AMD Readies Larger 7nm "Navi 12" Silicon to Power Radeon RX 5800 Series?
540 (0.09/day)
System Name His - Hers - Guest - Guest - Guest
Processor 2700X - i7 5960x - i7 990x - 930 -i7 870 - i7 870
Motherboard MSI B450 ITX - Evga X99 - X58 - x58 - P55 FTW 200's
Memory 16GB - 8G
Video Card(s) Radeon VII - GTX770 x 3
Storage SSD
Display(s) 4K
Case Antec 1200, 1200, 900, 900
Power Supply Antec 1200 watt
Software Windows 7 Windows 10
Benchmark Scores Who cares
in the earning call somebody asked about high end Navi
Hans Mosesmann -- Rosenblatt Securities -- Analyst
Great. And can you give us a sense, if you can, on 7-nanometer high-end Navi and mobile 7-nanometer CPUs, if you can? Thanks.
Lisa Su -- President and Chief Executive Officer
Hans, you asked the good product questions. I would say, they are coming. You should expect that our execution on those are on track, and we have a rich 7-nanometer portfolio beyond the products that we have currently announced in the upcoming quarters. Thank you, Hans.
2,360 (0.45/day)
Right where I want to be
System Name Miami
Processor Ryzen 3800X
Motherboard Asus Crosshair VII Formula
Cooling Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover
Memory F4-3600C16Q-32GTZNC
Video Card(s) XFX 6900 XT Speedster 0
Storage 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD
Display(s) DELL AW3420DW / HP ZR24w
Case Lian Li O11 Dynamic XL
Audio Device(s) EVGA Nu Audio
Power Supply Seasonic Prime Gold 1000W+750W
Mouse Corsair Scimitar/Glorious Model O-
Keyboard Corsair K95 Platinum
That's vague af. Sidestepped that question like a boss, probably placated Hans but I would've called her out.
bug
14,193 (3.96/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Not sidestepped at all:
So whatever hasn't been announced for the upcoming quarters (plural!), is coming beyond (i.e. later than) that.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.38/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
If that's quoted word for word then I'd say they're working on a product that hasn't been announced yet. Maybe it isn't called Navi, maybe it is but it's clear AMD needs a new high performance GPU product because Navi/Super unseated Radeon VII.
Good catch...yeah...we're gonna be waiting a while. :( Then again, AMD never gave the impression of anything other than Navi this year.
Look at it from AMD's perspective: Navi was a priority for Microsoft and Sony consoles. RX 5700 launch is branching off of that. Whatever comes next isn't going to be principally designed for consoles. I wouldn't be surprised if Sony/Microsoft gave AMD a 15 billion transistor budget for the entire package which is why we ended up with a 10.3 billion transistor Navi.
2,360 (0.45/day)
System Name Miami
IN PLAINSPEAK: He's asking if there are any cards above the current above the 5700 XT on the way. Her response is that there are more cards on the way.
Doesn't commit to anything definite, as I far I'm concerned she's referring to the cards coming in below those two as she isn't lying if they don't release anything above the 5700 XT for the next HALF. If that isn't a sidestep/cop-out what is?
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.38/day)
IA, USA
System Name BY-2021
Mosesmann: "...7-nanometer high-end Navi and mobile 7-nanometer CPUs..."
Su: "...they are coming."
"they" = "those ones" = more than one
Then she continues: "You should expect that our execution on those are on track, and we have a rich 7-nanometer portfolio beyond the products that we have currently announced in the upcoming quarters."
Plainly: >RX 5700 XT cards and 7nm mobile CPUs are coming in 2020 or later. These products haven't been announced yet.
12 (0.01/day)
NAVI 10 has two shader engines with four prim (triangle) units, 40 CU, 64 ROPS, 4MB L2 cache coupled with 256 bit bus.
7870 has two shader engines with two geometry units, 20 CU, 32 ROPS, 512KB L2 cache coupled with 256 bit bus.
R9-290X has four shader engines with four geometry units, 44 CU, 64 ROPS, 1MB L2 cache coupled with 512 bit bus. R9-290X is 2X scaled 7870.
Your argument for " theoretical maximum of 8 shader engines with 10 CUs each" didn't factor in memory controller relationship!
Each NAVI shader engine has two prim units, 20 CU, 32 ROPS, 2MB L2 cache and 128 bit bus.
Navi has 4 shader engines using dual compute units (each single CU is now 32 cores, so a dual CU is 64 cores - 2x32; this is why Wave32 takes 1 cycle and Wave64 takes 2 cycles). Each shader engine has 1 rasterizer, primitive unit, 16 ROPs (4x4) with included 128KB L1 cache for this tightly integrated hardware block.
Memory controller relationship doesn't matter so long as you use a crossbar to connect uneven amounts of ROP and MCs (see AMD's Tahiti). But, 6 SEs and 96 ROPs are evenly matched to a 384-bit bus. 8 SEs would likely use 4 1024-bit HBM3 MCs/PHYs.
The way the image is labeled might open ambiguity, but they show 4 distinct shader engine blocks.
273 (0.07/day)
Edmonton
System Name Coffeelake the Zen Destroyer
Processor 8700K @5.1GHz
Motherboard ASUS ROG MAXIMUS X FORMULA
Cooling Cooled by EK
Memory RGB DDR4 4133MHz CL17-17-17-37
Video Card(s) GTX 780 Ti to future GTX 1180Ti
Storage SAMSUNG 960 PRO 512GB
Display(s) ASUS ROG SWIFT PG27VQ to ROG SWIFT PG35VQ
Case Cooler Master HAF X Nvidia Edition
Audio Device(s) Logitech
Power Supply COOLER MASTER 1KW Gold
Mouse LOGITECH Gaming
Keyboard Logitech Gaming
Software MICROSOFT Redstone 4
Benchmark Scores Cine Bench 15 single performance 222
I'm sure nvidia will come out with a new SUPER DUPER series to compete with AMD.
What for?
Navi 10 is only going after TU106 as it distroyed it!
TU104 already outperforms Navi 10 and as for Navi 12 if any truth will then compete against TU104 but as for now Navi 12 is nonexistent.
Navi 20 will compete against TU102 but by then I would expect Nvidia to release an unlocked TU102. (2080Ti Super) yes...
RTX 2070 Super is the best all around GPU going right now, out of the box can OC up to 2.1GHz which brings it around 2080 performance at a lower price point. Stock 2070 Super is already 1080Ti and Radeon 7 performance out of the box at a lower price point.
TU104 all around is an awesome GPU! AMD knows this..... Hopefully AMD trys very hard to bring some compition to the table soon and bring those Nvidia prices down a bit more, as there doing to Intel.
Just think Intel has Xe coming too lol
2020 going to be interesting.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.38/day)
IA, USA
System Name BY-2021
NVIDIA is going to have a 7nm product sooner or later.
Xe is the real unknown here. It could cause a major disruption to the graphics card market. I'm not going to hold my breath though because Intel hasn't proven their 10nm process will work for large chips yet. If Xe on 14 nm, there's not much chance of it competing with the 7nm products.
Navi is impressive though. It's clearly not just GCN 6th gen with a die shrink.
697 (0.14/day)
Australia
System Name Eula
Processor AMD Ryzen 9 7900X PBO
Motherboard ASUS TUF Gaming X670E Plus Wifi
Cooling Corsair H150i Elite LCD XT White
Memory Trident Z5 Neo RGB DDR5-6000 64GB (4x16GB F5-6000J3038F16GX2-TZ5NR) EXPO II, OCCT Tested
Video Card(s) Gigabyte GeForce RTX 4080 GAMING OC
Storage Crucial P3 Plus, 4 TB NVMe, Samsung 980 Pro 2TB NVMe, Toshiba N300 10TB HDD, WDC Red Pro NAS HDD
Display(s) Acer Predator X32FP 32in 160Hz 4K, Corsair Xeneon 32UHD144 32in 144 hz 4K
Case Antec Constellation C8 RGB White
Power Supply Corsair HX1000 Platinum 1000W
Mouse SteelSeries Prime Pro Gaming Mouse
Keyboard SteelSeries Apex 5
Software MS Windows 11 Pro
Wrong, it's two shading engines. Your diagram shows two shader engines i.e. count "shader engine".
AMD Navi RDNA specs
That 7nm Navi 10 GPU is the first RDNA-based graphics chip, and the full core – used by the RX 5700 XT – comes with 40 compute units, and therefore 2,560 cores across two shader engines, with 64 render output units, and 160 texture units. It’s 251mm2 and has a full 10.3bn transistors inside it. Navi has a GDDR6 memory controller, though is compatible with HBM if needed, and has PCIe 4.0 support too.
486 (0.12/day)
I think it will be RX 5700XT vs RTX 2070 and few days before NDA lifts the RTX 2070Super comes out, so AMD will say that the RX 5800XT can match RTX 2080Ti in performance but at cheaper price of $999 and then few days berofe NDA lifts we will see RTX2080Ti SUPER at same $1200 MSRP.
There already is a RTX2080Ti SUPER called Titan RTX
4,127 (0.57/day)
System Name RiseZEN Gaming PC
Processor AMD Ryzen 7 5800X @ Auto
Motherboard Asus ROG Strix X570-E Gaming ATX Motherboard
Cooling Corsair H115i Elite Capellix AIO, 280mm Radiator, Dual RGB 140mm ML Series PWM Fans
Memory G.Skill TridentZ 64GB (4 x 16GB) DDR4 3200
Video Card(s) ASUS DUAL RX 6700 XT DUAL-RX6700XT-12G
Storage Corsair MP510 480GB M.2 - 2 x WD_BLACK 1TB SN850X M.2 1TB - Lexar NQ790 M.2 2TB
Display(s) ASUS ROG Strix 34” XG349C 144Hz 1440p + Asus ROG 27" MG278Q 144Hz WQHD 1440p
Case Corsair Obsidian Series 450D Gaming Case
Audio Device(s) SteelSeries 5Hv2 w/ Sound Blaster Z SE
Power Supply Corsair RM750x Power Supply
Mouse Razer Death-Adder + Viper 8K HZ Ambidextrous Gaming Mouse - Ergonomic Left Hand Edition
Keyboard Logitech G910 Orion Spectrum RGB Gaming Keyboard
Software Windows 10 Pro - 64-Bit Edition (Back to Win 10 because 11 is garbage)
Benchmark Scores I'm the Doctor, Doctor Who. The Definition of Gaming is PC Gaming...
Can't wait to see this new Navi 12 GPU in action. Hopefully AMD puts on a better cooler on it, enough with the Blower Style coolers.
They are ugly and don't work well.
The Radeon V cooler looked Great.
Intel will most likely tap into the low to mid range "Discrete GPU" market. I don't see any high end GPUs from them, at least for another couple years. Unless they have a surprise or something.
I agree, Navi is a combination of Old Tech GCN + New tech combined. AMD did a fantastic job on them. Fudzilla was the 1st to break the news on NAVI and its GTX 1080 like performance for a $250 price tag. What actually happened was NAVI GPUs that actually compete beyond GTX 1080 like performance, hence the price increase from the rumoured $250.
by FUAD ABAZOVICon12 APRIL 2018
AMD Navi is no high end GPU
420 (0.14/day)
System Name The Cum Blaster
Processor R9 5900x
Motherboard Gigabyte X470 Aorus Gaming 7 Wifi
Cooling Alphacool Eisbaer LT360
Memory 4x8GB Crucial Ballistix @ 3800C16
Video Card(s) 7900 XTX Nitro+
Storage Lots
Display(s) 4k60hz, 4k144hz
Case Obsidian 750D Airflow Edition
Power Supply EVGA SuperNOVA G3 750W
That sounds very optimistic.
optimistic? that doesn't sound optimistic to me. it sounds like a horror movie to me. the thought of paying $999 for a flagship card makes me shit my pants.
697 (0.14/day)
Australia
System Name Eula
NAVI is not GCN.
NAVI wave32 executes in single clock cycle and wave64 executes in two clock cycle s while GCN wave64 executes in four clock cycles.
4,127 (0.57/day)
NAVI is not GCN.
Correct it's based on RDNA. I was referring to an older explanation on what Navi could be.
Anyhow, thanks for correcting me.
273 (0.07/day)
Edmonton
128356
Intel has high-end GPUs coming by the way!
Bragin about 3.5 years old architecture 1080 performance is not Kool anymore.
Ryzen 7 is the performance of an 2.5 years old 1080Ti.
AMD is playing catch up....nothing more dreamers.
Want a fast Radeon 7 performance for less price?
2070 Super
Can't wait for the Techpowerup Review on the ROG-STRIX-RTX2070S-O8G- !
This is faster than Navi 10
4,127 (0.57/day)
2070 Super
You probably got confused. But how is a Ryzen 7 and a 1080 compared? Where one is a CPU and the other a GPU? Lol
AMD isn't playing catch up. They rule the CPU industry once again. The last time they achieved this was with the Athlon and Athlon 64.
AMDs Navi RDNA GPU is doing quite well in performance. Nvidia has the fastest GPU that's Overpriced. What people don't understand is it takes years for a new micro-Architecture. That is what AMDs been working on. They did it with the CPU and they are almost complete with the GPU...
3,542 (1.00/day)
System Name M3401 notebook
Processor 5600H
Motherboard NA
Memory 16GB
Video Card(s) 3050
Storage 500GB SSD
No, they have something rather cheap ($200) coming, according to Raja. (something with HBM in it, for enterprise)
4,127 (0.57/day)
64CU Navi card can be sold for $999 for easy since it will be better then RTX 2080Ti, question is how much better should it be since in this price range the RTRT is more relevant since the 2080Ti can run games with RTX ON much better then the 2060/2070/2080.
AMD can use the current high pricing of the 2080Ti, we need to "thank" Nvidia for that :-(.
Absolutely not for $999, because we all know the 2080 Ti is OVERPRICED to begin with. The 2080Ti is only worth about $699 MAX. Which makes all Nvidia cards Overpriced.
bug
14,193 (3.96/day)
To you, maybe. Obviously there are some that think that's the right price for 2080Ti, since they're buying the cards.
This may sound strange to you, but in a free market the price of goods is not dictated by the BOM. The price of goods is the one the seller is willing to accept and the buyer is willing to pay.
4,127 (0.57/day)
Hence the LOW 2080ti sales. Though the high price was due to lack of competition in the high end segment.
bug
14,193 (3.96/day)
As opposed to other high-end cards that usually sell en-masse?
The point is, whatever cards Nvidia makes, they sell. They're not catching dust on shelves.
3,542 (1.00/day)
Processor 5600H
Motherboard NA
Memory 16GB
Video Card(s) 3050
Storage 500GB SSD
Or also because it is a 750mm2 monster chip.
bug
14,193 (3.96/day)
A combination of both. I'm pretty sure Nvidia would have sold that for much less (or didn't release it at all) if AMD was active in that segment. Of course, since I don't consider buying cards that cost half as much, I'm just enjoying my popcorn from the sidelines ;)
Majin_Sam
3 (0.00/day)
...yea but thats got nothing to do w the value of a product. Nvidia has been padding their pockets for years at the expense of its customers and its only because AMD couldnt compete at the high end. Per frame, anything past a 60 series Nvidia GPU is a bad, bad value.
She said theyre coming...and that future products beyond that are coming...whats she supposed to do, throw down the target specs and release dates out prematurely so Nvidia can beat them to the table with a 1680 Super Duper Ti?
A Navi 12 die wouldnt be any worse for efficiency as a fully equipped TU104. Nvidia fans, especially the RTX buyers (im one), are going to feel real dumb pretty soon. Worse than "ga-hyuck, I just bought a 9900k at full retail" kind of dumb. A 5800 series will compete at high end, and it doesnt even have to better, or even as good, because its not going to cost $1400. Its not going to be $999. AMD has the taste for blood and for once its not from being punched in the mouf so think like...$699...maybe $799. Boom. Now either Nvidia has to double down on RTX and expedite it to mainstream (spending billions), slash RTX prices to compete (pissing us off), or RTX gets killed for the foreseeable future and we go back to good ol' rasteurization horsepower, and hello GTX 1180, 1680, 1780, whatever. Thats whats about to happen.
What for?
Daaah, Navi 10 achieves near parity to TU104...albeit the diet version. I dont know about a 2080 Super Ti or anything...maybe a new GTX line...
