AMD Updates its Statement on Radeon RX 480 Power Draw Controversy
bug
14,137 (3.96/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Not quite. There, only review samples had higher clocks. Here, they all have them higher...
You mean, all cards are advertised as 150W parts while drawing ~165W? And that's ok?
1,288 (0.20/day)
System Name Firebird
Processor Intel i7 2600K @5.0'ish 24/7 stock core Voltage {5.2 w/102 bCLK}
Motherboard Intel Extreme DZ68BC SkullTrail Z68 Cougerpoint, Excellent MCH !
Cooling Scythe NINJA PLUS Rev.B[skt478] Modded to 1155 Scythe SH12 fan
Memory Samsung 32nm 16Gb 4x4 (@19xxmhz} low profile[ better than 2133 banwidth]
Video Card(s) Gigabyte Aurosus 1080Ti
Storage Intel 512 SSD,Samsung 9701Tb, Toshiba 3Tbx2,Hitachi 320,1TBx2,'Cuda 400 7200.10, WD1TBUSB,to SATA
Display(s) Acer K272HUL 1440 27" WQHD, Samsung 226W, Vizio M60C3 4K 60",Vizio XVT3D554SV
Case CoolerMaster HAF 932
Audio Device(s) Intel 10ch[9+1] HD Audio X540> Pioneer VSX39TX[copper chasis,Rosewood sides 5x6LCD remote
Power Supply Seasonic X750 @ 24/7
Mouse Logictech G300s
Keyboard Saitek Cyborg v7
Software Windows 7 ROG E3 X64 by Neuropass/tweakscene
Benchmark Scores 4642@665/1600 220/GAT F1 4544 220/667strap 2.5/3/2/6 Bliss 650/1500 6490 Q6700 Bliss 690/1500
The PCI-E spec is designed to handle more than 75 Watt reference spec.
o_OConfused :confused: So when it {SIG} revised the spec up from the 25w to allow 75w total[12v+3.3v] where is this allowing the 12v to be over 75w not including the 3.3v already there.
From what I seen this is the only card found that has had an equal draw from both slot and cable. [BTW I really like this card !]
So if it's been revised to allow 150w thru the slot why can't that be found ?
501 (0.15/day)
Skopje, Macedonia
System Name The Tesseract Cube
Processor AMD Ryzen 5 3600
Motherboard MSI X570A-PRO
Cooling DeepCool Maelstrom 240mm, 2 X DeepCool TF120S (radiator fans), 4 X DeepCool RF120 (case fans)
Memory 2 x 16gb Kingston HyperX 3200mhz
Video Card(s) Sapphire Radeon RX 6800 Nitro + 16GB
Storage Corsair MP400 G3 1TB, Western Digital Caviar Blue 1TB
Display(s) MSI MAG241C Full HD, 144hz FreeSync
Case DeepCool Matrexx 55
Audio Device(s) MB Integrated, Sound Blaster Play 3 (Headset)
Power Supply Corsair CX650M Modular 80+ Bronze
Mouse Corsair Dark Core Pro Wirless RGB
Keyboard MSI GK30 Mecha-Membrane
Benchmark Scores CPUZ: Single Thread - 510 Multi Thread - 4.050 Cinebench R20: CPU - 3 500 score
So instead of trying your motherboard, now you can choose to fry your PSU instead.
HAHAHA, nice one, Mr. PSU Expert.
A 6pin gpu connector can provide up to 200W of power, so even if the 480 does not draw power from PCI Slot, it would still be enought and will run the card, and not damage your power plug or PSU.
12V rail can provide the power the card needs to run only on that 6 pin connector alone.
I for one would try a different solution:
Why not design a custom PCB for this card and route all power to the chips to come from the 6 or 8 pin connector, and exclude PCI power?
Asus, MSI, Sapphire could do that and instead of 6 pin, go for an 8 pin for better power delivery, since 8 pin is rated at 150W per connector, and max it can go is 300W???
255 (0.07/day)
Lurking over a keyboard ...
Cooling Custom WC
Memory Crucial Ballistix Sport LT 3200MHz C16 @ 3800MHz C16
Video Card(s) Sapphire RX 7900 XTX (MBA)
Storage 2x SN770 2TB, 4x 870 EVO 4TB
Display(s) Asus MG279Q
Case Be Quiet Dark Base 900 (Mods: Front mesh panel, improved top panel for airflow)
Audio Device(s) On-board
Power Supply CoolerMaster V850
Mouse Logitech G700S
Keyboard Cherry MX-Board 3.0
Software Win 10 Pro x64
Benchmark Scores https://www.3dmark.com/fs/29041947 https://www.3dmark.com/3dm/84973091
I think they've actually said they are doing two things (as well as the original draw being a non-issue as you mention):
1. Lowering the power draw from the PCIe slot (they didn't say by how much or if there was a penalty for that, benching will confirm) and this will be enabled as standard.
and separately:
2. Adding an option to reduce overall power by "some amount" at a cost to performance that should be off-set by a claimed 3% improvement in driver performance, assuming your game of choice is one of the "uplifted" ones.
Number 1 will be the most interesting to see the results of; how much have they reduced the PCIe slot power use and is the overall use now the same just with some amount moved to the PCIe power connector on the card and how has this affected performance, in theory, on the uplifted games, performance should be 3% better than the launch reviews.
Another question is if overall TDP/TBP has changed.
We should know more in a couple of days. ;)
For 1 this is the information we currently have, the current ref RX 480 PCB design is such that the IR3567B loop 1 (6 phases) is controlling the mosfets that supply GPU VDDC. Now the 6 phases are split 50/50 between PCI-E slot/plugs, we have independent 2 power planes, there is no "chip" on PCB that can adjust supply source to mosfets but IR3567B can do load balancing independently per phase so basically The Stilt's fix is lowering the ratio of loading capability of 3 phases supplied by PCI-E slot and shifting it to the 3 phases supplied by PCI-E plug. If there was any other method he could employ I would think he would have done that, especially with his experience and knowledge of AMD products. This is basically what I think AMD will do to reduce current/power usage from PCI-E slot. This does not effect how much power the GPU will draw or what voltage it will use, nor will it's performance be limited but what it does mean is 3 phases are being loaded more, you could depending on GPU properties/how much you push card for OC'ing hit OCP limit.
For 2 my opinion is this, PowerPlay in ROM has PowerTune table, which contains PowerLimit. These values are TDC/TDC/MPDL.
TDP: "Change TDP limit based on customer's thermal solution"
TDC: "PowerTune limit for maximum thermally sustainable current by VDDC regulator that can be supplied"
Maximum Power Delivery Limit (MPDL): "This power limit is the total chip power that we need to stay within in order to not violate the PCIe rail/connector power delivery"
These values limit GPU only not any other board elements (RAM,etc). TDC does not do any load balancing or differentiate between phases on VRM. MPDL does not differentiate between where power is drawn (ie slot/plugs). So AMD maybe implementing tweak of these settings in OS once driver load, as this is what we do when we change PL in OD/TriXX/MSI AB.
They may implement PowerTune algorithm tweak. Without delving too much into this I'll present an example based on 2 programs I experienced this on Fiji. In driver at x point they exposed a feature called "Power Efficiency". Prior to this setting being available I would adjust PL in ROM/OS to max, 3DM FS would run at max GPU clock but Heaven would show some clock dropping, with PE=Off no clock drop in Heaven. I was never reaching A/W/temps issue to make GPU drop clocks in Heaven with PE=On, so it has lead me to believe an aspect of PowerTune algorithm is being tweaked when I set PE=Off.
Just like you said I would agree it would be at a cost of performance which they are giving back in "some" titles for fix/point 2.
Now getting back to GPU properties, mainly leakage, higher leakage ASIC will draw more power. So you will have some cards not benefiting as much from the shift of load on phases to reduce PCI-E slot power usage. Like wise a higher leakage ASIC will reach PowerTune/Limit sooner under load so the owner may see more of a performance loss. IMO owners of lower leakage ASIC will benefit more from these fixes in context of "issue" and will be somewhat drawing less power as a whole at "stock".
When W1zzard tested The Stilt's tweak it drew ~10W less on PCI-E slot, which will be soon consumed by some OC'ing.
IMO the fixes are not "ideal" considering this is card which has PCI-E plug and by this I mean no disrespect to The Stilt, W1zzard and others involved with it. The ref PCB needs a redesign to be inline with what recent past AMD cards drew on PCI-E slot or to substantially reduce PCI-E slot power usage.
My apologies to members for mega long post.
4,357 (0.88/day)
Mexico
System Name Dell-y Driver
Processor Core i5-10400
Motherboard Asrock H410M-HVS
Cooling Intel 95w stock cooler
Memory 2x8 A-DATA 2999Mhz DDR4
Video Card(s) UHD 630
Storage 1TB WD Green M.2 - 4TB Seagate Barracuda
Display(s) Asus PA248 1920x1200 IPS
Case Dell Vostro 270S case
Power Supply Dell 220w
Software Windows 10 64bit
I guess math isn't your strong point. The card currently consumes more that the compliant 150W (~165W). If you limit PCIe input to <75W, then you end up drawing >75W from the 6 pin connector. Which is still outside the spec. So instead of trying your motherboard, now you can choose to fry your PSU instead.
The only sane thing to do is make the thing draw 150W as advertised.
The PSU cables can withstand the current. Take a look at your PSU's 6+2 pin cable: the extra 2 pins don't even have their own wires, they are just bridged from the existing ones so when you use it for an 8 pin card only 6 wires are connected directly to the PSU
The 6 pin connector can safely draw an extra 16w without caching fire or anything.
Also, AMD didn't say that the card would draw 150w (total board power) just that the card TDP was 150w (not the same thing as power consumption).
Anyway, if you're so concerned about going over the PCIe specification you can turn on the toogle to limit the power draw to 150w.
872 (0.14/day)
Copenhagen, Denmark
System Name Ryzen/Laptop/htpc
Processor R9 3900X/i7 6700HQ/i7 2600
Motherboard AsRock X470 Taichi/Acer/ Gigabyte H77M
Cooling Corsair H115i pro with 2 Noctua NF-A14 chromax/OEM/Noctua NH-L12i
Memory G.Skill Trident Z 32GB @3200/16GB DDR4 2666 HyperX impact/24GB
Video Card(s) TUL Red Dragon Vega 56/Intel HD 530 - GTX 950m/ 970 GTX
Storage 970pro NVMe 512GB,Samsung 860evo 1TB, 3x4TB WD gold/Transcend 830s, 1TB Toshiba/Adata 256GB + 1TB WD
Display(s) Philips FTV 32 inch + Dell 2407WFP-HC/OEM/Sony KDL-42W828B
Case Phanteks Enthoo Luxe/Acer Barebone/Enermax
Audio Device(s) SoundBlasterX AE-5 (Dell A525)(HyperX Cloud Alpha)/mojo/soundblaster xfi gamer
Power Supply Seasonic focus+ 850 platinum (SSR-850PX)/165 Watt power brick/Enermax 650W
Mouse G502 Hero/M705 Marathon/G305 Hero Lightspeed
Keyboard G19/oem/Steelseries Apex 300
Software Win10 pro 64bit
the horror will never end...
they have a fix people.. relax. or dont buy the damn card if you are so concerned. can we please just move along..
Air
203 (0.05/day)
Processor AMD Ryzen 5600X
Motherboard B550i AORUS PRO AX
Cooling Noctua NH-D9L
Memory 2 x 16Gb G.Skill Trident Z Neo 3600 MHz C16
Video Card(s) EVGA GTX 1070 SC
Storage Samsung 980 Pro 1 Tb
Case Ncase M1 V3
Power Supply Corsair SF600 Gold
Benchmark Scores CPU-Z: 655.8 single, 4999.7 multi Cinebench R23: 1563 single, 11275 multi
Is it really necessary for AMD to target its reference designs so close to the limit?
290x with jet engine cooler that cant keep temperatures bellow 90 ÂşC, 480x with 6-pin, but needs 8-pin and goes off spec.
Is the bad press they get from this stuff really worth the savings?:confused:
4,357 (0.88/day)
Mexico
some people are saying that this will increase the load on the 6 pin VRMs and cause damage to them. My gosh, the VRMs are overspecified, each phase can provide 40w (240w total) so even if the PCIe VRMs are underused the 6pin VRMs can take the heat. Heck, AMD could disable one of the phases entirely and the card would still get more than enough power and stay within the VRMs limits.
AMD was very stupid for letting this happen even if the fix was trivial. While I don't think it will impact RX 480 sales a lot this will just give nVidia more fodder for when the GTX 1060 launches. They had a homerun in their hands and let it slip between the cracks.
I've already bought one, should be shipped on the 12th when amazon gets more stock. I guess I'll watch ebay and look for an used one for cheap, pretty sure some people will dump 480s after the 1060 becomes available.
2,748 (0.54/day)
Greece
Motherboard MSI B550 Tomahawk
Cooling ZALMAN CNPS9X OPTIMA
Case SHARKOON M25-W 7.1 BLACK
Keyboard Trust GXT280
Who can be so stupid to sell his RX480 for a 1060? If he was a green fanboy he wouldn't buy it from the start. If he isn't a fanboy he will keep it just because it's the best VFM GPU for the last many years. :)
4,357 (0.88/day)
Mexico
I'm sure some will. Perception is reality, they say. Right now the perception is that AMD is selling hardware that could damage your system... of course, people like you and me know better but that's not the case for most people.
Anyway, I'm sure it won't affect AMD much but why give munition to your critics in the first place?
872 (0.14/day)
Copenhagen, Denmark
you can always trust on the stupidity of people.. ;)
3,901 (0.81/day)
Processor AMD Ryzen 7 5700X3D
Display(s) Hisense 55" U7K
Case Antec 1200
Mouse Razer Deathadder Chroma
Keyboard Logitech UltraX
Wonders never cease my friend.
3,992 (0.61/day)
Maryland
System Name HAL
Processor Core i9 14900ks @5.9-6.3
Motherboard Z790 Dark Hero
Cooling Bitspower Summit SE & (2) 360 Corsair XR7 Rads push/pull
Memory 2x 32GB (64GB) Gskill trident 6000 CL30
Video Card(s) RTX 4090 Gigagbyte gaming OC @ +200/1300
Storage (M2's) 2x Samsung 980 pro 2TB, 1xWD Black 2TB, 1x SK Hynix Platinum P41 2TB
Display(s) 65" LG OLED 120HZ
Case Lian Li dyanmic Evo11 with distro plate
Audio Device(s) Klipsh 7.1 through Sony DH790 EARC.
Power Supply Thermaltake 1350
Software Microsoft Windows 11 x64
omg you're annoying.
The toggle is off by default, so reviewers would have to re-run the card not in the default setting, which they never do. But no doubt they will this time because of the beatup around this issue
Like I said from the start this whole issue is a beatup. AMD is saying what I said, they are confident the power draw will not damage hardware.
Hardware specs are waaaay on the conservative side. Thats why we can overclock the crap out of our computers and not do damage. The PCI-E spec is designed to handle more than 75 Watt reference spec. Much more. Same with the 6 pin and 8 pin plugs, they can handle double the power of the spec.
If people think an extra 10% or 15% is going to destroy a motherboard, they have no idea how things work.
Get over it..
5,469 (0.88/day)
Australia
Glad for you Red Team owners, hopefully no more burned mobo's!
Can you link me to a thread or video that has shown someone that has had a burnt out mobo? I havent seen any yet, people talk about it but I still havent seen any evidence to support it.
184 (0.06/day)
"Already they have begun to see cases of damaged motherboards"
Really it is not, so you have to grab it with tweezers, and in some cases of those who have caused so much uproar in the network, then we have seen (when reviewing pictures of the burnt motherboard) riding three graphics cards providing only 2 PCI Express slots with adapters extensors-because I was doing mining bitcoins 24 hours seven days a week, and when installing new graphics board was loaded. This case is one of the most publicized, but it was really out of spec to start was the user.
But of course that did not stop him putting together all possible disturbance in the network, although the logical thing would be that high demand for energy that should have started by buying a plate with three PCI Express slots for the three graphs mounted.
cadaveca
My name is Dave
17,232 (2.50/day)
Fiery (AIDA dev) posted a link in an earlier thread.
bug
14,137 (3.96/day)
Maybe they can, but the PCIe still says 75W from the slot and another 75W from the 6 pin connector, so the card would still be running outside specs. Of course, this is more of a PCI-SIG failure, because they have certified a card that's not actually compliant, but what do they care? They're not the one selling video cards so they're not the ones catching flak.
777 (0.16/day)
Norway
System Name Games/internet/usage
Processor I7 5820k 4.2 Ghz
Motherboard ASUS X99-A2
Cooling custom water loop for cpu and gpu
Memory 16GiB Crucial Ballistix Sport 2666 MHz
Video Card(s) Radeon Rx 6800 XT
Storage Samsung XP941 500 GB + 1 TB SSD
Display(s) Dell 3008WFP
Case Caselabs Magnum M8
Audio Device(s) Shiit Modi 2 Uber -> Matrix m-stage -> HD650
Power Supply beQuiet dark power pro 1200W
Mouse Logitech MX518
Keyboard Corsair K95 RGB
If the plug can handle 75 W at 12+3.3 it can handle more at 12 V alone.
The reason would be this: electrical transmission losses are as flows: I*I*R=P,
R is resistance in the plug, stays the same at 3.3 V or 12 V
I is current, and at the same power for 3,3 V and 12 V the current will be 3,6 = (12 V/3.3V) times higher, the loss in one 3.3 V pinn will therefore be 13 = (3,6 * 3,6) times higher than in a 12 V pin.
The 3.3 V pins cannot be used at 12 V pins, but without the added heat from the 3,3 V pins the 12 V pins will have more power headroom , as the whole plug will be cooler.
753 (0.17/day)
System Name Chaos
Processor Intel Core i5 4590K @ 4.0 GHz
Motherboard MSI Z97 MPower MAX AC
Cooling Arctic Cooling Freezer i30 + MX4
Memory 4x4 GB Kingston HyperX Beast 2400 GT/s CL11
Video Card(s) Palit GTX 1070 Dual @ stock
Storage 256GB Samsung 840 Pro SSD + 1 TB WD Green (Idle timer off) + 320 GB WD Blue
Display(s) Dell U2515H
Case Fractal Design Define R3
Power Supply Corsair HX750 Platinum
Mouse CM Storm Recon
Keyboard CM Storm Quickfire Pro (MX Red)
The official limit for 3.3V is 9.9W, or up to 3A. 3.3V supply line has 4 pins at its disposal. Thus, 0.75A per pin maximum.
The 12V limit is actually officially 66W or 5.5A. Given five pins for power transmission, this is 1.1A per pin maximum.
Also, take a look at your formula again, it correctly says dissipated power = current squared times resistance.
12V line is allowed more current per pin than 3.3V line is...
422 (0.09/day)
Hungary
System Name masina
Motherboard ASUS TUF B550M
Cooling Scythe Kabuto 3 + Arctic BioniX P120 fan
Memory 16GB (2x8) DDR4-3200 CL16 Crucial Ballistix
Video Card(s) Radeon Pro WX 2100 2GB
Storage 500GB Crucial MX500, 640GB WD Black
Display(s) AOC C24G1
Case SilentiumPC AT6V
Power Supply Seasonic Focus GX 650W
Mouse Logitech G203
Keyboard Cooler Master MasterKeys L PBT
I've never had a PC full of dust, and the dust causing a PCIe slot to get burnt and become inoperational. Dust is not good, I grant you that, but it rarely cause any hardware failures. Except when the dust fills up a heatsink and that causes overheating.
That might be true and all, but you might want to ask yourself how does this individual handle his PC components? I'm guessing with not much care at all as it seems...
I'm sorry but, when the insides of your computer looks like a cat lives in it, with the accompanying fur, piss and god knows what else deposited on your motherboard, then any sort of HW failure claims are nullified in my eyes.
777 (0.16/day)
Norway
the loss in one 3.3 V pinn will therefore be 13 = (3,6 * 3,6) times higher than in a 12 V pin at the same power transfered.
was mostly just thinking it out while typing, and what is there to look at?
even with the 12 V pins beeing alowwed more A than a 3.3 V pin i still think the slightly to big power draw problem is blown out of proportions.
1,079 (0.22/day)
Indonesia
Processor AMD Ryzen 7 7900
Motherboard Gigabyte B650M AORUS PRO AX
Cooling Thermalright Peerless Assassin 120
Memory G.SKILL Flare X5 DDR5-6000 64GB (2x32GB)
Video Card(s) MSI RTX 3090 24GB
Storage 2 TB WD Black SN850X | 2 TB WD Blue SN570 | 10 TB WD Purple Pro
Display(s) Xiaomi G27Qi 27" 2K QHD IPS 180Hz
Case Fractal Design Define R5 Black
Power Supply SEASONIC FOCUS PLATINUM PX-850 850W
Mouse Fantech Helios II Pro S
Keyboard KIRA EXS
1,288 (0.20/day)
Source? It's already been raised from 25 to the 75, so that say's the plug is maxed out now..
Also from reading thru the spec they only allowed that since there is better convection cooling with newer PC's
4,357 (0.88/day)
Mexico
Just read the link okidna posted. I guess we can put all of this behind and enjoy our 480s :D
I plan to enable the compatibility mode, undervolt the core and overclock the memory as much as possible.
