- Feb 11, 2009
- 5,892 (0.98/day)
System Name | Cyberline |
Processor | Intel Core i7 2600k -> 12600k |
Motherboard | Asus P8P67 LE Rev 3.0 -> Gigabyte Z690 Auros Elite DDR4 |
Cooling | Tuniq Tower 120 -> Custom Watercoolingloop |
Memory | Corsair (4x2) 8gb 1600mhz -> Crucial (8x2) 16gb 3600mhz |
Video Card(s) | AMD RX480 -> RX7800XT |
Storage | Samsung 750 Evo 250gb SSD + WD 1tb x 2 + WD 2tb -> 2tb MVMe SSD |
Display(s) | Philips 32inch LPF5605H (television) -> Dell S3220DGF |
Case | antec 600 -> Thermaltake Tenor HTCP case |
Audio Device(s) | Focusrite 2i4 (USB) |
Power Supply | Seasonic 620watt 80+ Platinum |
Mouse | Elecom EX-G |
Keyboard | Rapoo V700 |
Software | Windows 10 Pro 64bit |
1. People already whine and bitch and moan about motherboard pricing. You want to quadruple the power capability on top of all that?
2. So, if you can do a high end GPU with 300w, why not scale that tech up to 400, or 500? Chips size is not a limiting factor anymore. Removing heat is now the limiting factor. Limiting your GPU lineup to 300w at best didnt work out so well for alchemist, nor historically has it worked well for AMD. If you dont want a 600w GPU....dont buy a 600w GPU? 4060s and 6650xts and 7800xts still exist.
1. ermm no? the power still comes from the psu in the end, just a bigger main plug in it, instead of 24 pin maybe 26 or so or just make that plug carry more power, its just that the peripherals pull the power from the board instead of having all kinds of separate cables going everywhere.
2. why not scale it up? welll I think I addressed already in the original comment, its the weakest form of progress.
We need the devs to get their advancement elsewhere and focus money and resources on that instead of just blasting it with more power consumption.
