AMD Radeon RX 7600 Final Specs and Power Figures Leaked, Uses 6 nm
697 (0.40/day)
France
System Name Home
Processor Ryzen 3600X
Motherboard MSI Tomahawk 450 MAX
Cooling Noctua NH-U14S
Memory 16GB Crucial Ballistix 3600 MHz DDR4 CAS 16
Video Card(s) MSI RX 5700XT EVOKE OC
Storage Samsung 970 PRO 512 GB
Display(s) ASUS VA326HR + MSI Optix G24C4
Case MSI - MAG Forge 100M
Power Supply Aerocool Lux RGB M 650W
IIRC the 7900s have zero gain from the dual-pumped FP32 units because the compiler doesn't really support the functionality yet.
What compiler? Do you have any source for that?
3x0
974 (1.14/day)
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550I Gaming Edge Wi-Fi ITX
Cooling Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
Memory 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
Video Card(s) PowerColor Radeon RX7800 XT Hellhound 16GiB
Storage Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
Display(s) Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
Case Cooler Master NR200P ITX
Audio Device(s) Altec Lansing 220, HyperX Cloud II
Power Supply Corsair SF750 Platinum 750W SFX
Mouse Lamzu Atlantis Mini Wireless
Keyboard HyperX Alloy Origins Aqua
Hm, so now it's not certain if it uses the full N33?
8,692 (3.99/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
I'm looking forward to reviewers benchmarking this alongside the 6600XT and noting what a nothing-burger RDNA3 is.
At $249 for a brand new 6650XT and absolutely tons of unsold stock, the MSRP of this needs to be basically $249 or lower.
3x0
974 (1.14/day)
RX 7600 is RDNA 2.5
It doesn't use the same node and doesn't have the same L3 cache improvements the 7900XT(X) have, just by looking at it superficially. I'm sure reviewers will dig in to the architecture even more.
53 (0.02/day)
This card/chip is waaaay out of his comfort zone, too damn hot clocked to make up the small footprint and grunt. It will be okay for cheaper SKUs with a tamed power (115w, 150w) and cards between 100-250 USD, 300 is a robbery.
3x0
974 (1.14/day)
$269/€299
...ooof
1,081 (0.19/day)
Porto
Processor Ryzen 9 5900X
Motherboard Gigabyte X570 Aorus Pro
Cooling AiO 240mm
Memory 2x 32GB Kingston Fury Beast 3600MHz CL18
Video Card(s) Radeon RX 6900XT Reference (amd.com)
Storage O.S.: 256GB SATA | 2x 1TB SanDisk SSD SATA Data | Games: 1TB Samsung 970 Evo
Display(s) LG 34" UWQHD
Audio Device(s) X-Fi XtremeMusic + Gigaworks SB750 7.1 THX
Power Supply XFX 850W
Mouse Logitech G502 Wireless
VR HMD Lenovo Explorer
Software Windows 10 64bit
Yup
I’m guessing RDNA 3’s dual issue mode will have limited impact. It relies heavily on the compiler to find VOPD possibilities, and compilers are frustratingly stupid at seeing very simple optimizations. For example, the FMA test above uses one variable for two of the inputs, which should make it possible for the compiler to meet dual issue constraints. But obviously, the compiler didn’t make it happen. We also tested with clpeak, and see similar behavior there. Even when the compiler is able to emit VOPD instructions, performance will only improve if compute throughput is a bottleneck, rather than memory performance.
On the other hand, VOPD does leave potential for improvement. AMD can optimize games by replacing known shaders with hand-optimized assembly instead of relying on compiler code generation. Humans will be much better at seeing dual issue opportunities than a compiler can ever hope to. Wave64 mode is another opportunity. On RDNA 2, AMD seems to compile a lot of pixel shaders down to wave64 mode, where dual issue can happen without any scheduling or register allocation smarts from the compiler..
$269/€299
...ooof
Yeah they can go f___ themselves with that price.
3,935 (0.59/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
I wonder if it will have an updated media/codec engine?
waldor
3 (0.00/day)
Considering RTX 3060 Ti sells for $200 used nowadays, not sure if there are buyers for this card for anything more than $200.
