a little review of intel branded lga 2011-3 cooling solution- extremely compact and effective
924 (0.18/day)
System Name future xeon II
Processor DUAL SOCKET xeon e5 2686 v3 , 36c/72t, hacked all cores @3.5ghz, TDP limit hacked
Motherboard asrock rack ep2c612 ws
Cooling case fans,liquid corsair h100iv2 x2
Memory 96 gb ddr4 2133mhz gskill+corsair
Video Card(s) 2x 1080 sc acx3 SLI, @STOCK
Storage Hp ex950 2tb nvme+ adata xpg sx8200 pro 1tb nvme+ sata ssd's+ spinners
Display(s) philips 40" bdm4065uc 4k @60
Case silverstone temjin tj07-b
Audio Device(s) sb Z
Power Supply corsair hx1200i
Mouse corsair m95 16 buttons
Keyboard microsoft internet keyboard pro
Software windows 10 x64 1903 ,enterprise
Benchmark Scores fire strike ultra- 10k time spy- 15k cpu z- 400/15000
In a draw of luck, the second of my corsair AIO h100i just died out of the blue, and while the first was under warranty and replaced the same day, this one isn't, and just by luck my two intel coolers arrived few days before
compared to the 240mm aio, the cpu runs about 5c hotter, but passes a stress test wonderfully, being fully unlocked and tdp unlimited(!). the cooler is a bit loud when fully loaded, and louder than the aio at idle, but it is super easy to install, does it's job, and I won't be using the flaky AIO's from now on. The installation of two AIO in the tower is much harder, the faulty one still hanging there as it was custom installed by me.
The tdp of the intel cooler is 150w, but I find it is much stronger than this, and certainly the heat pipes and the fan are very efficient.
14,223 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
A small correction, the cooler pictured is for Socket 2011 the first iteration, not 2011-3.
It also shows as TDP130 not TDP150 as you mentioned.
I have one of these and find it better than the stock Intel cooler, but not as efficient as a tower cooler.
1,962 (0.56/day)
Seattle, WA
Considering the mechanical specifications did not change between the various iterations of LGA 2011 that's a very small correction. Unless you want to cite the dynamic and static compressive load values changing by exactly 1 newton.
622 (0.09/day)
Oak Ridge, TN
System Name BorgX79
Processor i7-3930k 6/12cores@4.4GHz
Motherboard Sabertoothx79
Cooling Capitan 360
Memory Muhskin DDR3-1866
Video Card(s) Sapphire R480 8GB
Storage Chronos SSD
Display(s) 3x VW266H
Case Ching Mien 600
Audio Device(s) Realtek
Power Supply Cooler Master 1000W Silent Pro
Mouse Logitech G900
Keyboard Rosewill RK-1000
Software Win7x64
Those look like the coolers that came with my i7-920's back in the day.
I know I have 2 of them, I'm using them for 100W LEDs now.
They work pretty well for that, so they're decent coolers.
I replaced them with towers.
13,584 (2.01/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
My bold underline added for emphasis,
Pedestal chassis that provides adequate ventilation and correct temperature air to heat sink with fan removed
I have a colleague who builds a lot of custom PCs designed for use in home theaters where "silent running" (that is, zero fan noise) is a top client demand. He reports these affordable coolers work great for that, and he recommends their use when absolute silence is a requirement. But, he added if you keep the fan attached, it is very quiet on low speeds, but the fan noise may be unacceptable to some at full speed.
924 (0.18/day)
indeed it is a tad noisy @8000rpm, but asrock provides user customized fan curves in the bios, so i will keep it @ 20% on idle temps at least
1,870 (0.75/day)
Arizona
System Name Space Heater MKIV
Processor AMD Ryzen 7 5800X
Case Phanteks Enthoo Pro M
Mouse Logitech MX Master 3
Keyboard Glorious GMMK 2 96%
I'm sure mounting an aftermarket fan from Noctua or something would fix that.
13,584 (2.01/day)
Nebraska, USA
Mouse Logitech M190
That's if the fan is actually needed. But again, that's if needed. It takes very little air movement to make that heatsink much more efficient. So a very low fan speed may be all that's needed. And then the included fan is really quiet - especially in a good case.
1,870 (0.75/day)
Arizona
I'm also guessing there's no easy way to mod it to fit on other sockets...
Would be nice if Intel would go with a design like this for their stock coolers to compete with AMD's Wraith Prism cooler.
