System Name | [H]arbringer |
Processor | 4x 61XX ES @3.5Ghz (48cores) |
Motherboard | SM GL |
Cooling | 3x xspc rx360, rx240, 4x DT G34 snipers, D5 pump. |
Memory | 16x gskill DDR3 1600 cas6 2gb |
Video Card(s) | blah bigadv folder no gfx needed |
Storage | 32GB Sammy SSD |
Display(s) | headless |
Case | Xigmatek Elysium (whats left of it) |
Audio Device(s) | yawn |
Power Supply | Antec 1200w HCP |
Software | Ubuntu 10.10 |
Benchmark Scores | http://valid.canardpc.com/show_oc.php?id=1780855 http://www.hwbot.org/submission/2158678 http://ww |
Uhm, no, that's the blue outline between the chips...
But it might well be between cards as well.
System Name | Compy 386 |
Processor | 7800X3D |
Motherboard | Asus |
Cooling | Air for now..... |
Memory | 64 GB DDR5 6400Mhz |
Video Card(s) | 7900XTX 310 Merc |
Storage | Samsung 990 2TB, 2 SP 2TB SSDs, 24TB Enterprise drives |
Display(s) | 55" Samsung 4K HDR |
Audio Device(s) | ATI HDMI |
Mouse | Logitech MX518 |
Keyboard | Razer |
Software | A lot. |
Benchmark Scores | Its fast. Enough. |
Processor | Intel Core i5 4590 |
Motherboard | Gigabyte Z97x Gaming 3 |
Cooling | Intel Stock Cooler |
Memory | 8GiB(2x4GiB) DDR3-1600 [800MHz] |
Video Card(s) | XFX RX 560D 4GiB |
Storage | Transcend SSD370S 128GB; Toshiba DT01ACA100 1TB HDD |
Display(s) | Samsung S20D300 20" 768p TN |
Case | Cooler Master MasterBox E501L |
Audio Device(s) | Realtek ALC1150 |
Power Supply | Corsair VS450 |
Mouse | A4Tech N-70FX |
Software | Windows 10 Pro |
Benchmark Scores | BaseMark GPU : 250 Point in HD 4600 |
Those were gaming cards. New Pro Duo Vega II is a workstation card.this sounds like the successor of the beastly R9 295 X2 GPU & HD7990. Kinda sad this is a specific card for Apple "PC"....
Processor | 5930K |
Motherboard | MSI X99 SLI |
Cooling | WATER |
Memory | 16GB DDR4 2132 |
Video Card(s) | EVGAY 2070 SUPER |
Storage | SEVERAL SSD"S |
Display(s) | Catleap/Yamakasi 2560X1440 |
Case | D Frame MINI drilled out |
Audio Device(s) | onboard |
Power Supply | Corsair TX750 |
Mouse | DEATH ADDER |
Keyboard | Razer Black Widow Tournament |
Software | W10HB |
Benchmark Scores | PhIlLyChEeSeStEaK |
Dual GPU. Now that is a squeaker. I thought AMD would never go dual GPU. Infinity fabric between chips. Hmm wonder how that is going to pan out. Although it is an HBM2 so I wonder what the delay would be since Ryzen had some latency. Especially the 1st gen. Hope the GPU can avoid such a delay.
I assume this is only for MAC and we are not talking about PC alternative of the same GPU?
I don't want to know the noise levels.
System Name | Budget Box |
Processor | Xeon E5-2667v2 |
Motherboard | ASUS P9X79 Pro |
Cooling | Some cheap tower cooler, I dunno |
Memory | 32GB 1866-DDR3 ECC |
Video Card(s) | XFX RX 5600XT |
Storage | WD NVME 1GB |
Display(s) | ASUS Pro Art 27" |
Case | Antec P7 Neo |
For at least 5 years, the “pros” on the Apple size have felt pretty neglected, maybe longer since many didn’t care for the trash can design. This is the first real move of confidence for those users. Users can actually configure this MP, though I’m curious to see what sort of expansion there truly is. Will it be possible to add a third party GPU? Not just be detected by MacOS, but also have the necessary power cables to drive it.8K video rendering. It's here and apple knows the sooner they offer it and make it available the sooner they will have a need for a uber $$$$$ 8K display.
Sow the seeds, reap the reward, Apple is expanding it's roots again into content creation focused growth. About time, cause like it or not us PC plebes have benefitted from the drive for better monitors.
Please no, we don't need a repeat of EISA slots that were as long as the motherboard is wide. The issue is with 12V, what is needed is for the industry to migrate to higher multiples of that (24V, 36V) to bring down the high amperages and thick traces and cables necessitated by such a low voltage. High amperage is also far more dangerous than high voltage.
System Name | Firelance. |
Processor | Threadripper 3960X |
Motherboard | ROG Strix TRX40-E Gaming |
Cooling | IceGem 360 + 6x Arctic Cooling P12 |
Memory | 8x 16GB Patriot Viper DDR4-3200 CL16 |
Video Card(s) | MSI GeForce RTX 4060 Ti Ventus 2X OC |
Storage | 2TB WD SN850X (boot), 4TB Crucial P3 (data) |
Display(s) | 3x AOC Q32E2N (32" 2560x1440 75Hz) |
Case | Enthoo Pro II Server Edition (Closed Panel) + 6 fans |
Power Supply | Fractal Design Ion+ 2 Platinum 760W |
Mouse | Logitech G602 |
Keyboard | Logitech G613 |
Software | Windows 10 Professional x64 |
I do love Apple’s internal design cleanness. This thing could just as easily have a glass shell.
System Name | Bro2 |
Processor | Ryzen 5800X |
Motherboard | Gigabyte X570 Aorus Elite |
Cooling | Corsair h115i pro rgb |
Memory | 32GB G.Skill Flare X 3200 CL14 @3800Mhz CL16 |
Video Card(s) | Powercolor 6900 XT Red Devil 1.1v@2400Mhz |
Storage | M.2 Samsung 970 Evo Plus 500MB/ Samsung 860 Evo 1TB |
Display(s) | LG 27UD69 UHD / LG 27GN950 |
Case | Fractal Design G |
Audio Device(s) | Realtec 5.1 |
Power Supply | Seasonic 750W GOLD |
Mouse | Logitech G402 |
Keyboard | Logitech slim |
Software | Windows 10 64 bit |
I know AMD history and they were using handful of dual GPU always. Now they are releasing quite a number. Anyway this doesn't change the fact they were not going dual GPU for gaming. They are using Infinity Fabric for the communication and that's interesting. It's like AMD's trying to squeeze more juice from the GPU and I think that's a good thing. First step for dual chips in gaming. That's my assumption but I think they can pull this one off.If you knew AMD history you would know they have always used dual gpus.
Or it might perform slightly worse but it is twice as cheap and very good across the workstation suite workloadWow, 2 pages and no Crysis comment?
I hope this means AMD is ready to give NVIDIA some meaningful competition. It must perform better than NVIDIA's tensor cores if Apple picked it for their HEDT, granted it's using twice as many GPUs to do so.
System Name | M3401 notebook |
Processor | 5600H |
Motherboard | NA |
Memory | 16GB |
Video Card(s) | 3050 |
Storage | 500GB SSD |
Display(s) | 14" OLED screen of the laptop |
Software | Windows 10 |
Benchmark Scores | 3050 scores good 15-20% lower than average, despite ASUS's claims that it has uber cooling. |
Because tensor cores are the only reasonable metric one has when weighing performance of 28 TFlop GPUs.I hope this means AMD is ready to give NVIDIA some meaningful competition. It must perform better than NVIDIA's tensor cores if Apple picked it for their HEDT, granted it's using twice as many GPUs to do so.
A pity you can't rant about lack of heavily denoised RT gimmick.
Actually it is 28.4 single precision and double that for half precision for the Radeon Pro Vega II duo. That's what it says on the Apple page. The only thing worth mentioning is that this card is dual chip. What's also worth mentioning, you can double single precision by adding another Vega II duo. So if you ask me it's pretty impressive14 TFLOPS according to AMDs slideshow, which isn't exactly 28 TFLOPS because of bandwidth limitations between the two cards but even assuming 100% efficiency you're drag racing against NVIDIA's 16.3 TFLOPS on a single GPU card, which is significantly higher.
Believe me, I'm not a fanboy, I want AMD to succeed so I can get excited about product launches from both sides of the aisle instead of the one-sided progression we've had for years, but I'm also a realist, and tech marketing doesn't affect me anymore than a late night infomercial for pillows, so without real-world testing it's hard to say.
BUT
Apple DOES have product access, and has assumingly tested it thoroughly, and didn't decide to base their platform around it on a whim. That gives hope.
