ASRocks marketing team has lost their marbles...
18,176 (2.45/day)
This showed up on FB, so I figured I'd have a look what it was all about, as it didn't make much sense. I mean, how much of a limitation is Ethernet for gamers?
I guess they've also gotten rid of all their native English speaking staff, or even the ones that finished English class. C'mon Taiwan, you can do better than this.:(
Turns out their marketing team has gone of their rockers.
This is their "pitch" for hooking their Ethernet controller up to the PCIe lanes from the CPU.
True gaming focused design! Unlike most so called gaming motherboards that are only decorated with standard design, the Killer E3100 2.5G LAN chip architecture on Z590 PG Velocita can be chosen to be controlled directly by the CPU. Hence, it can benefit a new gaming experience in lower latency, faster internet network and the overall performance a huge boost.
I mean, how much latency can be added to Ethernet inside a PC? 0.5ms? And other motherboards are apparently only decorated, they don't actually have networking built in...
But that's not what struck me the most, but rather this. I mean, how much data does a keyboard and a mouse contribute with to cause data congestion and thus needing dedicated buses? :kookoo:
The whole product page is full of similar completely silly claims.
752 (0.43/day)
System Name Main PC
Processor AMD Ryzen 9 5950X
Motherboard ASUS X570 Crosshair VIII Hero (Wi-Fi)
Cooling EKWB X570 VIII Hero Monoblock, 2x XD5, Heatkiller IV SB block for chipset,Alphacool 3090 Strix block
Memory 4x16GB 3200-14-14-14-34 G.Skill Trident RGB (OC: 3600-14-14-14-28)
Video Card(s) ASUS RTX 3090 Strix OC
Storage 500GB+500GB SSD RAID0, Fusion IoDrive2 1.2TB, Huawei HSSD 2TB, 11TB on server used for steam
Display(s) Dell LG CX48 (custom res: 3840x1620@120Hz) + Acer XB271HU 2560x1440@144Hz
Case Corsair 1000D
Audio Device(s) Sennheiser HD599, Blue Yeti
Power Supply Corsair RM1000i
Keyboard Corsair Strafe RGB MK2
Software Windows 10 Pro 20H2
That is eBay-$5-item level marketing jargon. Wow, that is hilariously bad.
18,176 (2.45/day)
It actually makes me sad. This is like going back 15 years in time. Just the fact that that they're making a bunch of silly and unsubstantiated claims about their competitors is just lame.
9,340 (5.09/day)
Louisiana
Keyboard G710+x3
Last I checked there is only 20 lanes and between m.2 and gpu they are all gone lol
18,176 (2.45/day)
Apparently Killer NICs need four PCIe lanes...
Toothless
Tech, Games, and TPU!
9,764 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Your keyboard and mouse gonna use as much bandwidth as a RTX3070? Since when does a Logitech G502 cancel out a USB wifi card because it uses too much data?
9,781 (2.17/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
it must be faster, theres an easy to see direct bright yellow line of LAN running from the rj45 to the CPU o_O
18,176 (2.45/day)
This wasn't so much about the thing on FB, as the product page. The FB post just piqued my interest, but then I found out that they were claiming all sorts of BS on the product page while calling out their competitors as having inferior products and solutions. Not cool.
It's truly desperate times if these are the most unique selling points they could come up with.
95Viper
Super Moderator
13,173 (2.20/day)
Let's stay on topic.
It is not about facebook, twitter, or any other social media sites.
Don't be insulting or making disparaging remarks about other members.
Only warning.
Thank You and have a Gorgeous Day.
3,022 (1.15/day)
System Name System V
Processor AMD Ryzen 7 9700X
Case NZXT Source 210
But why? It's just 2.5 G Ethernet, right? They could more than make do with just two damn lanes. Hell, even one should be enough!
Even for 10 G Ethernet, 2 PCIE 4.0 lanes should be enough!
EDIT: Nevermind, it's probably how lanes are distributed in that board.
18,176 (2.45/day)
I have no idea. Yes, sure, it's how the lanes are split, but even so, why does it need PCIe 4.0 directly to the CPU? The chip is limited to PCIe 3.x anyhow, so the extra bandwidth isn't going to help.
The whole idea just feels so, not thought out at all? I can't see it having any real world affect on latency at all, as per their claim.
It's not as if it's an SSD that can at least benefit a little bit from this.
Then again, this is their claim about their I/O shield...
Unlike most so called pre-mounted I/O shield that is only decorated with fancy color schemes. We reserve more tolerance space and allow IO shield is adjustable when installing, thus fitting chassis perfectly without any mechanical issue.
3,657 (0.67/day)
Portugal
It is funny that these PRs started and were aimed initially at LAN gaming which was...the point. At the time, anything you did in your OS regarding Lanman and the kind of chip you had made a difference in the 'ms' range when you were playing on that LAN Party, Quake 3/UT2004 @ +100fps, to get a headshot. Internet would be slow, period.
Nowadays, depending on the country, in the times of the $69 ISP-provided Wi-Fi router/ONT-you-cannot-get-rid-of, overloaded fibre distribution point, data/broadband caps (general no net neutrallity), aggressive service quotas and such, I guess the marketing overdrive is here only to make you forget about that.
3,022 (1.15/day)
That claim about the IO shield... Isn't that what every motherboard maker has been doing for, well, quite a while now?
And then they wrote that bs in... Brutish English, I guess...
And I mostly agree with the above post. All those fancy network gaming features either are pointless because ISP will be trash anyways or you're LAN gaming so it doesn't matter because you'd have to have horrible network infrastructure for them to actually make the slightest difference.
silentbogo
5,621 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 64GB DDR4-3600(4x16)
Storage ADATA Legend 2TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Worse. E3100 is based on i225V, which only needs a single Gen2 lane.
18,176 (2.45/day)
silentbogo
5,621 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
From Intel ARK:
18,176 (2.45/day)
silentbogo
5,621 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
Where did you get that spec? I think you are looking at something different, cause I don't see NBASE-T in "Interfaces Supported"
I think I found it. You were looking at i225K. Not sure why, but it is listed w/ PCIe3 unlike siblings.
Here's i225V and i225LM (Killer E3100G and E3100X respectively)
And this is official spec:
9,781 (2.17/day)
Massachusetts
Processor i7-11700K
i still only buy Asrock motherboards, but i dont buy in to those gimmicks like a rj45 port, then another Red rj45 that is named 'killer', or some other pointless , 'go fast' marketing nomenclature.
the extreme boards & the Pro4M boards have served me very well over the decades. never had a real issue, aside from a dead fan header on a board 10 years ago.
they sent me a free brand new board
all these marketing ;campaigns these companies do are silly. they all do it, to some degree, maybe there are more kids buying motherboards & PC components than im aware of.
21,818 (3.41/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 64GB (2x 32GB) G.Skill Flare X5 @ DDR5-6200 (Running 1T no GDM)
Case Thermaltake Core X31
Software Gentoo Linux x64
Pretty much. That's what pisses me off more here: Lots of companies have made dumb marketing claims, but ASRock is letting it creep into product design. That is a very bad sign. Which is a shame because their products were historically the ones to have.
9,340 (5.09/day)
Louisiana
Keyboard G710+x3
They paid a company to run an add
If you question the add report it as fake news I'm sure they will investigate your proof it's false
21,818 (3.41/day)
Olympia, WA
System Name Pioneer
Thing is, it's not explicitlty provable as false. It's more "we're talking absolutely well beyond the range of human perception if there's any truth to it" sort of BS. Just enough for them to claim it's possibly true.
18,176 (2.45/day)
It's NOT about the ad. Read the product page for crying out loud. The ad was just what caught my attention, but everything else if from their ASRock product page.
I even included the link to it up top.
Also, they didn't pay a company to run that ad, that's an in-house ad that they put up on FB. Taiwanese companies are WAY too cheap to pay someone to do something like that for them.
How do I know this? Because I have worked for multiple Taiwanese companies.
9,340 (5.09/day)
Louisiana
Keyboard G710+x3
Well it made it through the fact checkers so it must be true lol
