Acer Intros S243HLbmii W-LED Illuminated Display
10,885 (1.55/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
Looks like it was designed by an artichoke.
It doesn't look like it's even height adjustable.
Nice specs. The LED TV's I've seen at BB are good, but not worth the price differential.
Mussels
Freshwater Moderator
58,412 (7.85/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
around here in Au, LED screens are cheaper. 24" cold cathode screens are a few hundred $$ more than 23.6" LED screens
may just be an au thing i guess
1,317 (0.20/day)
New Zealand
Processor AMD Phenom II 555BE unlocked X4 @3.8GHz
Motherboard GA-78LMT-S2P
Cooling Thermaltake Blue Orb + open case in cold room = low temps lol
Memory 8Gb DDR3 1600
Video Card(s) GTX580
Storage 64GB SSD Super Talent
Display(s) 22" Chimei, 17" Philips
Case POS!
Power Supply Cooler Master Silent Pro Gold 800W
not in NZ. mind you, aussie is known for some strange things. dingos stealing babies and stuff
Woody112
562 (0.09/day)
Florida
System Name Woody's MBP
Processor 2.4 C2D
Cooling Frikin Air
Memory Munskin 2x2 gig 1066mhz
Video Card(s) 9400gt/9600gt W/512mb
Storage 1TB WD scorpio blue
Display(s) 15.4" on lapie/ 24" Acer P241w on the wall/ 52" LCD TV
Software OSX/ Win 7
Most people don't realize it but LED's are cheaper. All it is is a diode that emits light, nothing more. Cost pennies to produce. Cold cathode tubes cost nickels to produce. You get the idea, the only thing keeping LED's at the price they are is advertising and the fact that their the new's tec to get on the market. Which always draws a price premium.
Really LED panels are just flat out cheaper to manufacture. Wish I had a patent on them is all.LOL
Wile E
Power User
24,318 (3.62/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
I have a 24" with 2ms and my tv is 42". Side by side, there is absolutely no difference that the human eye can detect at all whatsoever, and if you say you do, it is a lie. The current panels in production are pretty much optimal in that aspect.
Step off to the side slightly, or go above or below the center line on a Tn-Film.
And even if you do happen to be looking at both dead center, if you can't tell the picture quality difference between a Tn-film and a PVA or IPS, then you are blind.
875 (0.15/day)
LED's got three advantages right now
1. cheaper
2. brighter
3. thinner screens
even if it has other flaws swansen (please, list these drawbacks - i'm curious) they have enough good reasons to make them work in the market.
To continue on this :
Another bonus of an led BACKLIGHT is that instead of a solid white plane (as in most modern panels, that results in "glowing" black areas, and hence poor contrast), some manufacturers are now making what is effectively a simple "Black & White" LED backlight screen behind the color screen so that there is only light where there should be (as the backlight screen only displays the brightness pattern of the current frame, instead of displaying the image itself).
Overall this IS a far better idea than just using a plain white backlight, as your image will appear far more balanced, and it helps to expand the effective color tone range of the monitor without having to use more expensive color layers. It's still basically a cheap trick rather than actually producing a proper output medium like OLED, but it can DEFINITELY result in better images.
And before anyone asks what I mean by a "proper" output medium - I mean one where each pixel emits it's OWN light, and there is no backlight at all, rather than the current method whereby all of the pixels are arranged in what is effectively a stained glass window, with a Backlight shining through it from behind.
875 (0.15/day)
Must Agree - there are very noticeable discrepancies, and overall BOTH technologies are quite flawed :\
But they will be replaced eventually.. SED, OLED, some new variant of plasma.. who knows, but the entire concept of a backlight display is a fossil in the making - it will die off soon enough...
1,372 (0.21/day)
Chicago, IL
System Name Stealth 2 Duo Turbine
Processor Intel e6850 @ 3.8ghz
Motherboard Asus Striker Extreme
Cooling CoolerMaster V8 Modded With 2 white LED's & 100CFM fan
Memory OCZ DDR2 1066_ SLI Black-4GB
Video Card(s) 2xMSI 8800GT"s SLI
Storage <<HDD For OS>> 2x150GB_Western Digital Raptor_Raid 0. <<HDD For Storage>> 3 x 1TB
Display(s) ACER B273HU 27" LCD 2048x1152
Case Apex SuperCase_Custom 7 month Build
Audio Device(s) Striker Extreme Add-In Card HD-Audio
Power Supply EnerMax INFINITI 720watt
Software SE7VEN ULTIMATE 64bit
Benchmark Scores 3DMark01=NTTA, 3Dmark06=NTTA 3Dmark_Vantage=NTTA, Core Temp v0.99.5=28C
I was at microcenter today & seen a AOC Led panel,, it was nice looking but seem to have bad color banding. maybe it was the vga hook up, the HDMI wasn't being used.
1,888 (0.32/day)
System Name The Beast
Processor Intel Core i3-2100 @ 3.1GHz
Motherboard Asus P8P67 LE
Cooling Stock
Memory 4GB Corsair Vengeance DDR3 @ 1600MHz
Video Card(s) 1GB Sapphire Radeon HD4650 Ultimate Edition
Storage 60GB Corsair Force LE, 1TB Samsung SpinPoint F1, 500GB Seagate
Display(s) 22" Samsung T220HD & 19" Acer X193W
Case Corsair Obsidian 750D
Power Supply Corsair HX650W
Hmm, €240, not bad. I dig flat/slim bezels, they have a sleeker look. I agree with the speaker thing, maybe release a cheaper version that doesn't have them, I'm in the market for a 23/24" monitor, the Acer 16:9 one is €149 but I don't really like the looks of it :S nothing else in the price range though :(
2,270 (0.39/day)
the uk that's all you need to know ;)
System Name not very good (wants throwing out window most of time)
Processor xp3000@ 2.17ghz pile of sh** /i7 920 DO on air for now
Motherboard msi kt6 delta oap /gigabyte x58 ud7 (rev1.0)
Cooling 1 green akasa 8cm(rear) 1 multicoloured akasa(hd) 1 12 cm (intake) 1 9cm with circuit from old psu
Memory 1.25 gb kingston hyperx @333mhz/ 3gb corsair dominator xmp 1600mhz
Video Card(s) (agp) hd3850 not bad not really suitable for mobo n processor/ gb hd5870
Storage wd 320gb + samsung 320 gig + wd 1tb 6gb/s
Display(s) compaq mv720
Case thermaltake XaserIII skull / coolermaster cm 690II
Power Supply corsair hx 650 w which solved many problems (blew up) /850w corsair
Software xp pro sp3/ ? win 7 ultimate (32 bit)
Benchmark Scores 6543 3d mark05 ye ye not good but look at the processor /uknown as still not benched
1. cheaper
2. brighter
3. thinner screens
yes and they're less likely to short out like ccfl's are ,
i never have understood this bizaare obsesion cclf manufacturers have making them without heatsinks on the output transistors makes no sense :wtf::shadedshu
1,334 (0.23/day)
1. cheaper
2. brighter
3. thinner screens
1. Cheaper to make but don't sell cheaper = they make more money.
2. People don't want to burn their eyes. I have my monitor brightness at 37%.
3. Not really. The mixing and diffusion of light requires the screen to be reasonably thick. But LED drivers are much smaller so you do have a point here.
16:09 monitors are almost always cheaper than 16:10 ones.
Mussels
58,412 (7.85/day)
Oystralia
pr0n: as to point 2, the lowering of the brightness is partly why they'e so power efficent: even if they used the same at 100% brightness, if one screen was at 25% and another at 100%... you know the 25% is going to save some power.
1,334 (0.23/day)
Oh you meant the efficiency. I thought it was about the, you know, the "Now XXX% brighter than old model! And with free puppies!".
Mussels
58,412 (7.85/day)
Oystralia
brighter if you want it, more power efficient if you dont :)
works well, all pluses, no minus
wolf
Better Than Native
8,482 (1.30/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte B650I AX
Cooling Scythe Fuma 2
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
Where in Aus sells LED LCD's?
Mussels
58,412 (7.85/day)
Oystralia
tons of places. pretty much all samsungs use them now.
Easiest way to tell is the contrast figures, mines got a ridiculous number of 50,000:1 dynamic and 1,000:1 static - non LED are far lower than that
wolf
Better Than Native
8,482 (1.30/day)
System Name MightyX
VR HMD Meta Quest 3
I've noticed samsung have a nac for making a kickass stand that comes with most monitors, swivel, height the lot, waaaay better than my current flimsy benq.
Still, right now I have a 28", a 24" a 19" and a 15" and no job, I'm not sure I can justify another :rolleyes:
