are these temperature readings ok while gaming?
240 (0.07/day)
System Name assembled
Processor i5 10400 2.90ghz
Motherboard asus tuf b460 plus
Cooling stock fan with 3 cabinet fans
Memory 16gb
Video Card(s) Inno3d nvidia geforce rtx 2060
Storage 1tb seagate hdd model st2000dm005, 512 ssd western digital
Display(s) LG
Case Deepcool matrexx 55 mesh
Power Supply Corsair
Keyboard Corsair k55
namaste people,
specs
i5 10400 cpu
16gb ram
are these readings and the temperatures fine? please guide me
thank you so much
9,581 (3.28/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
They seems pretty high for that GPU, what model is the video card ? Is the case well ventilated ?
6,130 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Sad John Cena GIF
You're hitting thermal limits on your GPU. Your CPU is at 100C.
No, it's not normal.
240 (0.07/day)
Memory 16gb
Display(s) LG
oh shit, i think i will clean the cabinet right away, i dnt have the air pump for doing this. by the way this is the gpu
the pc is beside a wall and needs cleaning.
also this is the reading when im not gaming
i will send a photo of the inside. i dnt have anything special for cooling. not sure what to say when u ask what i have done about the cooling. thank for the answers ill just start cleaning the dust away
6,130 (2.85/day)
Poland
You should not be hitting 100C on 10400.
Your GPU probably needs cleaning and repasting.
5,572 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
Yeah keeping you PC clean is a good start but I would start thinking about better cooling for that CPU and possibly even a better case with more airflow as both GPU and CPU temps are pretty shocking.
also you've been a member of TPU for 8 years and yet you haven't bothered to fill in your systems specs in your profile please do it it helps us to help you better by us knowing what's inside your PC without having to keep asking what hardware you have all the time
Deleted member 57642
1st step: Clean and change the paste on your GPU/CPU - if necessary.
2nd setep: Undervolt it with...
...like so...
Even lower the frequencies if necessary - since you can actually get better performance (more consistent - to be more exact) - at lower frequencies if it's running stable - than at higher (even default) - if thermal throttling.
On a laptop i lowered the frequencies by 20% - since at this frequency I can run the GPU at 700 mV instead of 1000+ (or 900 undervolted) mV for default. Which translated to a maximum of 75*C in heavy load - despite of having the mediocre cooling and airflow of a laptop. In less GPU intensive games - it rarely goes above 50*C. Some (if not most) - are against lowering the max potential of your GPU (sacrificing FPS for lower temperatures) - but that's all up to you and the games you play. This configuration simply fits my needs. Not to mention - the fans are usually running quite low as well (around 50% or less - compared to max speed) - as in - reasonably silent. Tho, sure - a demanding game can change that (both temperatures and fan noise).
240 (0.07/day)
Memory 16gb
Display(s) LG
Thank u very much for the help, im cleaning the cabinet right now. After this will check the temps. And yes surely i will repaste the cpu if the temps are still high. There was a ton of dust inside. Ive been at it since my last msg. And yes will enter he specs in my profile as well after the cleaning is done. Will post the pics as well. Lets see what happens. Thanks very much to you all.
  • Like
Reactions: Lei
Lei
1,143 (0.89/day)
usually in my shirt
Processor 3900x - Bykski waterblock
Motherboard MSI b450m mortar max BIOS Date 27 Apr 2023
Cooling αcool 560 rad - 2xPhanteks F140XP
Memory Micron 32gb 3200mhz ddr4
Video Card(s) Colorful 3090 ADOC active backplate cooling
Storage WD SN850 2tb ,HP EX950 1tb, WD UltraStar Helioseal 18tb+18tb
Display(s) 24“ HUION pro 4k 10bit
Case aluminium extrusions copper panels, 60 deliveries for every piece down to screws
Audio Device(s) sony stereo mic, logitech c930, Gulikit pro 2 + xbox Series S controller, moded bt headphone 1200mAh
Power Supply Corsair RM1000x
Mouse pen display, no mouse no click
Keyboard Microsoft aio media embedded touchpad (moded lithium battery 1000mAh)
Software Win 11 23h2 build 22631
Benchmark Scores cine23 20000
@himendra
Very high for April. You'd be dead in summer. And your m.2 is probably cooking now.
13,252 (6.06/day)
Midlands, UK
Cooling Yes
Memory Anything from 4 to 48 GB
Storage A lot
Display(s) Monitors and TVs
Case The smaller the better
Mouse Wireless
Keyboard Wired
VR HMD Not yet
You've still got the stock Intel cooler? How do you cope with that noise? :fear:
Seriously, get a better cooler for your CPU, give the graphics card a good cleaning, and potentially a case with better airflow.
While the GPU can easily thermal throttle when reaching maximum temp (which isn't ideal, but acceptable), running an i5 to 100 degrees isn't normal.
240 (0.07/day)
Memory 16gb
Display(s) LG
13,252 (6.06/day)
Midlands, UK
Cooling Yes
Storage A lot
Mouse Wireless
Keyboard Wired
VR HMD Not yet
240 (0.07/day)
Memory 16gb
Display(s) LG
This city is very very hot. And a lottttt of dust. Incredible dirt everywhere. My hom3town is in mountains. One single day dust here is like a whole years dust in my hometown. Lets see the new temps ive cleaned n used new paste in cpu. I dnt know how to repaste gpu. Never done that. Wil see if i have have to do it.
Thanks
new temps after the repaste of cpu. please take a look.
this is while the game is running in high quality graphics and browser is also opened in the background.
3,684 (1.70/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
Within official limits, but I wouldnt be happy with those temps.
240 (0.07/day)
Memory 16gb
Display(s) LG
What should be the temps then? Cpu & gpu? Do i need to repaste the gpu? I bought the whole thing in 2021, the gpu might still be under warranty but still what should i do? By the way i had to reopen the case to fit one ram stick proply, now its back to 16gb just saying. Thanks
489 (0.57/day)
System Name Firestarter
Processor 7950X
Motherboard X670E Steel Legend
Cooling LF 2 420
Memory 4x16 G.Skill X5 6000@CL36
Video Card(s) RTX Gigabutt 4090 Gaming OC
Storage SSDS: OS: 2TB P41 Plat, 4TB SN850X, 1TB SN770. Raid 5 HDDS: 4x4TB WD Red Nas 2.0 HDDs, 1TB ext HDD.
Display(s) 42C3PUA, some dinky TN 10.1 inch display.
Case Fractal Torrent
Audio Device(s) PC38X
Power Supply GF3 TT Premium 850W
Mouse Razer Basilisk V3 Pro
Keyboard Steel Series Apex Pro
VR HMD Pimax Crystal with Index controllers
Good god.
I'd upgrade the cooler to a cheap air one.
Check out your case fans and filters if you have them.
Clean the GPU fins and see if that does anything, if not repaste.
Honestly, you're alright.
240 (0.07/day)
Memory 16gb
Display(s) LG
Good god.
U mean buy a new cpu fan? Yes there are 3 case fans i cleaned them. Filters? I dnt know what they are.
Thing is i have bought 1 laptop and assembled 2 pcs with the help of people on these forums. Entirely with the help of individuals here. Im unable to develop any interest in learning the technical terms related to computer building plus my english is completely basic. I may sound rude here in text but m trying my best to be as polite as i am in real life. Can anybody give a link to a new fan from amazon india? That fits inside the cabinet nicely that i have. Also i typed dxdiag to see my specs so that i can fill my profile but it dsnt give any details about the brand and all, i will fil up the profile surely after i learn abt their names myself. Thnak you very much guys. Sorry if sound rude plz understand this is just my english
4,517 (0.81/day)
Denmark
System Name The work PC /2700x/5950x
Processor 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V
Motherboard Gigabyte AORUS Master X570/2xMSI X470 M7 AC
Cooling Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE
Memory 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400
Video Card(s) 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI
Storage 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro
Display(s) Dell UltraSharp U2518D/2408WFP
Case Corsair 800D / Lian test bench/NZXT 500
Power Supply AX 850 Titanium/AX 860i/AX 760
Software Dual boot/Win 10 / Linux / Win 10+Linux
Are you sure that the exhaust fan is mounted correct. For me it look like you are sending air in but if you rfans in the front is reversed as well I guess it will work. Most use the front as intake (where the filter is if any) and the rear and top as exhaust.
240 (0.07/day)
Memory 16gb
Display(s) LG
I faintly remember this. When i was installing those fans in the front maybe i did google and found out that there is a logic to installing them. I will check em ryt now.
Ok, i put my hand in front and it seems like the front 2 fans are taking the air in, and the rear single one is for exhaust. There is one fan on the cpu the stock one also. Is this fine? I mean shud i have more for exhaust?
56 (0.09/day)
Gryffindor Common Room
System Name Dusty Gastly
Processor AMD RYZEN 5700G 8C/16T
Motherboard ASUS PRIME B550M-A WIFI
Cooling WRAITH PRISM
Memory HyperX Predator 4x8GB 3200 mhz CL 16
Video Card(s) MSI GTX 670
Storage 2X240 GB SATA SSD 1X480 GB SATA SSD 1X250GB SAMSUNG 970 EVO
Display(s) 1X 24" CURVED 144HZ AOC 1X21" 60HZ LG
Case COOLER MASTER H500 2X200MM FANS
Audio Device(s) HYPERX CLOUD II, LOGITECH G533, LOGITECH Z213
Power Supply COOLER MASTER MWE BRONZE 750W
Mouse DEATHADDER V2
Keyboard STEELSERIES APEX 7
Software WINDOWS 10 PRO
This is really not good...
13,252 (6.06/day)
Midlands, UK
Cooling Yes
Storage A lot
Mouse Wireless
Keyboard Wired
VR HMD Not yet
Thanks
Right... 80 °C on the CPU is fine if it's a heavy load. I would still get a better cooler for it, though.
Let's focus on the GPU, as it's thermal throttling. Have you cleaned its fan and heatsink fins?
240 (0.07/day)
Memory 16gb
Display(s) LG
i used the brush to clean it, cant say it was thorough.
however just now i watched a video of repasting that gpu. i will open it up, CLEAN and repaste it asap, i have never tackled a gpu before but seems like its the same as cpu cleaning.
its night time here, tomoro after work i will do it. i got this in 2021.
can u link any new cooler ?
thanks very much
13,252 (6.06/day)
Midlands, UK
Cooling Yes
Storage A lot
Mouse Wireless
Keyboard Wired
VR HMD Not yet
thanks very much
As for GPU repasting, just be careful to apply thermal paste evenly to all of the GPU die surface. Also, when you tighten the screws, do it in a star shape (e.g. bottom right, then upper left, then upper right, then bottom left), making sure there's equal pressure on the chip at all times. This is to make sure you don't accidentally chip a corner of the GPU die off.
As for CPU cooler recommendations, what chassis have you got? What's your budget?
4,517 (0.81/day)
Denmark
No, what I meant was that for me it looks like the rear fan reversed i.e. sucking air into the case. If your front fan are doing the same then 1) you are sucking dirty air in, 2) you have positive pressure in your case and the inlet fans are not running at a good place on the fan curve and they suck to little air, 3) all fans sucking in leads to poor air circulation and high temperature. Just check if the rear fan is sucking or blowing.
