AMD Releases PCI-Express Power Draw Fix, We Tested, Confirmed, Works
5,717 (0.93/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
I am having stability issue with this new driver on FuryX. 1100 OC is no longer stable no matter what amount of vcore offset is applied now. Played CSGO for 30mins and it crashed on me which have not happened since launch driver. Lower down to 1075OC and it still would crash. It can't even pass the 3DMark FireStrike Stress test now. I use DDU between all of my driver installations so it is definitely not the problem of driver files conflict. Reverted back 16.6.1 and everything is back to normal. Passed 100 loops of FSE Stress test at 99.5% for 1100 OC.
Very likely RTG is focusing on 480 driver now and somehow messed up driver support for previous gen cards. Guess I will just wait until a newer driver that does not solely focus on RX480 then.
And yes I have already submitted the problem to RTG.
5,717 (0.93/day)
That would make more sense, 40A*1.5V is 60W. If that's a 125°C rating, at lower temperatures we can still be talking around 80-100W. That's still huge.
@Shamalamadingdong
Yeah, I'm aware of the risks, but that applies to every overclock. Still, the headroom can be a lot higher than around 150W as initially thought. If user has PSU powerful enough to feed 6pin, VRM is there to deliver it if needed. Far beyond the original specs. Meaning AIB's only have to slam better cooling on reference design. They don't even have to redesign PCB and components on it to gain headroom.
Gusteberg over OCN is working on editing RX480 BIOS for increased power limit. With all power limit removed and heat factor dealt with the card should run 1.4GHz to 1.5GHz easily.
872 (0.14/day)
Copenhagen, Denmark
System Name Ryzen/Laptop/htpc
Processor R9 3900X/i7 6700HQ/i7 2600
Motherboard AsRock X470 Taichi/Acer/ Gigabyte H77M
Cooling Corsair H115i pro with 2 Noctua NF-A14 chromax/OEM/Noctua NH-L12i
Memory G.Skill Trident Z 32GB @3200/16GB DDR4 2666 HyperX impact/24GB
Video Card(s) TUL Red Dragon Vega 56/Intel HD 530 - GTX 950m/ 970 GTX
Storage 970pro NVMe 512GB,Samsung 860evo 1TB, 3x4TB WD gold/Transcend 830s, 1TB Toshiba/Adata 256GB + 1TB WD
Display(s) Philips FTV 32 inch + Dell 2407WFP-HC/OEM/Sony KDL-42W828B
Case Phanteks Enthoo Luxe/Acer Barebone/Enermax
Audio Device(s) SoundBlasterX AE-5 (Dell A525)(HyperX Cloud Alpha)/mojo/soundblaster xfi gamer
Power Supply Seasonic focus+ 850 platinum (SSR-850PX)/165 Watt power brick/Enermax 650W
Mouse G502 Hero/M705 Marathon/G305 Hero Lightspeed
Keyboard G19/oem/Steelseries Apex 300
Software Win10 pro 64bit
damn! with their budget though i dont think they can "multitask" that much..
5,717 (0.93/day)
Good thing is there are nothing new I needed from 16.7.1 at this moment. I thought FuryX would get the Wattman but nope. Oh well, I can work with traiditional way of OC. :D
4,323 (1.10/day)
Texas
Mouse Logitech G5
Keyboard Logitech G19S
That's unfortunate, it didn't effect my 290X's and their overclocking. I tested it with some BF4 last night and no problems with same settings though I don't see anything that I gained either so probably could have not downloaded it.
872 (0.14/day)
Copenhagen, Denmark
cool, you look like you know your stuff anyway.. :)
cdawall
where the hell are my stars
27,683 (4.10/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
mb don't have built in a current limiter and any consumer attached to it can draw more till something is kaboom
Depends on board I have more than one high end board that allowed per slot wattage limits. Most of which I could go as high as 150w...
2,722 (0.54/day)
Greece
Motherboard MSI B550 Tomahawk
Cooling ZALMAN CNPS9X OPTIMA
Case SHARKOON M25-W 7.1 BLACK
Keyboard Trust GXT280
well thats very neat.
So it actually works and the performance does not suffer :)
Nice job AMD.
@tPU and chance of running a few more games to see how they react?
Almost sure that for the next GPU review (custom RX480 probably) W1z will test them with Crimson 14.7.1 as he always does :)
1,491 (0.20/day)
66 feet from the ground
System Name 2nd AMD puppy
Processor FX-8350 vishera
Motherboard Gigabyte GA-970A-UD3
Cooling Cooler Master Hyper TX2
Memory 16 Gb DDR3:8GB Kingston HyperX Beast + 8Gb G.Skill Sniper(by courtesy of tabascosauz &TPU)
Video Card(s) Sapphire RX 580 Nitro+;1450/2000 Mhz
Storage SSD :840 pro 128 Gb;Iridium pro 240Gb ; HDD 2xWD-1Tb
Display(s) Benq XL2730Z 144 Hz freesync
Case NZXT 820 PHANTOM
Audio Device(s) Audigy SE with Logitech Z-5500
Power Supply Riotoro Enigma G2 850W
Mouse Razer copperhead / Gamdias zeus (by courtesy of sneekypeet & TPU)
Keyboard MS Sidewinder x4
Software win10 64bit ltsc
Benchmark Scores irrelevant for me
So, all phases can churn out 240W theoretical load and realistic max being 120W on 6pin phases and 75W on PCIe phases. That's still 195W which ain't that bad, giving some headroom. If you can cool it well enough.
you understood wrong.... 6 pin isn't max out with 120w...can deliver min. 150w....if psu rail have juice...
13,791 (1.86/day)
I know that, I was talking based on what phases can actually deliver. If 3 phases are dedicated to 6pin and each is 40W, then that's 120W. But someone later clarified it's 40A and not 40W...
31 (0.01/day)
System Name Throne
Processor Intel Core i5 3570K 3.4Ghz ~ 3.8Ghz Turbo
Motherboard GA Z77X-UD3H
Cooling Cooler Master TX3 Hyper
Memory Kingston Hyper X 1866Mhz
Video Card(s) Sapphire r9 280 Dual-X OC 940/1250
Storage Seagate Barracuda 7200rpm 64MB Cache 1TB SATA III
Display(s) LG 22MP55" 1080p IPS
Case Cooler Master Elite 430
Power Supply Corsair CX600M
Mouse Lenovo Default Mouse
Keyboard Logitech G15 Gaming Keyboard
Software Windows 7 64b Ultimate
Benchmark Scores Fire Strike Extreme Presets = 7650
so is a driver or what ?? i was having big peaks of current in my r9 280, maybe it got fixed for me too ?
13,791 (1.86/day)
Very unlikely since this is RX480 specific control of it's VRM segment. I very much doubt they'd somehow change old R9 280 as well with it.
31 (0.01/day)
System Name Throne
damn it, i think my PSU its failing to hold my system, i will get a EVGA Supernova 750W or a CX750M ...
5,717 (0.93/day)
Still, Fury X is still their current flagship. It deserves same attention as new RX generation. @xkm1948 send a bug report to AMD.
Read my thread dude, already sent. Thanks for the tag though. :D
I don't buy cards for showing epen. I use them for work and entertainment. So far my FuryX has been more than awesome for VR as well as OpenCL computing.
Going back to Nekopalive now.
31 (0.01/day)
System Name Throne
cant be more agree with you, for me no company is better than the other, i focus on costs and perfomance, no of those companys will give you a damn product for free, they will preffer to have ur blood first !
for what i see, nVidia is always more spensive than AMD at the same level of performance, atleast here in Cuba it this, for example, GTX960 here cost around 250/270$ at that same price tag and more performance i will neve buy that above an r9 280x (220$) or a r9 380x (270$)
1,927 (0.43/day)
UK
System Name TITAN Slayer / CPUCannon / MassFX
Processor i7 5960X @ 4.6Ghz / i7 3960x @5.0Ghz / FX6350 @ 4.?Ghz
Motherboard Rampage V Extreme / Rampage IV Extreme / MSI 970 Gaming
Cooling Phanteks PHTC14PE 2.5K 145mm TRs / Custom waterloop / Phanteks PHTC14PE + 3K 140mm Noctuas
Memory Crucial 2666 11-13-13-25 1.45V / G.skill RipjawsX 2400 10-12-12-34 1.7V / Crucial 2133 9-9-9-27 1.7V
Video Card(s) 3 Fury X in CF / R9 Fury 3840 cores 1145/570 1.3V / Nothing ATM
Storage 500GB Crucial SSD and 3TB WD Black / WD 1TB Black(OS) + WD 3TB Green / WD 1TB Blue
Display(s) LG 29UM67 80Hz/Asus mx299q 2560x1080 @ 84Hz / Asus VX239 1920x1080 @60hz
Case Dismatech easy v3.0 / Xigmatek Alfar (Open side panel)
Audio Device(s) M-audio M-track / realtek ALC 1150
Power Supply EVGA G2 1600W / CoolerMaster V1000 / Seasonic 620 M12-II
Mouse Mouse in review process/Razer Naga Epic 2011/Razer Naga 2014
Keyboard Keyboard in review process / Razer Blackwidow Ultimate 2014/Razer Blackwidow Ultimate 2011
Software Windows 7 Ultimate / Windows 7 ultimate / Windows 7 ultimate
Benchmark Scores cinebench 15.41 3960x @ 5.3ghz Wprime32m 3.352 3960x @ 5.25ghz Super PI 32m: 6m 42s 472ms @5.25ghz
Turns out I messed up the current rating at 125C. The RX 480 Vcore VRM is 6 phases composed of a MDU1514 high side FET and an MDU1511 low side FET. The MDU 1514 has a continuous drain current of 66A @ 25C case temperature and just under 30A at 125C. It has a pulsed current rating of 100A however the pulse duration or frequency isn't specified so it's not all that useful . The low side MDU1511 has a continuous drain current of 100A at 25C case temperature and goes down to about 66A at 125C. So the low side of the VRM can handle 396A of current at 125C and the high side should be able to keep up with that depending on the duty cycle. A 100% safe rating for the high side is 180A @125C at any core voltage setting. Realisticly the VRM shouldn't get anywhere near that hot and you will have a lot more current to play with on both the high and low sides.
872 (0.14/day)
Copenhagen, Denmark
they really should focus on the boot issue with high refresh rate using dvi, multi high refresh monitors increased power draw and displayport incompatibility with htc vive, but i guess any amd fault to bash is better than admitting nvidia has any
i didnt know about these problems, could you care to post some links please?
cdawall
27,683 (4.10/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
Frick
Fishfaced Nincompoop
19,756 (2.86/day)
w
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
There's a word for people stamping degrading titels on others without knowing the person in question: People stampting degrading titles to others sans knowing the persons they apply the stampt upon. And it's always ugly, on so many levels.
cadaveca
My name is Dave
17,232 (2.51/day)
Since this option was a function of the VRM controller, I was really surprised AMD didn't do this from the start, especially considering that it barely affects performance.
Nice to see compatibility mode for those users with older(within limits) PSU/mobo combos can safely add in multiple 480s, too.
However, If I was AMD, I would have had these things ready at the launch and advertised them as features to boost up the bullet points and bring in more consumer confidence. Hopefully future releases will take this situation as a consideration and they'll put it to good use. Sad to see hardware released that doesn't take advantage of all it has to offer; excellent to see it used properly so quickly.
872 (0.14/day)
Copenhagen, Denmark
that was their stupidity.. the whole problem could be avoided so easily.. i really cant get amd sometimes..
W1zzard
Administrator
28,021 (3.71/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
They could have just connected one more phase to the 6-pin, instead of 50/50, very easy to do during board design stage.
cadaveca
My name is Dave
17,232 (2.51/day)
But that might have given the potential for higher clocking and cannibalized a future SKU. :p
