AAF Realtek DCH Audio Driver - DTS
Status
Not open for further replies.
139 (0.09/day)
Processor Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz 3.60 GHz
Motherboard Gigabyte Technology Co., Ltd. B85M-D3H
Memory 8,00 Go (7,89 Go utilisable
Video Card(s) GPU 1 NVIDIA GeForce GTX 970/ GPU 0 Intel(R) HD Graphics 4600
Display(s) Samsung Q60T
Case Zalman case
Mouse USB NGS
Keyboard Old Dell keyboard
I did exactly as mentioned in the instructions. DTS did not work. If you need any information about my notebook or other information, I am available to help. I can provide remote access if you need it. While we are unable to resolve it, I am going to go back to the latest version of the Alan Finote AAF DCH Optimus Sound 6.0.9116.1 (Signed) driver. Everything is working perfectly in this version.
Same for me
34 (0.02/day)
@Hearick, When I install Alan's mod DTSAPO4 service works. - That's because it detected stereo, and the audio device most likely.
@emanresu, always scan files and so on, I believe that may be something to do with plugins, and information.
Even my Linux STB will connect to github because that's how the plugin gets information.
Go for open work, not hidden behind installers (same as official downloads).
Added my own modified profile (set of files), with better support for digital multichannel audio.
Added APO4 offload stream and offload mode effects to analogue interfaces.
The modified profile is not quite perfect, if you enable separate headphones please restart.
One thing I noticed is that the sound sounds better thru headphones at 48000hz at 24bit instead of 96000. Is that normal due to how files are set? The Enable Audio Enhancements is also enabled at 7.1 channels. If i disable it brings sound closer. What is the new features with the latest? 6.0.9116.8 is one I'm using.
Other thing too... not sure if anybody else does this, the levels i use on channels is set around 40-43. Output level is at 80
3,067 (1.99/day)
United Kingdom
Yesterday I also added Ultra to my old AMD GPU, via DisplayPort, see below posts if you need info.
There is also a video below (in my signature), from last week.
If I play 360 Dolby or DTS over SPDIF, its like I have extra virtual speakers with defined positioning.
My Z906 always sounded good, but never fully 360, well that changed.
33 (0.01/day)
Yesterday I also added Ultra to my old AMD GPU, via DisplayPort, DM if you need info.
Thanks @Ferather , i will test it today.
Unfortunately it still didn't work on my notebook.
139 (0.09/day)
Case Zalman case
Mouse USB NGS
3,067 (1.99/day)
United Kingdom
Sorry nothing I can do about it, I have tried now for days. I guess you will have to wait for another driver pack.
The only thing I could try, is if you sent me a link to working drivers, and I add it to that.
This being said this will cost me time and effort, just so you know.
Just diagnosed a friend with ALC892 with exact same problem, now its working. I will write a guide shortly.
The problem was other drivers, previously installed, and apps used to remove drivers.
DTS DCH 6.0.9116.1 is a driver fully written by myself (except the base files that come Realtek), with no other direct influence on any code or time spent by third party sources.
Main directory: https://www.mediafire.com/folder/9yrokjhyh2slx/DTS_DCH_Drivers (note, the Ferather preset is different to the one installed).
Alternative link: DTS DCH 6.0.9116.1.7z - Anonymous Files (no tracking, logs, and so on, https://anonymousfiles.io/).
How to cleanly install DTS DCH 6.0.9116.1 (don't skip steps), turn off your internet - unplug the cable or turn off wifi. DO NOT use third party software to skip steps.
If you have used my drivers previously, you will need to delete any files in 'C:\Windows\System32\DTS' after uninstalling the device.
This issue has been fixed in the current release, and you will not need to take any additional steps in the future.
First uninstall all Realtek, AAF, DTS or other installations from 'Apps & features'. Then restart your computer (it will probably ask you to restart).
Then in 'Device Manager', check for 'Microsoft Audio Device', If it still says 'Realtek' or 'AAF DCH Optimus Sound', you might have an issue.
Right click the device and select 'Uninstall', then tick 'delete driver', and restart your computer, repeat until the above.*
If you don't see 'Microsoft Audio Device', you need to repeat the process until you do.
Now open 'Command Prompt' as admin (note, you can select screen text, and press ctrl+c to copy, and right mouse to paste):
Type the following command: pnputil -e , this will display all installed drivers, look through the vendor, device and signer list, copy the oemX.inf name.
Now type the following command: pnputil -d oemX.inf , this will delete the driver, however it must not be in use (uninstalled).
If a driver fails to remove, uninstall the 'Microsoft Audio Device', do not restart, and try again (it will now).
Make sure to remove everything related to your Realtek, including past installs.
Now run a registry cleaner (CCleaner) 2-3 times, and restart.
In some cases, active third party audio software can cause bugs with registry entries, example Viper, I have only tested Equaliser APO (E-APO).
Double click install, wait for Windows to tell you to restart, wait 5-10 seconds then restart. Read the proved Readme.txt, now configure your sound setup.
If you are using the APO3 entry (ModeFX), please remove it when not needed, in order to use Ultra and other effects.
Inside the folder 'WIN10\APPS\UWP_Store\' you will find two .inf files, right click and install these to get Headphones:X v1 (APO3) and DTS:X Ultra (APO4).
DTS Headphones:X (v1) - https://www.microsoft.com/en-us/p/dts-headphone-x-v1/9pfndb3vh40p?activetab=pivot:overviewtab
DTS:X Ultra - https://www.microsoft.com/en-us/p/dts-x-ultra/9n0h1m8j1308?activetab=pivot:overviewtab
Fully functioning 6 channel balance for SPDIF, digital optical in this case.
When in multichannel mode (4, 5.1, 7.1), Ultra will use a multichannel preset, for 4+ speaker and effects.
If you require additional effects either use the Realtek Audio Console, or E-APO (ignore digital format).
If you need the old DTS Connect system, follow the Readme.txt for the property key.
I recycled the above screenshot, I'm lazy at times.
How do I get Ultra on my HDMI-DisplayPort GPU?
You have the Ultra mod working on your Realtek device? Open the provided tool: RTK APO Tool, at the top select the HDMI device.
Input the following, and press only write, NOT write default (will make it permanent), you can reset if needed.
Stream: {07531B73-E4CA-4B94-9D0E-D3C9A7825FE5}
Mode: {FCDD3010-BB3F-4B24-8074-A18FC7D558F7}
Endpoint: {599C2638-CC15-4FFE-B16A-9246260D2DF7}
Now restart the 'Windows Audio' service, or restart your computer.
You can also try and add-unlock features (perhaps your device supports DTS UltraPC II) use the provided 'RTK Device Tool'.
If you make a mistake copy 'RTKHDAUD.dat' from the drivers to C:\Windows\System32\drivers.
Don't press the flashing text, it will delete the config file.
In some cases you may need additional files.
Make you store E-APO's key in case you need to change it at a later date.
Stream Effect Clsid: {EACD2258-FCAC-4FF4-B36D-419E924A6D79}
If you want the DTS APO1, you will need to remove the E-APO line.
Note: DTS APO1 doesn't support WASAPI shared mode.
Below is an additional tool (cleaned), which contains 'Effect CLSID's.txt'.
  • FX Configurator.zip
42 (0.02/day)
Burgas, Bulgaria
DTS Ultra only work with internet connection off and don't working anymore and after restart same
3,067 (1.99/day)
United Kingdom
It does seem more subtle with internet, I can remove the online database in the next update (built into Ultra).
You can also try copying 'dts_apo4_oem_config_10251435', edit it, then transfer back.
File location for the .xml: C:\Windows\System32\DTS\PC\APO4x
Restart the APO4 service using 'Task Manager'.
42 (0.02/day)
Burgas, Bulgaria
I restarted again without turning on the internet and works Screenshot 2021-03-14 160122.png
but after open internet :(
3,067 (1.99/day)
United Kingdom
See my post above, remove (I am using 7z as admin to directly edit the file):
<control name="Database File Name">offlinedatabase_ui_AcerGaming2020.db</control>
I hope that works for you, I can edit the next update if required.
3,067 (1.99/day)
United Kingdom
No idea, still he can try the guide for HDMI and APO keys but to his speakers, should make the app more aggressive.
Bruhimnoob
18 (0.01/day)
Hello brothers, i just wanted to say thank you for all the hardwork you put into these mods but somehow im not able to install dts ultra.Sorry to trouble you but i dont know much about driver modding i just test the different drivers and do basic troubleshooting. i have used equaliser apo with hesuvi and that worked very well is there any way i can use hesuvi with this mod with virtual audio cable and voicemeeter
3,067 (1.99/day)
United Kingdom
https://www.techpowerup.com/forums/threads/aaf-realtek-dch-audio-driver-dts.277711/post-4477750
Ignore the alternative link, if you want to try it, I have changed the codes. You may need to switch between 5.1 and stereo after installing, just 1 time.
I suggest uninstalling the Ultra app, so it also starts new. If this version does not work for you, you are doomed :(
Please read the provided readme and uninstall-install guide.
If everything is working but you get 'Connect speakers' enter the following keys using 'RTK APO Tool'.
Restart your computer and try again, you may need to switch it to 5.1 (not stereo), then back.
You can also use E-APO with the above changes, it will use the existing APO (Ultra).
I think I found a better way to implement the SFX/MFX for ultra so no apps are needed to setup the ALC (Realtek).
Notes: The driver I am using as a source for Ultra is for ALC887, I have an ALC889, its possible I have better compatibility, and the reason it already works for me.
Unfortunately for me and you (updates), its not very possible to add compatibility for devices (ALC) I dont own, or have access to.
The last week or so of updates have been for everyone else, and I am still to receive any additional help with codes etc.
It looks like the Ultra interface works in a similar fashion to virtual cable, rather than directly on the device.
3,067 (1.99/day)
United Kingdom
Sorry to hear that, I did try for you. I did just upload my very final edit, but I dont think it will help you. Sometimes if a device goes wonky (or I get noise with audio) I reset it, without re-installing.
This might help, but I doubt it, go to 'Device Manager' and in the system section look for audio device, and disable it, then restart, then run Device Remover, then re-enable.
Also what Realtek ALC do you have, and what's the motherboard? This really suck because I am the first to have DTS:X Ultra multichannel over SPDIF and HDMI.
  • Device Remover.exe
34 (0.02/day)
Not sure what i did wrong to make it go into Windows Repair. It first showed at the bottom but then went to Repair screen once it restarted.
Deleted member 193792
Guys I plan to format my PC and perform a new Win10 installation.
All I want from the Realtek audio driver is the ability to have 5.1 audio over SPDIF in games that support surround audio. The vanilla/MSI driver does not allow that, AFAIK.
I have this mobo (ALC 892): https://www.msi.com/Motherboard/X470-GAMING-PRO-MAX
I have already bought legally from the MS store both Dolby Atmos and DTS Headphone:X, so I don't need cracked apps. Just the pure audio driver with no frills.
Can someone guide me what to do exactly? Also, I don't understand all this new terminology (APO, UAD etc.), so I would appreciate an ELI5.
Thanks in advance! :)
@Hearick do you mean @alanfox2000 APO Driver? It has like 4-5 viruses. GitHub removed for a reason. @Alan Finotty has a "ping checker" in his shit, that connects to his GitHub every hour. This is worrisome. Just FYI.
What? Is this true?!
34 (0.02/day)
Where i use to do stuff with PAX XFi and the changes in sound, i have to wonder if Realtek will accept ini files with configurations like ones used for Bass.ini, Mid.ini, Treble.ini and even Tweaks.ini, etc but for Realtek.
3,067 (1.99/day)
United Kingdom
Not 100% sure about Finotty, but his take over video and enable dev mode makes me wonder *, alanfox2000 content nearly always contains malware, trojans etc, some can be excused by the patcher.
However the thing is, you then ignore thinking its just the patcher or because the app is special, that's because it is special. It contains a variety of bad things.
On a separate note, you can try my driver, if you don't want Ultra don't install it, read the Readme.txt file, you can download my config below.
* It possible he needs to clean-up mistakes made in the registry and so on, and require more permission, legitimately.
Not 100% sure about Finotty, but his take over video and enable dev mode makes me wonder, alanfox2000 content nearly always contains malware, trojans etc, some can be excused by the patcher.
What's the difference between DTS:X Ultra and DTS:X Headphones? Is it the same thing (3D audio for headphones)?
ALC892 is compatible with your drivers? I've read some issues.
Also, is Dolby missing because it's lower quality compared to DTS?
3,067 (1.99/day)
United Kingdom
It supports multichannel. The stereo portion seems to be the bit some people are having issues with. My ALC889 works fully, but other ALC's maybe not.
2 channel audio > E-APO 2 channel clone to 6-8 channel > DTS:X Ultra multichannel effects > Audio out.
6-8 channel audio > DTS:X Ultra multichannel effects > Audio out.
Most games and movies should be multichannel.
I have added the relevant code the put DTS in the exclusive section, this way E-APO will use it when you install it.
It will basically create a composite stream fx, with DTS first then E-APO after, preventing issues.
You can also delete or change the key with the provided app.
I will start a new thread soon (with a full guide), as the current release is fully my own coding (with source) and 100% my time spent :)
> Feel free to read through my files, and apply them to another driver (ideally one for your motherboard).
> Please dont ask me questions related to modding your own driver unless you know the codes.
Added a 'DTS Presets and Encoded Videos' folder to the MediaFire main directory for the driver, I suggest downloading the encoded video.
Play all the files over SPDIF (and maybe HDMI), and notice the DTS:X Ultra effects applying, even though encoded.
Enjoy!
Status
