vision D / P5GC-MX/1333
Cooling Laminar RM1 / Gammaxx 400 / 775 Box cooler
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333 / 3 GB DDR2-700
Video Card(s) RX 6700 XT / R9 380 2 GB / 9600 GT
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 / 500 GB HDD
Display(s) Compit HA2704 / MSi G2712 / non-existent
Case Matrexx 55 / Junkyard special / non-existent
Power Supply Thermaltake 1000 W / Corsair CX650M / non-existent
Software Windows 11 / 10 / 8
If you're on Windows then go to the Control Panel and land there:
The fast startup is enabled by default and causes issues precisely because your PC doesn't shut down completely.
DISCLAIMER: this is not a real solution, just a workaround.
You could also try flashing a different BIOS on your GPU. Worked for me but only just once when one legacy card had exhibited UEFI glitches so I flashed it to something that doesn't support UEFI. Wasn't the real cause of this issue in other cases. WARNING: it is likely to brick your GPU, make sure you have a backup video card and enough time to reflash it properly. Back your BIOS up and store it somewhere safe. I won't guarantee it'll help anyway.
I also assume you tried ALL DPs on your GPU to no avail but if you didn't try different combinations out. What if you have a glitchy port..?
I also assume you tried booting without any monitor connected whatsoever. Was the behaviour exactly the same? If yes it's not your monitors, or cables, it's something else.
Chances are very low but it might be your CPU playing tricks. Try giving it slightly more voltage and see if the issue persists.
drdn0
6 (0.40/day)
I also assume you tried ALL DPs on your GPU to no avail but if you didn't try different combinations out. What if you have a glitchy DP..?
Fast startup is off, and has always been off.
No difference
3,450 (4.92/day)
Russian Wild West
Hmmmmm, then this fuckup is very deep. Any chance to try this GPU in a different system?
drdn0
6 (0.40/day)
No.
Again, it's not exactly a rare thing - there are dozens of posts about it with no solutions.
It's not the end of the world and everything works fine once it's booted, but it is annoying
1,712 (3.92/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
DP is primary display port. I would put the 1440 monitor on that, and the 1080 on hdmi. Both on DP ports if possible really.
43,272 (6.74/day)
You get this card used?
Breadboard system
hook system staight up to wall and make sure no atx connections on motherboard or gpu are damaged.
Try system in different room
Try card in another system, even if at a repair shop
Low quality post by drdn0
drdn0
6 (0.40/day)
Breadboard system
No.
Utterly pointless 'advice' lol.
43,272 (6.74/day)
@drdn0
You may want to rethink about what you wrote.
You came here asking for help, I am providing several suggestions to try.
Being that way towards senior members will cause others to not help you. I for one have been here since 2007. I also wrote the bios flashing procedures for AMD Polaris and newer cards.
Also on another note good luck finding a solution because your choices are very slim on how to fix said issue.
