ARCTIC COOLING Freezer 7 Pro Rev.2 92mm Fluid Dynamic CPU Cooler
Exile_Chavez
283 (0.05/day)
System Name Build 1
Processor AMD Phenom II X4 955 3.2ghz
Motherboard MSI 770-C45 AM3 AMD 770 ATX AMD Motherboard
Cooling Xigmatek Dark Knight, 3 120mm Intakes, 1 200mm Exchaust, 2 140mm Exchausts
Memory OCZ Gold 4GB 240-Pin DDR3 1333mhz
Video Card(s) XFX HD-577A-ZNDC Radeon HD 5770 XXX Edition 1GB 128-bit DDR5 PCI Express 2.0 x16 HDCP
Storage WD Blue 640GB 7200 RPM
Display(s) ACER 23" Full HD HDMI Widescreen Monitor
Case NZXT Phantom Black
Audio Device(s) None
Power Supply OCZ StealthXStream 700W ATX12V/EPS12V SLI Ready Crossfire Ready
Software Windows 7 Home Premium 64-bit
Hello tech power up forums. I am a new member, so excuse me if I offend any unspoken rules. I own a AMD 3.2Ghz Quad CPU, and am a little unhappy with my idle temperature of ~38*C. I have read reviews of idle temps for this CPU down in the mid 20*Cs. I have looked into this CPU cooler quite a lot now, and am wondering if anyone would be able to tell me whether or not it would be worth purchasing. I am aiming for around 30*C idle. Just for additional info, max load(as in all 4 cores at >90% for 5 mins) brings me to a large 55*C. I have no overclock on my CPU, and the current cooler is the stock that came with it. Below is a link to the CPU cooler I am looking at: http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
Please aid me in this decision. And if by chance you know this CPU cooler is sucks, then if you could recommend another, but try and keep the price.
9,899 (1.69/day)
Essex, England
System Name My pc
Processor Ryzen 5 3600
Motherboard Asus Rog b450-f
Cooling Cooler master 120mm aio
Memory 16gb ddr4 3200mhz
Video Card(s) MSI Ventus 3x 3070
Storage 2tb intel nvme and 2tb generic ssd
Display(s) Generic dell 1080p overclocked to 75hz
Case Phanteks enthoo
Power Supply 650w of borderline fire hazard
Mouse Some wierd Chinese vertical mouse
Keyboard Generic mechanical keyboard
Software Windows ten
Its a basic after market cooler, should take you down to 25-28c idle, depends on your ambient temperature.
Exile_Chavez
283 (0.05/day)
System Name Build 1
If you could please, what is ambient temperature? Then I could probably tell you more. And is there a cooler you recommend?
Easy Rhino
Linux Advocate
15,638 (2.35/day)
Mid-Atlantic
System Name Desktop
Processor i5 13600KF
Cooling Noctua NH-U9S
Storage WD_BLACK 4TB SN850x
Display(s) Gigabye M32U
Case Corsair Carbide 400C
Audio Device(s) On Board
Mouse MX Master 3s
Software Fedora KDE Spin
i owned that cooler and never really liked its performance. however, before you find a new one consider your case temps.
Kursah
Super Moderator
14,733 (2.21/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
The ACF7P is decent for lightly OC'd quads and OC'd duals, but beyond that you may need a little more cooling oomph if you decide to really push OC's. Really idle temp isn't a big deal and shouldn't be, load temps are where you need to pay attention. Sure it's nice to see uber low idle temps, but in reality if your load temps are acceptable, it doesn't matter in that respect.
That cooler would treat you well, I've used it on many builds with dual core and quad core Intel chips all OC'd. Even at full blast the fan isn't very noisy.
Ambient Temp is the temperature of the area/room the PC is located in. Airflow in your case is another good place to examine cooling potential, if you have crap airflow or clogged airflow, odds are a better cooler won't net you a lot better in that respect, if your case can't get rid of the warm/hot air the cooler is exhausting, then you'll see similar results you do now.
theonedub
habe fidem
8,027 (1.40/day)
Northern CA, USA
System Name Erakith || AsRock NUCS
Processor AMD ThreadRipper 2990WX ES (32c/64t 3.5ghz@1.02v) || Intel i7 1360P Raptor Lake-P
Motherboard MSI X399 MEG Creation || AsRock OE
Cooling EK Supremacy TR4 Full Nickel, D5 w/ EK Top, 2X EK-CoolStream XTX 360 & Photon 270 Res || OE
Memory 32GB (4x8GB) Corsair Vengeance PRO RGB DDR4 3000|| 2x16GB Corsair DDR4
Video Card(s) Vega 64 EK FC|| Intel Iris Xe
Storage 250gb WD Black NVMe & (2) 2TB Intel 660p NVMe || 2TB Corsair MP600 Pro
Display(s) 34" Dell Ultrasharp U3415W
Power Supply Corsair HX1000
Software Windows 10 Pro x64 || WIndows 11 Pro x64
Exile_Chavez
283 (0.05/day)
System Name Build 1
I actually have very nice airflow. With 2 250mm Case fans(side and front) each shoving about 105CFM. Ambient temp would be anywhere from 67*F-75*F. I do though have some wires in places I don't want them, but that is a self fix.
I am also getting a 120mm rear exhaust fan, I will probably get this CPU cooler now that I have feedback.
Exile_Chavez
283 (0.05/day)
System Name Build 1
Excluding the Xigmatek brand CPU coolers(because I looked at most of the ones there, and none appear to be AM3 compatible). Can anyone recommend a good one for me?
Full CPU specs: (thank you newegg)
-Model
-Brand AMD
-Processors Type Desktop
-Series: Phenom II X4
-Model: HDZ955FBGIBOX
-CPU Socket Type: Socket AM3
-Core: Deneb
-Multi-Core: Quad-Core
-Name: Phenom II X4 955 Black Edition
-Operating Frequency: 3.2GHz
-Hyper Transports: 4000MHz
-L2 Cache 4 x 512KB:
-L3 Cache 6MB:
-Manufacturing Tech: 45 nm
-64 bit Support: Yes
-Hyper-Transport Support: Yes
-Virtualization Technology Support: Yes
-Voltage: 0.875V - 1.5V
-Thermal Design Power: 125W
1,793 (0.32/day)
System Name Old Skool
Processor E6750 @ 3.6 ghz
Motherboard GA P35 DS3L
Cooling Xigmatek Dark Knight S1283v
Memory 4gb Kingston DDR2 @ 900mhz
Video Card(s) XFX 9800GT 512MB
Storage SAMSUNG 320gb
Display(s) VIEWSONIC vx2260wm
Case HAF 922
Audio Device(s) Realtek (on board) + Logitech x540
Power Supply CM 550w
Software W7 Ultimate 64
Xigmatek dark knight, does wonders with amd cpus. And yes, am3 is compatible (am2+)
theonedub
habe fidem
8,027 (1.40/day)
Northern CA, USA
The thread I linked to advised the DK and that person has an AM3 CPU too :laugh:
1,793 (0.32/day)
Case HAF 922
For $40, it does a pretty good job. Get the DK, you won't regret it. Plus it has leds and has a black coating which gives it good looks.
1,745 (0.26/day)
The Nevada Wasteland
System Name 9th Level
Processor AMD Ryzen 5 5600X
Motherboard MSI X570 Carbon wifi
Cooling EK Basic 360, x2 250mm, x1 140mm, x1 120mm fans.
Memory 32GB Corsair Vengeance 3200mhz.
Video Card(s) EVGA RTX 3080 12GB FTW3
Storage 500gb ssd, 2tb ssd, 6tb HD.
Display(s) MSI 27" Curved 1440p@165hz
Case HAF 932
Power Supply Corsair HX850W
Software Windows 10 64bit
NO it wont, I have used it.
I suggest The Xigmatek. I have a Xigmatek Thor's Hammer and the idle is 35C after Idling for hours and max load temp with 98% CPU usage is 49C.
AM2+ and AM3 are compatible cooler wise.
Exile_Chavez
283 (0.05/day)
System Name Build 1
hmm... the coolers i looked at didn't say AM3. Weird.
But anyways, looked at the DK cooler, and that looks hot. Like amazing looking. Ill look into it some more.
theonedub
habe fidem
8,027 (1.40/day)
Northern CA, USA
The AM2/AM3 bracket and mounting holes on the motherboard are identical. The DK is strong, mine cooled my Q9550 well and will be going on my i7 shortly.
1,793 (0.32/day)
Case HAF 922
They dont label it as am3 as it basically has the same spacing as am2+.
BUCK NASTY
4P Enthusiust
5,015 (0.79/day)
Fort Pierce, FL. U.S.A.
System Name Main Rig
Processor AMD RYZEN 5600X
Motherboard MSI MPG X570 GAMING EDGE WIFI
Cooling CORSAIR H115i
Memory 16gb DDR4 @ 1200MHZ
Video Card(s) GIGABYTE RTX 4080 SUPER
Storage SAMSUNG M.2 1TB
Display(s) ASUS 24" IPS
Case Coolermaster Centurion 590
Power Supply EVGA SUPERNOVA 1000
Exile_Chavez
283 (0.05/day)
System Name Build 1
Theonedub, do you have numbers by chance on how much it keeps it? And if by chance original with stock?
Also I have a program open right now, and it says I am, <10% load and at 38*C. So an estimate would be great.
1,793 (0.32/day)
Case HAF 922
Use a program like prime95 to eat all the raw power of your cpu to get full load temps. <10% load ain't gonna heat your cpu that much.
Exile_Chavez
283 (0.05/day)
System Name Build 1
Ill look at that. But I was just giving some info on small load temps.
theonedub
habe fidem
8,027 (1.40/day)
Northern CA, USA
Exile_Chavez
283 (0.05/day)
System Name Build 1
Sweet. Thanks guys for the help. Ill post back if I need help. Im convinced on the DK now.
1,793 (0.32/day)
Case HAF 922
Sound decision, i just bought one miself! One more thing though, its a pretty high cooler, so check if it will fit your case.
Exile_Chavez
283 (0.05/day)
System Name Build 1
I am not really sure how to do that really. Or rather I would like a double check. I have the Xclio A380BK. If someone could double check me on that, many thanks.
Kursah
Super Moderator
14,733 (2.21/day)
Missoula, MT, USA
It's a full tower, I would assume as long as your side panel is loaded with fans you should be just fine, I've fit the Xig S1283 (non DK) in many cases from mid to full tower w/o much issue. I did have to remove my side fan on my old Antec 900 when I used a Scythe 120x38mm fan on the Xig cooler though. But stock there were no issues, had about 1cm of clearance lol.
Looking at that case I would assume you'd be ok to go for it.
Exile_Chavez
283 (0.05/day)
System Name Build 1
Cool. Thank you all for the help
