- May 10, 2023
- 782 (1.14/day)
- Brazil
Processor | 5950x |
Motherboard | B550 ProArt |
Cooling | Fuma 2 |
Memory | 4x32GB 3200MHz Corsair LPX |
Video Card(s) | 2x RTX 3090 |
Display(s) | LG 42" C2 4k OLED |
Power Supply | XPG Core Reactor 850W |
Software | I use Arch btw |
I don't think it'd benefit much from integrated memory, but it is going to use soldered memory anyway (LPDDR5X), which is hella fast.This particular halo APU would be great in the form of a SOC like the Apple Silicons, with memory integrated in the same chip.
Yes, it will be beyond expensive, but given how Ngreedia got away with their halo offerings prices, who knows.
Or, maybe using quad memory channels, instead of dual.
It also uses something akin to "quad channel", since it's a 256-bit bus, double of what you have on your consumer desktop (128-bit at dual-channel), that's the most interesting part of this product IMO.
DDR5 muddied the terms a bit.I read something similar.
Since it is using DDR5, which is dual channel per dimm (or something like that, bit rusty in the subject) thats why its showing as such.
But I dont know if this can be compared to a proper quad channel system, like whats used with ThreadRippers, for example.
Before DDR5, there was kind of a convention to call a 64-bit bus a "channel", since that was the norm for what we had in a single stick/mobo slot. 2 sticks in different channels? 128-bit, or the so called "dual-channel".
Now with DDR5 each DIMM/channel has 2x "sub-channels" of 32-bit each, but your total bus size is still 128-bit when using 2 sticks, so nothing changed.
Threadrippers, as an example, have a bus width of 256-bit (4x64-bit) for the non-Pro variants, and 512-bit (8x-64-bit) for the pro ones.
Strix halo has a 256-bit bus, so it'd be similar to what we call a quad-channel system.
