ARCTIC COOLING Freezer 7 Pro Rev.2 92mm Fluid Dynamic CPU Cooler
9,899 (1.69/day)
Essex, England
System Name My pc
Processor Ryzen 5 3600
Motherboard Asus Rog b450-f
Cooling Cooler master 120mm aio
Memory 16gb ddr4 3200mhz
Video Card(s) MSI Ventus 3x 3070
Storage 2tb intel nvme and 2tb generic ssd
Display(s) Generic dell 1080p overclocked to 75hz
Case Phanteks enthoo
Power Supply 650w of borderline fire hazard
Mouse Some wierd Chinese vertical mouse
Keyboard Generic mechanical keyboard
Software Windows ten
NO it wont, I have used it.
I suggest The Xigmatek. I have a Xigmatek Thor's Hammer and the idle is 35C after Idling for hours and max load temp with 98% CPU usage is 49C.
AM2+ and AM3 are compatible cooler wise.
I've had 3, all worked a charm.
Exile_Chavez
283 (0.05/day)
System Name Build 1
Processor AMD Phenom II X4 955 3.2ghz
Motherboard MSI 770-C45 AM3 AMD 770 ATX AMD Motherboard
Cooling Xigmatek Dark Knight, 3 120mm Intakes, 1 200mm Exchaust, 2 140mm Exchausts
Memory OCZ Gold 4GB 240-Pin DDR3 1333mhz
Video Card(s) XFX HD-577A-ZNDC Radeon HD 5770 XXX Edition 1GB 128-bit DDR5 PCI Express 2.0 x16 HDCP
Storage WD Blue 640GB 7200 RPM
Display(s) ACER 23" Full HD HDMI Widescreen Monitor
Case NZXT Phantom Black
Audio Device(s) None
Power Supply OCZ StealthXStream 700W ATX12V/EPS12V SLI Ready Crossfire Ready
Software Windows 7 Home Premium 64-bit
So I ordered the Xigmatek Dark Knight last Wednesday, from newegg of course along with some Artic Silver 5, and the thermal remover and purifier.
Came in today, and I realized just how freakin big this thing is. I have an Xclio A380BK Super Tower, and it didn't fit.
So I took an industrial drill to my side fan, the rear guard, and that didn't work. So I ghetto rigged it.
I grabbed some duct tape, and reverse mounted my fan on the outside of the case, with the duct tape, and it works fine.
My temps are down from: (all Celsius)
Ambient: ~70F
Idle:
-Stock: 39
-Dark: 32
100% Full Load:
-Stock: 58-60
-Dark: 45
So it was worth the money, and the rigging. I would recommend this cooler to anyone without a massive side fan.
1,793 (0.32/day)
System Name Old Skool
Processor E6750 @ 3.6 ghz
Motherboard GA P35 DS3L
Cooling Xigmatek Dark Knight S1283v
Memory 4gb Kingston DDR2 @ 900mhz
Video Card(s) XFX 9800GT 512MB
Storage SAMSUNG 320gb
Display(s) VIEWSONIC vx2260wm
Case HAF 922
Audio Device(s) Realtek (on board) + Logitech x540
Power Supply CM 550w
Software W7 Ultimate 64
Happy for you man! I'm actually waiting for mine. I guess I'll have to wait a couple of weeks more! Nail biting moments indeed haha! ;)
Exile_Chavez
283 (0.05/day)
System Name Build 1
I hope you have space!
1,793 (0.32/day)
Case HAF 922
It should fit in nicely since I have a large case.
Exile_Chavez
283 (0.05/day)
System Name Build 1
Has it arrived yet? I would like to know you system temp changes to compare
crazyeyesreaper
Not a Moderator
9,819 (1.70/day)
System Name Old reliable
Processor Intel 8700K @ 4.8 GHz
Motherboard MSI Z370 Gaming Pro Carbon AC
Cooling Custom Water
Memory 32 GB Crucial Ballistix 3666 MHz
Video Card(s) MSI RTX 3080 10GB Suprim X
Storage 3x SSDs 2x HDDs
Display(s) ASUS VG27AQL1A x2 2560x1440 8bit IPS
Case Thermaltake Core P3 TG
Audio Device(s) Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset
Power Supply Zalman EBT-1000
Mouse Mionix NAOS 7000
Keyboard Mionix
i have a Dark Knight it will let me 940 safely run up to 3800mhz pumping up to 1.55volts
AM2+ and AM3 are the same basic socket therefore any cooler that fits AM2 Am2+ will fit AM3
the Xigmatek Darknight is a great mid range cooler it will cool your cpu far better
the artic cooling Freezer 7 pro is good for dual cores tri and quads it cant handle the heat and it fails to do its job that simple
the 940BE puts out the same heat as a 955BE so if i can hit 3.8ghz and stay under 62'c core in a 90'f + room it will handle your cpu without issue again cant stress enough the Freezer 7 had its hay day in the time of overclocked dualcores for quads it just isnt up to snuff and can't even compete with stock AMD coolers for the Phenom II line
1,793 (0.32/day)
Case HAF 922
Nopes, shipping from the us to my country takes ages, maybe more 2 weeks of nail biting! Anyways, my temps aren't gonna be the same as yours since my cpu is a dual core but I'd gladly swap info with you! :toast:
Exile_Chavez
283 (0.05/day)
System Name Build 1
Mines actually a stock AMD Phenom II X4 955 3.2GHz AM3 125W Quad Black Edition, not quite a dual, temps would be way lower if it was
Also update on temps(C)
Lowest with Stock: 34
Lowest with DK: 28
(100% load for 10 mins)
Highest with Stock: 58
Highest with DK: 45
7,662 (1.19/day)
c:\programs\kitteh.exe
Processor C2Q6600 @ 1.6 GHz
Motherboard Anus PQ5
Cooling ACFPro
Memory GEiL2 x 1 GB PC2 6400
Video Card(s) MSi 4830 (RIP)
Storage Seagate Barracuda 7200.10 320 GB Perpendicular Recording
Display(s) Dell 17'
Case El Cheepo
Audio Device(s) 7.1 Onboard
Power Supply Corsair TX750
Software MCE2K5
Freezer 7 Pro works for socket 775 (LGA),
two its a bit archaic, i own one, get something HDT
Exile_Chavez
283 (0.05/day)
System Name Build 1
I actually ended up buying the Artic Silver 5, which is work quite well
MKmods
Case Mod Guru
5,697 (0.92/day)
Nevada
System Name Crossflow III
Processor AMD 965 (4.04Ghz)
Motherboard Asus Crosshair III
Cooling Air
Memory 4 gigs Mushkin 7-7-7-20@1T
Video Card(s) single 9800GT
Storage Raptor 150's in Raid0
Display(s) LG Flatron 24"
Case Custom
Audio Device(s) AuzenTech X-Raider W/OP637
Power Supply Custom modded Corsair 750HX
Software Win 7 64/Solaris Utility
Benchmark Scores 3DMark06--21963 so far
more garbage...:rolleyes:
I am running an AC Freezer with a 965 OCd to 4.04Ghz and here are my temps
Now its all fine and dandy if you guys like coolers that have 120mm fans and 2 X the surface area of the freezer but please quit bashing a perfectly good cooler if you dont really know what ur talking about
crazyeyesreaper
Not a Moderator
9,819 (1.70/day)
Keyboard Mionix
then your lucky dont know what to tell you sort of like CD i think it was in the PII overclocking thread where the stock amd cooler was getting ridiculously good temps i honestly dont see how your freezer 7 just slapped on is getting those temps and i dont see 3d mark as a good way to test for temps run LinX for 15 passes then get back to me at my 3600mhz oc gaming i never topped 52'c in my hot room linX id hit 63'c i wouldnt and you couldnt pay me to use a Freezer 7 on a quadcore
and so far its 2 users where the freezer 7 couldnt hold up in terms of temps im guessing since your the modding guru you have a few things tweaked in the case or you have a very low ambient temp
MKmods
Case Mod Guru
5,697 (0.92/day)
Nevada
Cooling Air
Case Custom
My ambient is 75F, and I havent tweaked anything except my freezer is painted (should make it hotter according to the goofballs on the internet). If your case cooling sucks than NO cooler wont work at its peak efficiency.
It has nothing to do with luck, I have sold hundreds of the Freezers just because its a very good cooler.
I have used one in almost every mod I have done and NEVER had a prob with temps ever.
There are other coolers that are quite a bit bigger with much more surface area and larger fans that cool better and thats fine, but there seem to be a lot of goofy people BASHING the Freezer.
If you guys want to say there are BETTER coolers , than fine but the freezer is a perfectly good cooler for 95% of comps...
crazyeyesreaper
Not a Moderator
9,819 (1.70/day)
Keyboard Mionix
2,262 (0.33/day)
Toronto, Ontario
System Name The Expanse
Processor AMD Ryzen 7 5800X3D
Cooling Corsair H150i Pro
Video Card(s) XFX Radeon RX 7900 XTX Magnetic Air (24.12.1)
I also want to see something other then 3dmark used to heat up the cores.... ;)
59 (0.01/day)
System Name alpha
Processor Intel Core i7 4770k
Motherboard Gigabyte GA-Z87X-UD4H
Cooling Prolimatech Armageddon with 2 NF-A15's
Memory 2x4GB Crucial Sport
Video Card(s) integrated HD 4600
Storage Samsung 840 Pro 512GB
Display(s) Acer KN242HYL
Case fractal design Define R5
Audio Device(s) headphones
Power Supply Seasonic x-750
Mouse Logtech Performance MX (wireless)
Keyboard Logitech G810 (backlit wired)
Software Win7-64
I have a Freezer Pro 7. It's nice enough for my non-OC machine, but I got a Megahalems for my OC rig. The FP7 just doesn't cool well enough for OCing.
Any of the towers - Mega, Venomous, etc. - will do fine for OCing, according to the various reviews I've seen.
theonedub
habe fidem
8,027 (1.40/day)
Northern CA, USA
System Name Erakith || AsRock NUCS
Processor AMD ThreadRipper 2990WX ES (32c/64t 3.5ghz@1.02v) || Intel i7 1360P Raptor Lake-P
Motherboard MSI X399 MEG Creation || AsRock OE
Cooling EK Supremacy TR4 Full Nickel, D5 w/ EK Top, 2X EK-CoolStream XTX 360 & Photon 270 Res || OE
Memory 32GB (4x8GB) Corsair Vengeance PRO RGB DDR4 3000|| 2x16GB Corsair DDR4
Video Card(s) Vega 64 EK FC|| Intel Iris Xe
Storage 250gb WD Black NVMe & (2) 2TB Intel 660p NVMe || 2TB Corsair MP600 Pro
Display(s) 34" Dell Ultrasharp U3415W
Power Supply Corsair HX1000
Software Windows 10 Pro x64 || WIndows 11 Pro x64
+1, honestly I have used an AC7 before and my results couldnt be more different. I dont need to see if go through LinX but something a little more CPU intensive please :toast:
MKmods
Case Mod Guru
5,697 (0.92/day)
Nevada
Cooling Air
Case Custom
Its not like I have time to play with you kids...but here it is after 11min while running Burn in test
I would be more inclined to kiss ur butts if any of you had made any contributions to comps other than spouting off stuff you read from other kids that also had little experience
crazyeyesreaper
Not a Moderator
9,819 (1.70/day)
Keyboard Mionix
hmm so your telling me that a 965 thats been heavily overclocked only saw a 3'c rise in temps im gonna call shenanigans try running actual LinX .64 and set it to max ram usage because in all honesty even at stock speeds i see higher temps then that running with the windows open and my room at 65'F when running it so at the end of this i have to call shenanigans either your Freezer 7 is one of a kind or its breaking heat barriers and eating them as a snack along the way because ive honestly never seen a freezer 7 perfrom that well on a quad
MKmods
Case Mod Guru
5,697 (0.92/day)
Nevada
Cooling Air
Case Custom
i
LOL you guys never learn, I dont know if Im special? (who the fu%k am I kidding I fricken rule:rockout:)
But this is in a crappy tower case with no ex fans (other than the PS) and no intake fans either (my Crossflow SFF case is 3-5C cooler). Here it is at 4Ghz with "UR" program after 20 runs
Now I am not trying to say other coolers arent better or the freezer is the best made but Honestly 99% of Freezer owners are perfectly happy with their coolers, just because some goofballs dont know how to properly install a simple cooler or build a computer right thats no reason to slam a very good cooler
newtekie1
Semi-Retired Folder
28,473 (4.06/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Oh man, I'm so glad MKMods was able to come in here and show us his "great" idle temps, otherwise we would have never known how fucking AWESOME the Freezer 7 Pro is!!! And don't anyone dare say differently! He did the same thing in the last thread about the Freezer 7, posted idle temps on a dual core 240 and tried to say because they were low that the cooler is amazing. He also went on to insult the OP because he has higher load temps, with a quad core 955, that the high temps must be due to user error, because he gets such great temps...
Stop spreading trash MKmods, you don't know what the hell you are talking about, the cooler sucks for anything beyond a dual-core, 45°C idle temps is nothing to be proud of!
And I love how your "load" tests actually have temps that are better than your initial idle temps, and you seem to think that is proof of something. BurnIn Test hardly loads the CPU, your lucky to see 55% CPU usage.
Why not do some real load testing and watch the cooler fail?
Just to give everyone an idea:
IdleTemps:
MKmods' "load" temps:
Real load temps:
Most of us will notice the difference, MKmods...not so much...
But yeah, I'm soooo glad that MKmods came in here and set us all straight with his "correct" information about how great the cooler is, and he also managed to do it in a nice civil manor, not being insulting in any way, he really has made a great addition to this thread.:rolleyes:
Polaris573
Senior Moderator
4,268 (0.59/day)
Little Rock, USA
Processor LGA 775 Intel Q9550 2.8 Ghz
Motherboard MSI P7N Diamond - 780i Chipset
Cooling Arctic Freezer
Memory 6GB G.Skill DDRII 800 4-4-3-5
Video Card(s) Sapphire HD 7850 2 GB PCI-E
Storage 1 TB Seagate 32MB Cache, 250 GB Seagate 16MB Cache
Display(s) Acer X203w
Case Coolermaster Centurion 5
Audio Device(s) Creative Sound Blaster X-Fi Xtreme Music
Power Supply OCZ StealthXStream 600 Watt
Please calm down and behave civilly. There is no reason to insult each other because you disagree on the performance of a CPU cooler.
crazyeyesreaper
Not a Moderator
9,819 (1.70/day)
Keyboard Mionix
yes sir mister moderator sir :respect:
MKmods
Case Mod Guru
5,697 (0.92/day)
Nevada
Cooling Air
Case Custom
yep my 965 and Freezer arent quite up to your Xeon and thermalright cooler...
Oh wait thats right the OP has a 955 that is OCd and dosent want to spend $60+ on a cooler....
