AMD Radeon RX 480 specifications leaked?
18,584 (2.66/day)
System Name AlderLake
A slide from AMD’s internal presentation has allegedly been leaked.
AMD Radeon RX 480, 5.5 TFLOPs, 8GB 256-bit
The specifications are rather poor in details, but we are told that the RX 480 (it appears this is in fact the official name for this card) has 5.5 TFLOPs single-precision computing power. Card would be equipped with 8GB GDDR5 memory across 256-bit interface.
The card will be powered through single 6-pin power connector, and judging from the chart it will compete with NVIDIA’s GeForce GTX 970 and GTX 980. The 6-pin power connector together with PCI-Express slot can provide 150W of power, which means Polaris 10 will require less than that.
AMD Radeon RX 480 would support DirectX12 with Async Compute capability. RX 480 will also feature DisplayPort 1.4, full HEVC and HDR monitor support.
The 5.5 TFLOPs computing power would indicate that RX 480 has 2304 Stream Processors clocked at 1200 MHz, but this part is pure speculation at this point.
http://videocardz.com/60752/amd-radeon-rx-480-specifications-leaked
1,456 (0.32/day)
Israel
Processor AMD Ryzen 7 5800X
Motherboard B550 Aorus PRO V2
Cooling Corsair H115i RGB Platinum
Memory Gskill Trident Z Neo 3600 2x16GB
Video Card(s) MSI RTX 3070 Trio X
Storage WD Blue SN550 1TB NVME/Teranova 1TB Sata/WD Blue SN580 2TB NVME
Display(s) Dell AW3423DWF
Case Corsair 4000D Airflow
Audio Device(s) Schiit Audio Modi+\Magni+
Power Supply Corsair HX850i
Keyboard SteelSeries Apex Pro
It's a little awkward that they to compare to some of Nvidia last gen GPU's, but i suppose it only makes sense since the next gen offerings from both sides are targeted at different market segments.
crazyeyesreaper
Not a Moderator
9,820 (1.69/day)
System Name Old reliable
Processor Intel 8700K @ 4.8 GHz
Motherboard MSI Z370 Gaming Pro Carbon AC
Cooling Custom Water
Memory 32 GB Crucial Ballistix 3666 MHz
Video Card(s) MSI RTX 3080 10GB Suprim X
Storage 3x SSDs 2x HDDs
Display(s) ASUS VG27AQL1A x2 2560x1440 8bit IPS
Case Thermaltake Core P3 TG
Audio Device(s) Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset
Power Supply Zalman EBT-1000
Mouse Mionix NAOS 7000
Keyboard Mionix
It basically falls between the R9 390 / 390x
390 = 5.1 Tflops
390x = 5.9 Tflops
From the looks
Fury X 8.6 Tflops
490x?
Nano 8.19 Tflops
490?
Fury 7.2 Tflops
390x 5.9 Tflops
480x 5,5 Tflops
390 5.1 Tflops
480
380x 3.97 Tflops
470x
380 3.48 Tflops
5,731 (1.06/day)
West Midlands. UK.
System Name Ryzen Reynolds
Cooling Raijintek Leto Pro
Power Supply Corsair VS 550w
Mouse Zalman ZM-M401R
Keyboard Razor Lycosa
390 = 5.1 Tflops
390x = 5.9 Tflops
From the looks
Fury X 8.6 Tflops
490x?
Nano 8.19 Tflops
490?
Fury
390x 5.5 Tflops
480x
390 5.1 Tflops
480
380x
470x
380
480 needs to be where 480x is as the op lists 480 5.5 tflops not the 480x
Which if true would make it a very attractive mid range choice for me
crazyeyesreaper
Not a Moderator
9,820 (1.69/day)
Keyboard Mionix
@NdMk2o1o
Keep in mind Titan X = 6.14 Tflops
So this only really applies to AMD's lineup and whos to say that the Tflops = actual gaming performance.
Time and again AMD has more raw compute but falls behind in games. the new Series may switch that a bit we do not know just yet.
2,735 (0.54/day)
Greece
Motherboard MSI B550 Tomahawk
Cooling ZALMAN CNPS9X OPTIMA
Case SHARKOON M25-W 7.1 BLACK
Keyboard Trust GXT280
If those specs are true, let me establish from now my estimation about its performance: It will surpass 390X for sure, also win 980 and perhaps be at Fury's (non-X) level for $250-299 (especially in DX11 due to arch improvements). And that product might become the bargain GPU of all times for any gamer on a budget with: DX12 superiority vs green camp, low power comsumption, thermals, noise. There will be 2 important things to be revealed later though: OC level and the not so low possibility for this GPU to be a cut down version with a full on edition to follow in 2-3 months and go against 1070.
5,731 (1.06/day)
West Midlands. UK.
@NdMk2o1o
So this only really applies to AMD's lineup and hows to say that the Tflops = actual gaming performance.
Yes however we're comparing their previous gen not NV/AMD they aren't going to go backwards on performance/tflops.... especially moving to 16nm so it will be at the very least smack bang between 390/390x if the above info is even legit.
crazyeyesreaper
Not a Moderator
9,820 (1.69/day)
Keyboard Mionix
^ true enough but since this is an entirely new gen of GCN that may change.
R9 380x = 3.97 Tflops
7970 Ghz = 4.3 Tflops
380x is on par or faster than 7970 Ghz but less compute performance.
480x could very well be slower in terms of PEAK Tflops but might out perform the 390x again remains to be seen but since AMD has done this before it could very well happen again.
Still all things considered 480x will likely be as shown in between the 390 and 390x
The supposed 3Dmark results show what is said to be a 480x beating the 390x. So again remains to be seen what will happen.
13,791 (1.85/day)
I'd expect RX 480 to be at least on a level of R9 390X. Which means RX 490X needs to be R9 Fury X level. Otherwise I don't understand the Polaris product placement within the market...
5,731 (1.06/day)
West Midlands. UK.
I did say that, hence me sayng at the very least it would be there or there abouts but could well be higher with new fab process and architecture improvements ;) :toast:
Either way I think I'll be going AMD this time around NV is too expensive for my liking and it will probably be around the 480 price/performance point.
Kursah
Super Moderator
14,735 (2.20/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
I wish I had a GTX480 just so I could upgrade to an RX480... :D
I'm looking forward to seeing this card released, I agree with @NdMk2o1o that this will be a great price/performance option...but as always I would expect NV to trim the price fat off of their profit per card soon after these are released. Bringeth the RX480 to release!
Another good year of GPU releases (I don't feel the 300-series or R9 Fury/Nano's were bad releases at all)...let's keep this trend and hope the RX480 provides some more competition than that slideshow signifies it might.
:rockout:
Kanan
Tech Enthusiast & Gamer
3,517 (1.01/day)
Europe
System Name eazen corp | Xentronon 7.2
Processor AMD Ryzen 7 3700X // PBO max.
Cooling Noctua NH-D14 SE2011 w/ AM4 kit // 3x Corsair AF140L case fans (2 in, 1 out)
Memory G.Skill Trident Z RGB 2x16 GB DDR4 3600 @ 3800, CL16-19-19-39-58-1T, 1.4 V
Video Card(s) Asus ROG Strix GeForce RTX 2080 Ti modded to MATRIX // 2000-2100 MHz Core / 1938 MHz G6
Storage Silicon Power P34A80 1TB NVME/Samsung SSD 830 128GB&850 Evo 500GB&F3 1TB 7200RPM/Seagate 2TB 5900RPM
Display(s) Samsung 27" Curved FS2 HDR QLED 1440p/144Hz&27" iiyama TN LED 1080p/120Hz / Samsung 40" IPS 1080p TV
Case Corsair Carbide 600C
Audio Device(s) HyperX Cloud Orbit S / Creative SB X AE-5 @ Logitech Z906 / Sony HD AVR @PC & TV @ Teufel Theater 80
Power Supply EVGA 650 GQ
Mouse Logitech G700 @ Steelseries DeX // Xbox 360 Wireless Controller
Keyboard Corsair K70 LUX RGB /w Cherry MX Brown switches
VR HMD Still nope
Benchmark Scores 15 095 Time Spy | P29 079 Firestrike | P35 628 3DM11 | X67 508 3DM Vantage Extreme
I think the 480/480X will be between 970 to Fury-ish levels and the 490(X) easily faster than anything before, including Fury X. Everything else would be a disappointment. I expect 490(X) to be as fast as GTX 1080 or faster.
5,731 (1.06/day)
West Midlands. UK.
3,531 (0.84/day)
Athens, Greece
3,890 (0.81/day)
Cooling AMD Wraith Prism
Display(s) Samsung 50" QN94A Neo QLED
Case Antec 1200
Mouse Razer Deathadder Chroma
Keyboard Logitech UltraX
crazyeyesreaper
Not a Moderator
9,820 (1.69/day)
Keyboard Mionix
so roughly 390x performance for $200 thats not awful IF that is the case
3,531 (0.84/day)
Athens, Greece
3,890 (0.81/day)
Case Antec 1200
2,141 (0.52/day)
Serbia
Processor Ryzen 5600
Motherboard X570 I Aorus Pro
Cooling Deepcool AG400
Display(s) 24G2U
Case NR200P
Power Supply Ion SFX 650
Mouse G703 (TTC Gold 60M)
Software W10
Amazing if true.
5,717 (0.93/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
Buy 3 of this and do a Tri-fire, see if that comes close to a 1080 performance.
HTC
4,678 (0.76/day)
Portugal
System Name HTC's System
Processor Ryzen 5 5800X3D
Motherboard Asrock Taichi X370
Cooling NH-C14, with the AM4 mounting kit
Memory G.Skill Kit 16GB DDR4 F4 - 3200 C16D - 16 GTZB
Video Card(s) Sapphire Pulse 6600 8 GB
Storage 1 Samsung NVMe 960 EVO 250 GB + 1 3.5" Seagate IronWolf Pro 6TB 7200RPM 256MB SATA III
Display(s) LG 27UD58
Case Fractal Design Define R6 USB-C
Power Supply Corsair TX 850M 80+ Gold
Mouse Razer Deathadder Elite
Software Ubuntu 20.04.6 LTS
$199. Is that for the Founders Edition ?
We'll know more in 3hrs.
LOL xD
I'm getting the bad feeling this is the "Fury X is an overclocker's dream" kind of hype AMD delivered to us back before Fury cards launched.
If this is the case, i expect these new cards to excell @ power draw, as claimed, but not so much on the performance front: it should still blow out of the water anything currently priced like this and it SHOULD be enough for the average user, which is what AMD's going for, but i seriously doubt it will touch nVidia's new cards.
Here's to hoping i'm completely wrong!
5,731 (1.06/day)
West Midlands. UK.
Come close? it would blow it out of the water (obviously good scaling games dependant as always with multi-GPU setups..) but if this is the case, $199 for a 480 (which I personally highly doubt and think you could add a $100 on to that price for a realistic expected price) would be a major coup for AMD, can't see it myself though and like I said, I think they will be more around the $299 point
3,890 (0.81/day)
Case Antec 1200
Out of interest what does $200 get you from AMD's current lineup?
