6900xt degrades below stock speeds within 4 Weeks?
Status
Not open for further replies.
2,930 (2.08/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
before you guys write "reinstall the driver"..
the card was tested in now the 4th PC, Blank windows 10 installation, different Platforms (AM4 (X570), Z490, Z590, AM4 (B550))
in the first three Weeks my 6900xt ran 100% Stable at 2700 mhz (benched Timespy, Firestrike, Port Royal and i played almost (mixed) 200 Hours! of valheim, Battlefield, RB6, WoW, NFS Heat and other games)
The Cards ran every application for an indefinite amount of time.
Now after 3 weeks i had non stop crashes in a bunch of games (but not all)
10 Mhz Down. everything is completely stable (Timespy loops, the games that crashed and superposition just fine.)
when i bump it up again by 10Mhz everything is unstable.
Now that repeats every few days and now i am almost at my Stock speeds.
50Mhz less than at day one does not even run CS:GO anymore. and i have to go 70 Mhz below the (First three Weeks for 200 Hours of load stable) Clock Speed.
Today i am sitting at just 30 Mhz above Stock (that's 160 Mhz below the once stable OC)
And now the reason why i post this..
Since today the card is not even stable at stock speeds anymore (blank, fresh installed windows 10 on two different machines with two different PSUs)
going into wattman and clicking on "reset" and running the card at stock speeds crashes in a few games and i have to drop clocks by around 20Mhz below Stock.
This is ridiculous... but i don't understand how a Card can degrade within a month from +200 Mhz above Stock to -20 below stock.
Deleted member 202104
in the first three Weeks my 6900xt ran 100% Stable at 2700 mhz (could run furmark over night,)
You most likely have cooked it with Furmark running overnight at 2700. It wouldn't be the first time it's killed a GPU.
Furmark is not your friend.
3,809 (0.75/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
Holy carp, you ran furmark overnight? I have to wonder why?
2,930 (2.08/day)
Germany
i never ran furmark at all.
i meant that the OC was stable enough to run furmark over night. (i don't even have it installed)
3,809 (0.75/day)
Processor AMD 5900x
Storage Sabrent
Case Phanteks 719
Mouse Logitech G600
Well that changes things. I would try to confirm stability in a second machine if possible before RMA.
The only other thing that sticks out in your system specs is your PSU in that it could be a power draw issue. Try to pinpoint whether its a gpu issue or possibly a power issue. You've got a 330w+ cpu and a 350w gpu which doesn't count anything else that draws power in your setup. If the card is stable in a second rig, then it's likely the psu. Between the two I'd rather replace the psu so cross your fingers.
1,491 (0.95/day)
System Name Chip
Processor Amd 5600X
Motherboard MSI B450M Mortar Max
Cooling Hyper 212
Memory 2x 16g ddr4 3200mz
Video Card(s) RX 6700
Storage 5.5 tb hd 220 g ssd
Display(s) Normal moniter
Case something cheap
VR HMD Vive
wait
so you are saying it could run this program overnight
but i never actually knew this and where gussing
1,035 (0.18/day)
Processor Ryzen 9 5900X
Cooling ARCTIC Liquid Freezer III 360 A-RGB
Memory 32 GB Ballistix Elite DDR4-3600 CL16
Video Card(s) XFX 6800 XT Speedster Merc 319 Black
Storage Sabrent Rocket NVMe 4.0 1TB
Display(s) LG 27GL850B x 2 / ASUS MG278Q
Case be quiet! Silent Base 802
Audio Device(s) Sound Blaster AE-7 / Sennheiser HD 660S
Power Supply Seasonic Vertex PX-1200
Software Windows 11 Pro 64
Your overclocking results may vary, and pushing a card too far can degrade it's performance. Sounds like you pushed things a little too hard?
XFX Speedster MERC319 RX 6900 XT BLACK​
Base Clock 1825 MHz 1950 MHz (+7%)
Game Clock 2015 MHz 2135 MHz (+6%)
Boost Clock 2250 MHz 2365 MHz (+5%)
3,454 (1.17/day)
Processor 9800X3D
Cooling DeepCool AK620
Storage 4TB Samsung 990 Pro
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX850
Mouse Razor Death Adder v3
Software win11
Well when the card can't run stock clock it's time for RMA, or you can send it to Buildzoid to investigate how that happen I guess.
wolf
Better Than Native
8,245 (1.28/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte X650I AX
Cooling Scythe Fuma 2
Memory 32GB DDR5 6000 CL30
Video Card(s) Asus TUF RTX3080 Deshrouded
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
This is a genuine fear of mine with a current-gen card, RMA but they have no stock to give you a replacement... yikes.
AsRock
TPU addict
19,105 (2.99/day)
UK\USA
What ?, why should they replace it ?, if he overclocked the crap out of it then there is only one to blame. Shit like this is why XFX don't do lifetime warranty's any longer.
594 (0.12/day)
St. Louis, MO
System Name Desktop
Processor AMD Ryzen 7800X3D
Motherboard MSI X670E MEG ACE
Cooling Corsair XC7 Block / Corsair XG7 Block EK 360PE Radiator EK 120XE Radiator 8x EK Vadar Furious Fans
Memory 64GB TeamGroup T-Create Expert DDR5-6000
Video Card(s) MSI RTX 4090 Gaming X Trio
Storage 1TB WD Black SN850 / 4TB Inland Premium / 8TB WD Black HDD
Display(s) Alienware AW3821DW / ASUS TUF VG279QM
Case Lian-Li Dynamic 011 XL ROG
Audio Device(s) Razer Nommo Pro Speakers / Creative AE-9 w/ Audio-Technica ATH-R70X
Power Supply EVGA P2 1200W Platinum
Mouse Razer Viper, Logitech G600
Keyboard Razer Huntsman Elite
I am still confused as to whether the OP ran FurMark or not on their card..... it appears the original post has been edited. FurMark can wreck cards at stock not to mention OC'd.
9,781 (2.20/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
probably realized replies would point out the fault of using it, & edited the post.
regardless, this type of manic benchmarking is bound to end with nothing good. theres no sense to all that benchmarking & stress testing. if you push a component as hard as you can, as much as you can, eventually its going to quit. its pointless, especially when youre running higher end gear
this is like a guy spinning his tires all the time, every stop light, burning out, then wondering what happened when he blows gaskets, & shreds his tires.
if thats what a person enjoys, thats fine, but hardware damage comes with the territory eventually.
1,136 (0.26/day)
Babylon 5
System Name DaBeast!!! DaBeast2!!!
Processor AMD AM4 Ryzen 7 5700X3D 8C/16T/AMD AM4 RYZEN 9 5900X 12C/24T
Cooling Thermaltake Water 3.0 360 AIO/Thermalright PA 120 SE
Mouse Logitech G303 Shroud Ed/Logitech G603 WL
Keyboard Logitech G915/Keychron K2
Software Win11 Pro/Win11 Pro
That's why when I'd gotten my GPU, I'd OC'ed it and benchmarked it, and after I was done, I left it at stock speed with a little UV.
Nothing bad has happened, runs solid. Peeps who do all these crazy OCs and volt mods and whatnot, not saying the OP did this, but running a stressful benchmark like Furmark overnight isn't exactly ideal. They kill their cards and then blame the card makers, that's just bad form.
Fyi, I've had my 6900XT for about 2 months now, spend about 3-4 hours on games each day with 2-3 hours in addition to that surfing and media consumption. My 6900 XT is running perfectly fine.
551 (0.17/day)
Texas
System Name O-Clock
Processor Intel Core i9-9900K @ 52x/49x 8c8t
Motherboard ASUS Maximus XI Gene
Cooling EK Quantum Velocity C+A, EK Quantum Vector C+A, CE 280, Monsta 280, GTS 280 all w/ A14 IP67
Memory 2x16GB G.Skill TridentZ @3900 MHz CL16
Video Card(s) EVGA RTX 2080 Ti XC Black
Storage Samsung 983 ZET 960GB, 2x WD SN850X 4TB
Display(s) Asus VG259QM
Case Corsair 900D
Audio Device(s) beyerdynamic DT 990 600Ω, Asus SupremeFX Hi-Fi 5.25", Elgato Wave 3
Power Supply EVGA 1600 T2 w/ A14 IP67
Mouse Logitech G403 Wireless (PMW3366)
Keyboard Monsgeek M5W w/ Cherry MX Silent Black RGBs
Benchmark Scores https://hwbot.org/search/submissions/permalink?userId=92615&cpuId=5773
For context, 3 weeks is equal to 504 hours. So the OP spent more than 40% of that time using the GPU intensively..., basically 9.6hrs every day, uh, u do sleep right? lol how u have so much time for that much gaming in 3 weeks
1,491 (0.95/day)
System Name Chip
Processor Amd 5600X
Cooling Hyper 212
VR HMD Vive
no wonder that card is dead lol
551 (0.17/day)
Texas
System Name O-Clock
Case Corsair 900D
3,454 (1.17/day)
Processor 9800X3D
Software win11
If OP didn't modify his card physically I think XFX is liable to replace his card. Whatever OP was doing, it would only accelerate a fault in the design that are meant to fail later on, and it's XFX's fault.
1,491 (0.95/day)
System Name Chip
Processor Amd 5600X
Cooling Hyper 212
VR HMD Vive
he oced it and proceded to push it really hard
maybe even furmark
he does not dserve a rma
3,809 (0.75/day)
Processor AMD 5900x
Storage Sabrent
Case Phanteks 719
Mouse Logitech G600
maybe even furmark
You've no idea what you're talking about. You can't overclock these cards to death. These cards have a hard bios limiter and plenty of protections. It will run at its max tdp all day long as IT WAS DESIGNED TO.
Frick
Fishfaced Nincompoop
19,660 (2.86/day)
Piteå
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Memory 2 x 16GB Corsair Vengeance
Case Fractal Design Define R4
Keyboard Dell SK3205
Hang on guys, when did overclocking and using the hardware become this controversial thing? This kind of degradation sounds terrible.
3,809 (0.75/day)
Processor AMD 5900x
Storage Sabrent
Case Phanteks 719
Mouse Logitech G600
Yea, it's bizarre contrarian mindset. These cards will not go into a nuclear meltdown. TPU showed below that furmark power draw was actually lower than peak gaming power draw, lmao. And even compared to the averaged gaming power draw vs furmark, furmark was only 15w higher.
Mussels
Freshwater Moderator
58,413 (7.92/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
GPU's cant die from overclocking just the freqeuncies via software - they're so locked down with BIOS limits they're impossible to kill via software
Normally i'd say replace the thermal paste and thermal pads, but its so new just RMA the damn thing for being unstable at stock
9,499 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
No way it degraded, something else happened. I suspect it's PSU related, 6900XT's power consumption spikes very hard.
AsRock
TPU addict
19,105 (2.99/day)
UK\USA
I think they will, how ever personally if i was pushing one to the max i blame my self and not the card.
If he decides to take it apart though he needs to get in touch with XFX with his issue and ask them if he can try it just to see if it solves the problem.
If he just takes it apart and it don't work or has same issue and then contact them and they say just send it in they don't have to fix\replace it as the seals will of been broken and did not ask them first.
I have had no issue's over a very long time with them over some 10 years now.
632 (0.30/day)
Ah yes, the "proverbial" AMD quality strikes again one might say... My condolences to the OP but their recent products really aren't fit to be pushed hard over extended periods as shown numerous times ever since Zen2 & Navi landed back in 2019.
Status
