- Aug 9, 2019
- 1,652 (0.87/day)
Processor | 7800X3D 2x16GB CO |
Motherboard | Asrock B650m HDV |
Cooling | Peerless Assassin SE |
Memory | 2x16GB DR A-die@6000c30 tuned |
Video Card(s) | Asus 4070 dual OC 2610@915mv |
Storage | WD blue 1TB nvme |
Display(s) | Lenovo G24-10 144Hz |
Case | Corsair D4000 Airflow |
Power Supply | EVGA GQ 650W |
Software | Windows 10 home 64 |
Benchmark Scores | Superposition 8k 5267 Aida64 58.5ns |
I've had my card for 2 weeks now, but the hotspottemps annoyed me. From day 1 they howered around 20-21C above gputemp. I decided to repaste with MX-6. Card is run undervolted at 2655@915mv and +1250MHz vram.
Stock with fans at 30% unigine superposition:
After repaste:
Re-ran tests several times. Gpu-temp dropped by 2C, hotspot by 5C.
Then I tested mining with Nicehash with fans at 50%:
Stock 61C/82C HS
Repaste 59C/76C HS
With fans on auto the stabilized at 49% stock, 41% after repaste with gpu-temp at 60C in both cases, but hotspot at 83C stock and 77C repaste.
With mining and fans at auto I get lower noise and 6C lower hotspot
Overall I'm satisfied with results
After repaste:
Stock 61C/82C HS
Repaste 59C/76C HS
