AMD Ryzen AI Max 395+ Mini PC: GMK Announces Strix Halo-Powered Compact System
722 (0.10/day)
40 RDNA 4 CUs look like it's gonna outperform the PS5 36 RDNA 2 CUs. But will it bottleneck by DDR5 bandwidth?
That is a good question
Those are RDNA 3.5 and they are designed to work with LPDDR5 memory. It have 256 GB/s of bandwidth instead of the 448 GB/s of the PS5 but it will have 32 MB of MALL cache (infinity cache) just for the GPU.
It's unclear what is the bandwidth of that cache so it would be hard to calculate effective bandwidth of this GPU at different resolution. But as a reminder, this is what AMD published for cache hit ratio per resolution for RNDA2
2,774 (1.61/day)
LLMs, especially the 80B parameter ones these machines are designed for, cannot reliably cache anything.
It requires you to run through all 80B parameters to compute even just one token. That's usually 80 GBs of weights. There's no caching strategy available here. Generative AI / Painting AIs are convolutional in nature and can benefit from caches. But as you see... it very much depends "which" AI you're trying to run on these machines.
Caches for RDNA / Video Games exist because the Framebuffer (aka: the screen's pixels) is very commonly used in video games. Not just for output, but also as inputs (TAA, and other anti-aliasing effects... blur effects and more). Storing the entire framebuffer/screen in Cache makes a big difference for video games.
865 (1.18/day)
System Name Lenovo slim 5 16'
Processor AMD 8845hs
Motherboard Lenovo motherboard
Cooling 2 fans
Memory 64gb 5600mhz cl40
Video Card(s) 4070 laptop
Storage 16tb, x2 8tb SSD
Display(s) 16in 16:10 (1920x1200) 144hz
Power Supply 270w psu
Strix Halo is worrying the hell out of Intel and Nvidia. This is a chip that is going to take a sizable bite out of everyone's lunch so long as TSMC can supply it, and it quite honestly the chip I care most about as I am migrating over to mini PC's. I have a Phoenix point Mini PC right now. Zen 3 with 12 RDNA 2 CU's. The damn tiny thing is awesome.
My current laptop has a 8845hs, I see myself using the AMD 780m gpu more than the 4070 mobile. I usually play more games with the 780m, fits just perfect.
7,317 (1.03/day)
Video Card(s) Asus GeForce RTX™ 4070 Dual OC (Waiting on RX 8800 XT) | Intel® Iris® Xe Graphics
Looks like partners can opt to use LPDDR5X as well. HP is launching the Z2 Mini G1a which is a similar form factor but with soldered 8000MT/s memory and a MAX+ 395 PRO. That'd be LPDDR5X right?
Edit: not to mention this thing looks way nicer than the GMK box
View attachment 379782View attachment 379783
I cannot remember if it was Acer that showed off a AMD Ryzen AI Max+ 395 with without soldered memory which I am intrigued to see the performance between DDR5 vs LPDDR5X ram but I wish there would be a CAMM2 model instead of soldered memory so when there is a memory error you can change the model out and performance between CAMM2 and LPDDR5x should be on pair or am I far off?
I really hope the AMD Ryzen AI Max+ 395 based system won't be hella expensive because I personally want one and it can replace my current system if gaming performance is good this is why I would love to also see non-soldered vs soldered performance.
It would be awesome if AMD would release a Ryzen Max+ 395 without AI so it could be cheaper for normal people and the gamers that could need this one.
Probably due to fact that CAMM2 and LPCAMM dont support 256bit quad channel memory which is what these AI Max series of CPUs are designed around.
Yeah this apu got quad channel memory support this was something I wasn't even thinking about. But this I would love to see what happens when there is a non-soldered version to see the performance difference.
Not a fan of mini DP ports.
Same, but there is a place for it somewhere but again it's I am happy HP didn't go with mini-hdmi.
523 (0.68/day)
NYC
System Name GameStation
Processor AMD R5 5600X
Motherboard Gigabyte B550
Cooling Artic Freezer II 120
Memory 16 GB
Video Card(s) Sapphire Pulse 7900 XTX
Storage 2 TB SSD
Case Cooler Master Elite 120
You can't install Asahi Linux on the Mac Mini?
You can, but Apple is not helping that team with documentation or drivers, so theres a lot of the hardware not being properly utilized.
Its quad channel.
It is using 256bit DDR5, so it's still bottlenecked but not as much as say a 8700G.
But in quad channel.
Per this TPU article : https://www.techpowerup.com/330548/...ix-halo-soc-up-to-16-zen-5-cores-massive-igpu
To keep the up to 16 "Zen 5" CPU cores, the large iGPU with 40 CU, and the 50 TOPS NPU fed with sufficient memory bandwidth, AMD has given the "Strix Halo" a quad-channel (256-bit) LPDDR5X-6400 memory interface. This should give the processor a memory bandwidth of 256-bit. The iGPU talks to the system over the core switching fabric (Infinity Fabric) of the SoC die.
The scary part is, this APU was supposed to be released 2 years ago.
Not sure why the delay.
253 (0.07/day)
Japan
System Name ChronicleScienceWorkStation
Processor AMD Threadripper 1950X
Motherboard Asrock X399 Taichi
Cooling Noctua U14S-TR4
Memory G.Skill DDR4 3200 C14 16GB*4
Video Card(s) AMD Radeon VII
Storage Samsung 970 Pro*1, Kingston A2000 1TB*2 RAID 0, HGST 8TB*5 RAID 6
Case Lian Li PC-A75X
Power Supply Corsair AX1600i
Software Proxmox 6.2
40 CUs? The Rx 580x was 36 CUs.
That's a mighty amount of GPU-compute.
But it was 7 years ago. Not to say it wasn't a good start but it's more of a finally.
449 (1.27/day)
Processor Ryzen AI
Motherboard MSI
Cooling Cool
Memory Fast
Video Card(s) Matrox Ultra high quality | Radeon
Storage Chinese
Display(s) 4K
Case Transparent left side window
Audio Device(s) Yes
Power Supply Chinese
Mouse Chinese
Keyboard Chinese
VR HMD No
Software Android | Yandex
Benchmark Scores Yes
Radeon 8060S is quite fast for an integrated GPU, it's actually in the ballpark of RTX 4060.
If you can buy the product, buy it. It's probably one of the two or three AMD products that are worth it.
449 (1.27/day)
Processor Ryzen AI
Motherboard MSI
Cooling Cool
Memory Fast
Storage Chinese
Display(s) 4K
Audio Device(s) Yes
Mouse Chinese
Keyboard Chinese
VR HMD No
Their biggest target is Apple, especially MacBook pros!
Can't be. That is a completely different market segment, RISC, non-x86 and non-Windows ecosystem.
AMD is a mess now.
973 (0.89/day)
nah, it’s a 45w product the m4 isn’t even 10w.
its a pipe cleaner product to see if there is a real market for them.
if there is a big demand for it they will quickly replace it with an RDNA 4 gpu if there isn’t it’s going to be a one off.
given the state of the economy and the slump the pc market is in, it’s going to be a one off
973 (0.89/day)
I'm talking about the (Halo) chips in general, not just this product as such.
How does that matter, unless you were talking about something else?
You're kidding right o_O
No I’m not kidding, the m4 and the m4 pro are vastly more energy efficient chips.
this thing only starts at 45w and has the option to go all the way op to 120w
Probably even more when stressed.
7,586 (1.77/day)
Yes but they're not ~10W chips as you said, also the top m4(Pro/Max) chip probably peaks closer to ~80W in MT tasks. The 12c M4 pro peaks to 73.2W in CB15 multi, it could likely consume a lot more in the latest benches. Granted this doesn't exclude other components & the fan but still, these things aren't that efficient as they're portrayed!
Apple's biggest advantage is the Mac OS & of course their entire well oiled & controlled/closed ecosystem
39 (0.04/day)
I think AMD has supply problem from TSMC, not getting enough wafers allocated due to often being outbid by e.g. Apple, Nvidia and Intel. So that's one reoccurring problem.
Second, AMD has produced better CPU:s than Intel for a long time now, yet we still see Intel systems, motherboards and laptops dominate. Intel is clearly bribing manufacturers to use their stuff. Nvidia as well. They might even have exclusivity deals, and deals that say they own a certain laptop design from a company. E.g. Lenovo and ThinkPad X1 Carbon, Dell XPS, etc. Ever wondering why we don't see AMD chips in them? Because Intel owns the designs.
In other words, even if AMD has a very appealing product, as in this Strix Halo, it is difficult for them to penetrate the market. If AMD was in a dominant position themselves, they would act the same as Intel/Nvidia. These giant coorporations really don't care about anything other than your money. We should not feel sorry for AMD. Just hope that these more powerful APU:s are becoming more standard from now on.
2,250 (0.33/day)
Toronto, Ontario
System Name The Expanse
Processor AMD Ryzen 7 5800X3D
Cooling Corsair H150i Pro
Video Card(s) XFX Radeon RX 7900 XTX Magnetic Air (24.12.1)
I'm so tempted to grab one of these for a Dedicated machine to run LLM's.
Currently running them on my 7900XTX which is good with 24GB of VRAM for models in the 30B range, however this where you have access to 96GB of unified VRAM would allow me to run much larger models 70B easily.
However price will be high and this is just a nice to have currently. Can wait on this abit to see what prices look like in a year.
Kiddles
1 (1.00/day)
Could be the future since big bulky performance PC:s are getting tiresome, at least for me. But it has to be executed right. Aesthetics, price, BIOS, I/O and a good quality cooling solution that doesn't sound like a jet engine. Would have better longevity than a Mac mini since Linux could be installed.
I'm in a similar boat. I'm kinda just done with building a PC every god damn time, and I don't play enough AAA, or even AA games, to warrant the need for a high end GPU anymore. I just want something power efficient that has a small spatial footprint at this point, but is still enough to play the games that I already have in my Steam library at 1080p/1440p, 60 FPS. Plus, 40 CUs boosted up to 2900 MHz (assuming it clocks that high) would offer around 14.8 TFLOPS, which is plenty for getting 120 FPS in CS:GO and other competitive shooters that aren't trying to go too hard on visuals.
That said, the BIOS for GMKTech computers isn't the most feature-rich, but it's generally enough for what most people are using these things for. And don't expect to get under 84°C at 100% load with the limited cooling most MiniPCs have.
