- Dec 26, 2006
- 3,977 (0.60/day)
- Northern Ontario Canada
Processor | Ryzen 5700x |
Motherboard | Gigabyte X570S Aero G R1.1 BiosF5g |
Cooling | Noctua NH-C12P SE14 w/ NF-A15 HS-PWM Fan 1500rpm |
Memory | Micron DDR4-3200 2x32GB D.S. D.R. (CT2K32G4DFD832A) |
Video Card(s) | AMD RX 6800 - Asus Tuf |
Storage | Kingston KC3000 1TB & 2TB & 4TB Corsair MP600 Pro LPX |
Display(s) | LG 27UL550-W (27" 4k) |
Case | Be Quiet Pure Base 600 (no window) |
Audio Device(s) | Realtek ALC1220-VB |
Power Supply | SuperFlower Leadex V Gold Pro 850W ATX Ver2.52 |
Mouse | Mionix Naos Pro |
Keyboard | Corsair Strafe with browns |
Software | W10 22H2 Pro x64 |
During construction so does nuclear. There is a lot of concrete and steel in a nuclear plant and supporting infrastructure and a large amount of land used up. A lot of hydro is run of river so not much in the way of a headpond or flooding. Hydro station life is typically 3x that of a nuclear facility as well. But like you said for large continuous MW output nuclear is king…..well we used to have coal plants that could put out the same if you had the coal to do so.In operation hydro is cleanest, pronto. During construction, though, it generates A LOT of CO2 (and other gasses) when flooding their reservoirs if deforestation isn't correctly done, and it causes a lot of other environmental issues as well. And I say that while working at the most successful hydro plant in the world.
Solar and wind-powered generation also occupy too much area for the power they actually generate, and there's also an environmental hit for the production of their equipment and the area they're installed. So all things considered, I say nuclear is the cleanest (and also the most regular throughput) generation available.
