ASUS Announces NVIDIA GeForce RTX 50 Series Graphics Cards
47,393 (7.52/day)
ASUS today announced its NVIDIA GeForce RTX 50 Series graphics cards, including the all-new ROG Astral line that ushers in a new generation of performance. The ROG Astral series combines top-tier frame rates and a sleek, stellar design, with both air-cooled and liquid-cooled variants ready to power a user's next PC.
Powered by NVIDIA Blackwell, GeForce RTX 50 Series GPUs bring game-changing capabilities to gamers and creators, Equipped with a massive level of AI horsepower, the RTX 50 Series enables new experiences and next-level graphics fidelity. Users can multiply performance with NVIDIA DLSS 4, generate images at unprecedented speed, and unleash creativity with NVIDIA Studio. Plus, they can access NVIDIA NIM microservices—state-of-the-art AI models that let enthusiasts and developers build AI assistants, agents, and workflows with peak performance on NIM-ready systems.
ROG Astral takes to the skies with next-level performance and design
The ROG Astral series derives its name from the relentless pursuit of innovation and excellence, inspired by the boundless mysteries of the universe, particularly the immense gravitational forces and infinite depth of black holes. ROG Astral symbolizes the powerful and limitless energy of the cosmos, pushing performance to new heights and continuously exploring uncharted territories like never before.
As the first quad-fan graphics cards from ROG, the ROG Astral GeForce RTX 5090 and 5080 take cooling to the next level with up to 20% more airflow and pressure than previous three-fan designs. This helps reduce hotspots, leading to unprecedented clock speeds.
The inclusion of a fourth fan allows for more densely-packed heatsink fins, increasing overall cooling potential. In addition, the ROG Astral GeForce RTX 5090 and 5080 see the return of the ASUS-patented vapor-chamber design with milled pathways, allowing heat pipes to sink into the surface without flat edges for improved heat dissipation. And between that heatsink and the GPU, traditional thermal paste has been swapped for a premium phase-change thermal pad, which not only optimizes heat transfer but also increases the longevity of the thermal interface material. Liquifying by design to effectively fill the gaps between the GPU and the heatsink, this phase-change GPU thermal pad's superior thermal conductivity helps ensure optimal performance and durability of graphics cards under heavy load.
The ROG Astral series is built for enthusiasts and overclockers, which means premium power delivery is a must. Powerful 80-amp MOSFETs allow for more than 35% extra headroom than standard designs, for enhanced stability and higher overclocking potential. At the same time, a protective PCB coating helps protect against short-circuits caused by moisture or dust, which means these cards are built to last.
All of this is encased in an ultra-rigid metal frame, fan shroud and backplate with a slick new design that evokes futuristic starships. And as a top-of-the-line series, ROG Astral also supports the latest advanced features in GPU Tweak III, including a Thermal Map of the PCB, Power Detector+ to check the 12VHPWR connection, and a Mileage tracker that logs power usage over the lifespan of the card. Add to these features two FanConnect II headers for controlling case fans and a Dual BIOS switch that lets users choose between maximum performance and quiet operation—all of it amounts to an incredible graphics card that can handle nearly anything thrown at it.
For liquid cooling enthusiasts, ASUS also offers the ROG Astral LC GeForce RTX 5090. Featuring many of the same features as its air-cooled cousin, the LC version opts for a low-profile heatsink under the shroud, with a full-coverage cold plate that allows the extra-thick 360 mm radiator to cool the GPU and other heat-producing components on the PCB. Featuring up to 30% better thermal performance than air cooling, the ROG Astral LC GeForce RTX 5090 is an ideal choice for scoring powerful performance with quiet operation.
ROG Strix, ASUS TUF Gaming, and ASUS Prime fill out the lineup
The ROG Astral series is not the only family of graphics cards gracing the ASUS lineup this generation. Gamers looking for a powerful GeForce RTX 5070 Ti or RTX 5070 graphics card should look at the ROG Strix variants, featuring striking designs and a host of features, including a vented exoskeleton, Dual BIOS switch, high-end power delivery, phase-change GPU thermal pad and Aura Sync.
  • ROG Strix GeForce RTX 5070 Ti
  • ROG Strix GeForce RTX 5070 Ti OC Edition
  • ROG Strix GeForce RTX 5070 (Coming soon)
  • ROG Strix GeForce RTX 5070 OC Edition (coming soon)
For ultra-reliable performance that can suit any PC build, the TUF Gaming GeForce RTX 5090, RTX 5080, RTX 5070 Ti and RTX 5070 are all excellent choices. Like the ROG Astral series, TUF Gaming models feature the phase-change thermal compound, a protective PCB coating and military-grade components for durability, plus a vapor chamber on the TUF Gaming GeForce RTX 5090 and 5080. Certified military-grade TUF chokes and MOSFETs deliver rock-solid power to the CPU, which can help improve system stability. Meanwhile, TUF 5K black metallic capacitors provide 52% wider temperature tolerance and a lifespan up to 2.5 times longer than standard capacitors.
  • TUF Gaming GeForce RTX 5090
  • TUF Gaming GeForce RTX 5090 OC Edition
  • TUF Gaming GeForce RTX 5080
  • TUF Gaming GeForce RTX 5080 OC Edition
  • TUF Gaming GeForce RTX 5070 Ti
  • TUF Gaming GeForce RTX 5070 Ti OC Edition
  • TUF Gaming GeForce RTX 5070 OC Edition
Finally, ASUS Prime graphics cards also join the launch, featuring the phase-change thermal compound and tri-fan cooling. And for the GeForce RTX 5080, 5070 Ti and 5070 models, a 2.5-slot design that meets the SFF-Ready Enthusiast GeForce Card guideline provides broad compatibility at an attractive price. At the same time, the ASUS Prime GeForce RTX 5080 still features a vapor chamber for thermal performance users can count on.
  • Prime GeForce RTX 5080
  • Prime GeForce RTX 5080 OC Edition
  • Prime GeForce RTX 5070 Ti
  • Prime GeForce RTX 5070 Ti OC Edition
  • Prime GeForce RTX 5070 OC Edition
The new GeForce RTX 50 Series graphics cards can be seamlessly paired with a power supply from the ROG Thor III or ROG Strix Platinum lines, featuring ATX 3.1 and PCIe 5.0 support, the ASUS-patented GPU-First intelligent voltage stabilizer, and GaN MOSFETs. Click here to check out Thor III and ROG Strix Platinum PSUs.
MuseTree is an AI-powered image-generation app designed to spark your creativity. Effortlessly create and manage images and visual ideas, unlocking endless new inspirations. With its intuitive visual interface, generating stunning images has never been easier.
7,215 (4.88/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Audio Device(s) Apple USB-C + Sony MDR-V7 headphones
Software Windows 10 Pro 22H2
Man, that ROG Astral 5090 is probably going to be mind blowingly expensive. But I'd be lying if I said I wouldn't purchase one if I could. Looks like that it's everything I like in a graphics card and more.
212 (0.81/day)
System Name Main Workstation
Processor AMD Ryzen Threadripper 2970WX PBO 3,6-4,2Ghz
Motherboard Gigabyte x399 Aorus Pro (ReBAR patched)
Cooling Alphacool Eisbaer Aurora Pro 420
Memory 8x16GB (128) Kingston Fury RGB @3266Mts 16-18-18-36-74 2T
Video Card(s) RTX 3090 ROG Gaming OC @1500Mhz (1965Boost)
Storage Lexar NM790 2TB, Corsair Force MP510 960Gb, Samsung 860 SATA 2TB, 2TB WD Green 7200rpm
Case Phanteks Ethoo Pro 2 TG
Power Supply EVGA Super Nova 1000GT
Not the biggest fan of the Astral name and Design. Its all a bit... empty?
Will make its way into my collection one day anyways. If they havent all gone up in flames from the powerconnector.
1,000 (0.16/day)
Hungary / Budapest
System Name Kincsem
Processor AMD Ryzen 9 9950X
Motherboard ASUS ProArt X870E-CREATOR WIFI
Cooling Be Quiet Dark Rock Pro 5
Memory Kingston Fury KF560C32RSK2-96 (2×48GB 6GHz)
Video Card(s) Sapphire AMD RX 7900 XT Pulse
Storage Samsung 970PRO 500GB + Samsung 980PRO 2TB + FURY Renegade 2TB+ Adata 2TB + WD Ultrastar HC550 16TB
Display(s) Acer QHD 27"@144Hz 1ms + UHD 27"@60Hz
Case Cooler Master CM 690 III
Power Supply Seasonic 1300W 80+ Gold Prime
Keyboard HyperX Alloy Elite RGB
Software Windows 10-64
Benchmark Scores https://valid.x86.fr/9qw7iq https://valid.x86.fr/4d8n02 X570 https://www.techpowerup.com/gpuz/g46uc
Can't wait to see the benchmarks and prices! :love:
867 (0.48/day)
5070 looks interesting, the spec is a tiny uplift from 4070 though and similar price.
Only the 5090 looks a decent generational improvement but it's costs 2k+.
Ultimately as expected, loads of AI spamming but little generational improvement and the same or higher prices.
64 (0.21/day)
System Name SOCIETY
Processor AMD Ryzen 9 7800x3D
Motherboard MSI MAG X670E TOMAHAWK
Memory 64GB 6000mhz
Video Card(s) Nvidia RTX 3090
Storage WD SN850X 4TB, Micron 1100 2TB, ZFS NAS over 10gbe network
Display(s) 27" Dell S2721DGF, 24" ASUS IPS, 24" Dell IPS
Case Corsair 750D
Power Supply Cooler Master 1200W Gold
Mouse Razer Deathadder
Keyboard ROG Falchion
VR HMD Pimax 8KX
Software Windows 10 with Debian VM
Dang ASUS, you know what'd be really premium? Non melty power plugs.
I'm gonna have to sit it out and wait to see if this gen has another safety risk to it, but god with the variety of custom cards I'm shocked nobody made an 8 pin variant of 4080/4090s to see if there was a market for it.
It's like someone at nvidia has a 12VHPWR/12V-2x6 fetish and is holding a gun to the board partners and saying that using the new power plugs is an essential feature.
Meanwhile AMD partners are showing off 9070s with 8 pins.
If AMD was competitive for my purpose I'd just go with them and be done with it, but I may just buy nothing at all, again.
115 (0.20/day)
System Name EnvyPC
Processor Ryzen 7 7800X3D
Motherboard Asus ROG Strix B650E-I Gaming WiFi
Cooling Thermalright Peerless Assassin 120 White / be quiet! Silent Wings Pro 4 120mm (x2), 140mm (x3)
Memory 64GB Klevv Cras V RGB White DDR5-6000 (Hynix A) 30-36-36-76 1.35v
Video Card(s) MSI GeForce RTX 4080 16GB Gaming X Trio White Edition
Storage SK Hynix Platinum P41 2TB NVME
Display(s) HP Omen 4K 144Hz
Case Lian Li Dan Case A3 White
Audio Device(s) Creative Sound BlasterX G6
Mouse Logitech G600 White
I really hope it comes in white... :respect:
7,215 (4.88/day)
São Paulo, Brazil
The power connector issue has been fixed for almost 2 years now... are we gonna pretend that they haven't forever?
Yuuup. ROG White cards are just amazing. I love how 4080 Strix looks like. But I am probably gonna pick a TUF this time around, if I end up buying ASUS. My current build is white, but I plan on getting a Y70 Silver Wolf case when they show up here.
600 (0.38/day)
Greece
System Name Office / HP Prodesk 490 G3 MT (ex-office)
Processor Intel 13700 (90° limit) / Intel i7-6700
Motherboard Asus TUF Gaming H770 Pro / HP 805F H170
Cooling Noctua NH-U14S / Stock
Memory G. Skill Trident XMP 2x16gb DDR5 6400MHz cl32 / Samsung 2x8gb 2133MHz DDR4
Video Card(s) Asus RTX 3060 Ti Dual OC GDDR6X / Zotac GTX 1650 GDDR6 OC
Storage Samsung 2tb 980 PRO MZ / Samsung SSD 1TB 860 EVO + WD blue HDD 1TB (WD10EZEX)
Display(s) Eizo FlexScan EV2455 - 1920x1200 / Panasonic TX-32LS490E 32'' LED 1920x1080
Case Nanoxia Deep Silence 8 Pro / HP microtower
Audio Device(s) On board
Power Supply Seasonic Prime PX750 / OEM 300W bronze
Mouse MS cheap wired / Logitech cheap wired m90
Keyboard MS cheap wired / HP cheap wired
Software W11 / W7 Pro ->10 Pro
I guess those Prime series are the same level with Dual, just with 3 fans? :confused:
212 (0.81/day)
It bloody hasnt. They just announced a new revision. Its shit.
I am sick of arguing. This failure just needs to go. Bring back 8 pin. Nothing was wrong with it.
115 (0.13/day)
Sure, buddy ;) . Meanwhile, dozens of millions of gamers worldwide have been running their graphics cards with 12VHPWR (mostly not even the newer revision) connectors just fine for ~24+ months now.
It is a complete non-issue. I personally love having only one cable from my PSU to the graphics card for a cleaner build. It's awesome. My RTX 4090 has been running flawlessly from day 1 and I was an early adopter (October 2022). I have even... *GASP*... unplugged and replugged the power connector on the card quite a few times when I swapped or installed new parts or when I built my new system. Never had a single problem.
nVidia has a 90% market share in consumer GPUs (yes, not all of them RTX 4000 series, ofc, but still...) and there are literally another dozens of millions of these cards running in professional environments with that very power connector.
Non-issue remains a non-issue. Go ahead and buy an AMD card though if you are too afraid to handle a simple power connector :D .
411 (0.26/day)
Texass
System Name EXTREME-FLIGHT SIM
Processor AMD RYZEN 7 9800X3D 4.7GHZ 8-core 120W
Motherboard ASUS ROG X670E Crosshair EXTREME BIOS V.2506
Cooling be quiet! Silent Loop 2 360MM, Light Wings 120 & 140MM
Memory G. SKILL Trident Z5 RGB 32MBx2 DDR5-6000 CL32/EXPOⅡ
Video Card(s) ASUS ROG Strix RTX4090 O24
Storage 2TB CRUCIAL T705 M.2, 4TB Seagate FireCuda 3.5"x7200rpm
Display(s) Samsung Odyssey Neo G9 57" 5120x1440 120Hz DP2.1 #2.Ulrhzar 8" Touchscreen(HUD)
Case be quiet! Dark Base Pro 900 Rev.2 Silver
Audio Device(s) ROG SupremeFX ALC4082, Creative SoundBlaster Katana V2
Power Supply be quiet! Dark Power Pro 12 1500W via APC Back-UPS 1500
Mouse LOGITECH Pro Superlight2 and POWERPLAY Mouse Pad
Keyboard CORSAIR K100 AIR
Software WINDOWS 11 x64 PRO 23H2, MSFS2020-2024 Aviator Edition, DCS
Benchmark Scores fast and stable AIDA64
My old boss from the '70's would say "If you have to ask the price you can't afford it." Not this time Dub Young.
These will be so cheap I'll get the liquid cooled. I got room in my new Lian-Li O11 XL case. Although I ran 4090 for 2 years air-cooled w/o issue.
Motivated I am. Now for that 9950X3D.
Same and same. Everybody hated that 4 plug adapter. The CableMod right angle adapter worked fine too but I destroyed it and got my money back and be quiet! made a perfect cable for it.
7,215 (4.88/day)
São Paulo, Brazil
Announced and implemented it back in 2023... the problems are fixed... there's no need to argue, just accept that the connector is here to stay I guess
64 (0.21/day)
System Name SOCIETY
Memory 64GB 6000mhz
Case Corsair 750D
VR HMD Pimax 8KX
Why do you think it's been fixed for 2 years? 12V-2x6 has only been used on things that use less power than the 4090, the one that had the problem, and now the 5090 is set to use more power than it.
The 5090 is set to use much closer to the power limit of the cables than 8 pins were ever used for, so I'll just wait and see. Maybe they do melt maybe they don't, but I'm not going to be gambling it.
The cablemod connector that was officially recalled due to being a safety risk? https://www.techpowerup.com/316977/cablemod-recalls-12vhpwr-v1-0-and-v1-1-angled-adapters
Or did they make a non-melting one later?
411 (0.26/day)
Texass
Non-melting model. The original. This one didn't melt. It was manually destroyed and they gave my money back via (eyeroll) Paypal.
1,000 (0.16/day)
Hungary / Budapest
System Name Kincsem
Oh, I know that I can't afford it I am broke! - something really expensive died on me and I need to fix/replace it... makes me really sad (on that price could get 3 5090-s will not comment more on this).
I already have the 9950X which will serve me well at least until 2027 I guess.
Wish it had like 16 more PCIe lanes tho....
411 (0.26/day)
Texass
I'm limiting my mobo to one M.2 slot and the 4090 to run at 16X. I have the 7950X. I'm burning money but I'm old and I can't take it with me. Leave it to Grandson.
But I get it for more 5.0 x16 lanes.
194 (0.07/day)
Germany
Cooling MO-RA3 420 LT | 4x NF-A20
Memory F5-6400J3239G16GX2-TZ5NR
Video Card(s) Asus 4090 TUF
Storage 1TB NM790 | 2TB SN850X | 1TB SN750
Display(s) AW3423DW | S2721DGFA
Case Hyte Y70
Audio Device(s) FiiO K11 | DT1990 Pro | Rode NT-USB
Power Supply FSP Hydro Ti Pro 1000W
Mouse G502 X Plus | GPX Superlight 2
Keyboard Keychron Q6 Max
5090 Astral somewhat resembles the 4090 Matrix.
Price will surely be 2500 USD.
