AMD FX Sets Guinness Record for Clock Speed
19,374 (3.53/day)
Well now that you don't have to have all cores enable to get the WR...
Maybe all the guys that do heavy overclocking should go back to it & use only one core on the cpu (mostly on AMD side)...
Me think i could probably do 5ghz on air with only 1 core enable , hmmm!... :rolleyes:
Now? Its always been that way (well since multi cores were out). When shooting for highest clocks you should always disable cores.
HTC
4,664 (0.76/day)
Portugal
System Name HTC's System
Processor Ryzen 5 5800X3D
Motherboard Asrock Taichi X370
Cooling NH-C14, with the AM4 mounting kit
Memory G.Skill Kit 16GB DDR4 F4 - 3200 C16D - 16 GTZB
Video Card(s) Sapphire Pulse 6600 8 GB
Storage 1 Samsung NVMe 960 EVO 250 GB + 1 3.5" Seagate IronWolf Pro 6TB 7200RPM 256MB SATA III
Display(s) LG 27UD58
Case Fractal Design Define R6 USB-C
Power Supply Corsair TX 850M 80+ Gold
Mouse Razer Deathadder Elite
Software Ubuntu 20.04.6 LTS
Let me quote hipro5 from XS:
Well yes - you read it well!...... :D
An EASY way to KILL your i7 980X cpu is VERY SIMPLE... :D and :(
IF your cpu sucks under LN2 or so, an EASY way to kill it is the following:
Power up you mobo (it doesn't matter what mobo you have)
Go into cpu features
Disable Hyper Threading.
Select 2 Cores for slow die
OR
Select 1 Core for FAST die
Save and exit and.........you're ready - No overclock no nothing - :mad:
Here's my story:
I had a decent i7 980 Cpu, benching Vantage ~5900MHz
I putted on the GIGABYTE UD7 mobo
I was playing OK UNTIL I tested the Super-Pi 1M
Disable HT
Test 1M
Disable 4 cores and I left only the 2 of them
Playing 1M OK
Playing and fooling around with 2 cores for a couple of sessions
OK
ENABLE ALL cores and HT
NO Windows at 5800MHz which was EASY before
NO Windows at 5600MHz
NO Windows at 5400MHz
NO Windows at 4000MHz
Booted into Windows with full cores and HT at DEFAULTS = NO GO
I said f(l)uck!...The cpu degraded THAT FAST.... :(
NO
Another Cpu on EVGA
Decent one too
Playing, testing it and fooling around with full cores and HT and LN2 = OK
Next day I had no LN2 to play with so I did some testing on air with DEFAULT EVERYTHING
Testing Super-Pi with 2 cores = OK
I then go into bios and pick ONLY ONE CPU Core with No HT.
Save and exit.
Boots and freezes
Pressing Reset
NO BOOT
CPU = DEAD!.... :mad:
I then call to a friend of mine who is on air and he doesn't Overclock at all.
I go to him
Get into bios and disable HT and pick one core
Did you do it?
Yes?
OK - Now save and exit -
OK
George it doesn't booting!.... :eek:
I go - clear c-mos and retry.
George no go, what happened? you killed my cpu?
Am I at your home? How could I kill your cpu?..... :D
SHI(f)t!!!
So if Intel hasn't predicted such behaviours, RMA THE BIATCHES guys..... :mad: ;)
DEFAULT with ONE core enable and no HT = DEAD.....
RMA - Period
I suggest to the motherboard manufactures to leave into their bioses ONLY the option of the Hyper Threading and REMOVE the option form the core's selectance with a bios update. :(
And this is why they stopped searching single thread frequency records for 980x and such.
On topic: congratz AMD for a new frequency record :toast:
Here's to hoping performance comes along with frequency: frequency without performance isn't much to hope for, IMO.
19,374 (3.53/day)
Way to find the exception to the rule! That was a known problem with gulftowns. Too bad nobody in their right mind would shoot for a CPUz record with one of those in the first place. ;)
cadaveca
My name is Dave
17,232 (2.52/day)
Right, that's why HiPro and others were killing them.:laugh:
:slap:
I stayed far away from 6-core iNTEL CPUs because of that thread...
19,374 (3.53/day)
Well, as you should have been able to see from that thread, they were trying to rock single threaded benchmarks, not CPUz...and of course after this was confirmed that all stopped...though some of those were good for 7Ghz+ which is more than we can say for a lot of CPU's. :p
cadaveca
My name is Dave
17,232 (2.52/day)
Sure. But it does say something very interesting about how AMD deals with disabled cores, if they are pushing so much wattage through them.
19,374 (3.53/day)
That, my mousey friend (your avi), is well above my head on how the architecture works inside the silicon. But you are correct. :)
I just wonder (and this is bet for another thread at possibly another site) why that only happened with Gulftown... 32nm process? Not sure thats it as my 25/2600k works fine down to 1c/2c...
cadaveca
My name is Dave
17,232 (2.52/day)
6-core INtel chips are 32nm, like SB. I seem to recall something about current run-off.
Can the 6-cores adjust core speed independantly? Pretty AMD's can.
I mean, as already stated, keeping that 8 GHz+ frequency stable is a big thing, just kind of a useless thing for me personally. My reviews won't cover stuff like that.
cdawall
where the hell are my stars
27,680 (4.11/day)
Houston
System Name All the cores
Processor 2990WX
Motherboard Asrock X399M
Cooling CPU-XSPC RayStorm Neo, 2x240mm+360mm, D5PWM+140mL, GPU-2x360mm, 2xbyski, D4+D5+100mL
Memory 4x16GB G.Skill 3600
Video Card(s) (2) EVGA SC BLACK 1080Ti's
Storage 2x Samsung SM951 512GB, Samsung PM961 512GB
Display(s) Dell UP2414Q 3840X2160@60hz
Case Caselabs Mercury S5+pedestal
Power Supply Seasonic Prime 1200w
Mouse Thermaltake Theron, Steam controller
Keyboard Keychron K8
Software W10P
Ok lets start this then .
1. Higher IPC + We do not know how this performs in real world applications .
2. More cores , Ok it has 8 cores ( That is a start . ) .
3. It clocks like a mother Trucker . On One core ( or was it 2 cores ) Never the less NOT on ALL 8 cores for sure !
4. Just how is this going to help me in making a logical sensible buy on a product ?
5. They broke the world record . That is awesome ! Great job .
Am I flame baiting or thread crapping ? Or are you being a tad bit too over the top ? I want more information but it just ekks out of AMD . And I think that all the Fluff is not going to make me change my mind about this BD chip . I want more than a world record holding over clock chip .
Actually we do know how higer IPC works in the real world. Conroe vs K8, conroe had a higher IPC and outperformed at lower clocks, K8 vs netburst opposite of K8 vs conroe, netburst vs mobile P3 based P4 the mobiles performed better with a higher IPC, K10 vs sandybride again higher IPC lower clocks better performance. So if we were to extrapolate said common knowledge hmmm I wonder if higher IPC makes a difference. There are plenty of clockers that disable cores including all of the high amd clocks as it stands the most anyone has really seen with all 6 or all 4 cores going on ANY manuf's chip is in the mid/high 6ghz. this is not designed to make YOU buy this chip it is to increase awarness and basically be a PR stunt before release.
19,374 (3.53/day)
Right, but SB doesnt have this issue, so its not the process... I do not believe gulftown can do that, no.
Our reviews do... sort of. We arent as standardized as you all are, so it depends on the reviewer. We ALL overclock, some brink overclock on water, others brink overclock on LN2 for theirs. But again our user/reader base is a bit more geared towards overclocking.
trickson
OH, I have such a headache
7,595 (1.04/day)
Planet Earth.
System Name Ryzen TUF.
Processor AMD Ryzen7 3700X
Motherboard Asus TUF X570 Gaming Plus
Cooling Noctua
Memory Gskill RipJaws 3466MHz
Video Card(s) Asus TUF 1650 Super Clocked.
Storage CB 1T M.2 Drive.
Display(s) 73" Soney 4K.
Case Antech LanAir Pro.
Audio Device(s) Denon AVR-S750H
Power Supply Corsair TX750
Mouse Optical
Keyboard K120 Logitech
Software Windows 10 64 bit Home OEM
I get the ICP stuff I know that with more there will be more performance , Thing is Just how MUCH more will it have over the SB ? THAT IS THE QUESTION ! All AMD can do is stupid stunts and give out useless crap on there chips at this time . This is all I am saying . :shadedshu
cdawall
27,680 (4.11/day)
Houston
Processor 2990WX
Software W10P
How is it a stupid stunt they took some of the best AMD clockers handed them a handful of new cpu's and they set a WR. Thats not a stunt thats a PR win.
trickson
7,595 (1.04/day)
Planet Earth.
Cooling Noctua
Mouse Optical
I guess your right , It will go good with this . And means about as much . But it is a great thing to see done . Congratulations AMD ! A job well done indeed . :rockout:
cdawall
27,680 (4.11/day)
Houston
Processor 2990WX
Software W10P
I mean its not like its the first high end cpu to break the top 10 fastest chips or anything :laugh:
trickson
7,595 (1.04/day)
Planet Earth.
Cooling Noctua
Mouse Optical
3,688 (0.59/day)
Ohio
System Name Felix777
Processor Core i5-3570k@stock
Motherboard Biostar H61
Memory 8gb
Video Card(s) XFX RX 470
Storage WD 500GB BLK
Display(s) Acer p236h bd
Case Haf 912
Power Supply Rosewill CAPSTONE 450watt
Software Win 10 x64
i think its awesome. its the beginning of a new architecture. Few more family releases of it and i wonder how far it'll take AMD. My hopes and expectations are high.
12,036 (1.72/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
Interesting that chew says its a 4 core 8 threaded CPU. If that truly is the case (or at least how AMD plays it if the market allows) they will be killing Intel on IPC.
cadaveca
My name is Dave
17,232 (2.52/day)
In some situations, yes, it is just a quadcore.
:banghead:
In fact, it IS just four MODULES. But the OS recognizes each module as 2 cores, like Intel's HT, but it's so much more than just HT, they have to make that distinction somehow.
:ohwell:
For most instances, I think, for most users, it'll effectively be a 8-core CPU.
But it's still just a quad. Module. But quad.:wtf:
:D
1,539 (0.27/day)
Canada/Québec/Montreal
System Name Main PC
Processor PII 925 x4 @3.724GHz (266x14) 1.525v NB 2660 1.425v
Motherboard Gigabyte AM3 GA-890XA-UD3 (790x+SB850)
Cooling Scythe Mugen 2 rev.B
Memory Hyperx 8GB (2x4) 1600@1418 8-7-7-20-27-1t
Video Card(s) GTX 680
Storage 256GB SSD / 2TB HDD
Display(s) LCD Samsung 24" 16:9
Case Cooler Master HAF 912
Audio Device(s) On-Board HD
Power Supply CM 750w GX |3.3v@25a|5v@25a|12v@60a
Software Kubuntu dual boot /Windows 7 Ultimate 64bit
Benchmark Scores later...
Don't think. Do.
You didn't notice... i was sarcastic ;)
Well all CPU-z scores on HWBot are all full cores enable except for Celeron & P4 which are single core CPU , anyway Celeron still/was single core cpu... as far as i know
:banghead:
:ohwell:
:D
You'll still get 8 threads ;)
Also i wonder if we're going to see some 4-6 cores FX unlock in to 8 cores FX?
That would be so cool...:rockout:
19,374 (3.53/day)
All. Hardly.
Most any CPU with HT, at minimum HT is disabled, in a lot, cores are disabled. This is the best way to achieve the highest clocks. If someone didnt disable HT and some cores, they likely havent maxed out their CPU. Its the way it is and there isnt any getting around that.
2600k - http://hwbot.org/hardware/processor/core_i7_2600k/
i7 920 - http://hwbot.org/hardware/processor/core_i7_920/
I can go on...and on, but hopefully you get my point.
cdawall
27,680 (4.11/day)
Houston
Processor 2990WX
Software W10P
well all of the P4's on the list have HT disabled since most are P4 631's. the P4 631's on the >8ghz list are very very single core single thread. As is seen here and here.
1,430 (0.29/day)
A frozen turdberg.
System Name Runs Smooth
Processor FX 8350
Motherboard Crosshair V Formula Z
Cooling Corsair H110 with AeroCool Shark 140mm fans
Memory 16GB G-skill Trident X 1866 Cl. 8
Video Card(s) HIS 7970 IceQ X² GHZ Edition
Storage OCZ Vector 256GB SSD & 1Tb piece of crap
Display(s) acer H243H
Case NZXT Phantom 820 matte black
Audio Device(s) Nada
Power Supply NZXT Hale90 V2 850 watt
Software Windows 7 Pro
Benchmark Scores Lesbians are hot!!!
I actually think you might be able to pull it off. I wasn't trying to be a dick or anything, I just wanted to see how close you came.
2,459 (0.39/day)
System Name PC
Processor i7 9700KF
Motherboard MSI Z390 A PRO
Cooling Noctua NH-U14S
Memory 32GB Corsair Vengeance DDR4 3000mhz
Video Card(s) PALIT RTX 4070 Dual 12Gb
Storage 2X Crucial MX500 2TB SSD, Samsung 850 pro 512gb SSD
Display(s) DELL C34H89x 34" Ultrawide
Case Corsair Obsidian 550D
Audio Device(s) Audioengine A5+ Speakers
Power Supply Corsair RM750
Mouse Logitech G403
Software Windows 10 64bit
I nearly came!
1,430 (0.29/day)
A frozen turdberg.
Processor FX 8350
