- May 8, 2021
- 1,978 (1.30/day)
- Lithuania
System Name | Shizuka |
Processor | Intel Core i5 10400F |
Motherboard | Gigabyte B460M Aorus Pro |
Cooling | Scythe Choten |
Memory | 2x8GB G.Skill Aegis 2666 MHz |
Video Card(s) | PowerColor Red Dragon V2 RX 580 8GB ~100 watts in Wattman |
Storage | 512GB WD Blue + 256GB WD Green + 4TH Toshiba X300 |
Display(s) | BenQ BL2420PT |
Case | Cooler Master Silencio S400 |
Audio Device(s) | Topping D10 + AIWA NSX-V70 |
Power Supply | Chieftec A90 550W (GDP-550C) |
Mouse | Steel Series Rival 100 |
Keyboard | Hama SL 570 |
Software | Windows 10 Enterprise |
As far as I understand this is the formula of fan airflow:
air moved = rpms*volume of air that fan blades catch per revolution*static pressure of fan
It seems that fan static pressure and airflow is very similar to car engine's horsepower, revs and torque. So static pressure in fan is like torque in car and horsepower in car is like airflow in fan. Since fans usually aren't made thicker and most common size of them is 120mm, a hypothetical fan that runs at 1400 rpm, but one is made to be optimized for air flow and other is made to static pressure. That happens if you change blades. However, to achieve higher pressure, some cfm has to be sacrificed, therefore fan is able to provide lower level of air flow, but through more obstructions, meanwhile airflow optimized fan is overall better performing in terms of cfm (and probably in terms of noise, since pressure fans have heavier blades and they vibrate more when spinning), however such fan in theory shouldn't cope well with obstructions. However, from as much as I have observed, a fan blades don't really affect fan performance much. I'm starting to think that higher static pressure fans may have only slightly higher static pressure (makes sense, since a fan isn't a good air pump, due to gaps and due to looking nothing like a proper Archimedes screw) and thus in many practical scenarios higher static pressure just simply fail to deliver any proper advantage over basic airflow optimized fan. Meanwhile air flow fans pretty much always generate enough pressure, so there's no need for any special design. Are these observations true or not?
Side note:
it seems that static pressure optimized fans have a much better laminar flow:
See? Nidec has pretty much ideal straight laminar flow, instead of very turbulent and not straight flow of typical fan, which yo can see here (certainly not the best video, but I have seen that stuff somewhere else, it's just so hard to find such stuff again):
Also I have some generic 7 blades and with hand I can feel that air mostly flows from blade edge and flow isn't straight, but but it is like 25 degrees sideways. Not all of it isn't straight, but a good portion of it. Anyway, I have no idea if laminar flow is preferred and is any better than turbulent flow, as far as I know from car aerodynamics, laminar should be better, but since computer fan isn't pushing out air at high speed, it probably doesn't matter much.
Side note:
