AMD Ryzen 5 8600G to Feature Radeon 760M Graphics with 8 CU, 5.00 GHz Maximum CPU Boost
269 (0.24/day)
Georgia, United States
System Name LMDESKTOPv2
Processor Intel i9 10850K
Motherboard ASRock Z590 PG Velocita
Cooling Arctic Liquid Freezer II 240 w/ Maintenance Kit
Memory Corsair Vengeance DDR4 3600 CL18 2x16
Video Card(s) RTX 3080 Ti FE
Storage Intel Optane 900p 280GB, 1TB WD Blue SSD, 2TB Team Vulkan SSD, 2TB Seagate HDD, 4TB Team MP34 SSD
Display(s) HP Omen 27q, HP 25er
Case Fractal Design Meshify C Steel Panel
Audio Device(s) Sennheiser GSX 1000, Schiit Magni Heresy, Sennheiser HD560S
Power Supply Corsair HX850 V2
Mouse Logitech MX518 Legendary Edition
Keyboard Logitech G413 Carbon
VR HMD Oculus Quest 2 (w/ BOBO VR battery strap)
Software Win 10 Professional
Anyway, I wonder what the point is with buying this instead of a system with a soldered APU, especially when mini-ITX boards are so expensive.
Building a bigger system with an ATX board seems unlikely as well.
There are several use cases here. For example you wanted to build a new machine but wanted to buy the graphics card later so you bought this so you could have adequate gaming performance in lower end stuff until you bought a card.
9,785 (3.47/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
The question I have is how do we know how those perform if there is no HDMI or DP port on the MB used. Unless they were using USB C there is no way to test the APU by itself using that MB. There is also the fact that the Ace is one of the most expensive AM5 boards period. I hope TPU uses B650 and A620 boards when they get these for testing.
2,368 (2.70/day)
Brazil
Processor AMD Ryzen 7 5700X3D
Case Lian Li Lancool 216
Mouse Razer Viper Ultimate
The Ace has DP over USB-C.
Afaik, AM5 has HDMI and DP capabilities onboard by itself but it's up to the motherboard manufacturers to implement the outputs. As every processor bar the 7500F has a basic as it may be iGPU, at least one video out is expected.
1,146 (0.20/day)
SCOTLAND!
System Name Machine XX
Processor Ryzen 7600
Cooling 120mm heatsink
Memory 32GB DDR5 6000 CL30
Video Card(s) RX5700XT 8Gb
Storage 280GB Optane 900p
Display(s) 19" + 23" + 17"
Case ATX
Power Supply 800W
Oh zip it, you know when AMD first used the term APU? And why Intel doesn't use it? It's a marketing term, even if its utility has changed slightly over the years!
please show us what piece of silicone on the 7950x has both a CPU core and GPU core on it......
9,785 (3.47/day)
Cooling In Win SR36
R0H1T
Your total lack of knowledge is showing, please show us what piece of silicone on the 7950x has both a CPU core and GPU core on it......
So the 7950X has no video support? Even the 7950X3D has GPU cores. These are going to be APUs for AM5. If you didn't know the 5600G (AM4 APU) does support Freesync with it's Vega cores.
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
the graphics cores on the 7000 series are not on the same silicone as the cpu cores.....thats the difference with the APU chips
7,729 (1.78/day)
You mean Silicon or Silicone?
https://www.techpowerup.com/review/amd-ryzen-9-7950x/images/delidded.jpg
And yes it's still an APU :rolleyes:
the graphics cores on the 7000 series is not on the same silicone as the cpu cores.....thats the difference with the APU chips
No the term APU used to refer to "CPU" with an IGP, before that they were usually on the motherboard. In case you missed it the CCD's (chiplet) also don't have a memory controller, I guess they're not CPU's then?
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
No they have only ever called the chips with the graphics and CPU on the same piece of silicone APU's, nowhere in any AMD documents is a Desktop Multi chip package referred to as an APU.
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
9,785 (3.47/day)
Cooling In Win SR36
all are single pieces of silicone going back to am1 apart from 2 laptop chips 7945HX and 7845HX. no desktop mcm chips are called an apu.
What is an APU to you? To me it is a chip that has GPU cores period. What you are talking about was only true for AM4. I am not sure but I could swear there is a 16 core APU on laptop currently that is MCM that you just referenced (7945HX :) :) . Of course you can't be serious in thinking that those cannot come to the desktop with better cooling potential and more power and be called APUs but if you want to argue the scientific definition of an APU be my guest. All I know is that my 7900X3D shows its own GPU in HWinfo but I have been drinking so.
HWiNFO64 v7.43-5040 Sensor Status [1 value hidden] 2024-01-08 3_35_00 PM.png
2,368 (2.70/day)
Brazil
AMD's definition of an APU is a CPU with an iGPU capable of (albeit light) gaming on its own, without the need for a dGPU. The iGPU on the 7000-series CPUs isn't capable of that.
9,785 (3.47/day)
Cooling In Win SR36
Of course, it is only 2 GPU cores but would a 3400G blow it away?
SL2
2,489 (0.36/day)
Maybe AMD just can't make their mind up..
We actually don't think of the Ryzen 7000 Series as an APU. It's a processor that has graphics, and I know that's a subtle difference.
To us, when we say "APU," it really means the product has powerful graphics, is capable of playing a game, has all the bells and whistles for video encode, display, drivers, etc.
Llano is over a decade old now so stop using it as a reference, things change. AMD did try to highlight its IGP performance at the time, something I never saw them do with Raphael. AMD simply pointed out the 2CU IGP's existence, which isn't the same.
That's apples to oranges, or rather apples to old apples. By that reasoning you can't call a Phenom II X4 920 a quad core anymore because there are dual cores that beats it today.
