Asus B660M E D4 audio DTS to realtek audio manager
Masum Hasan
17 (0.03/day)
my asus tuf gaming b660m e d4
Motherboard have by default Realtek with DTS audio controller,
It's very poor quality it’s not enough for me,
Now my question is "How i can use realtek audio manager equalizer"
I Don't like DTS Audio manager, Its very limited option,
Before i used GIGABYTE motherbaord it have Realtek audio manage equalizer,
Now Asus motherboard have DTS,
I Don't Need DTS,
I NEED REALTEK equalizer like this
I need to know it’s possible to restore this realtek original equalizer like this?
3,052 (2.05/day)
United Kingdom
Install a generic Realtek driver (such as this one), the driver you are using has DTS post processing config (SSTPPCfg), which overrides the default Realtek one.
Once installed, you might need to find (using explorer) and register 'RtkApi64U.dll' and 'RtkCfg64.dll' (command prompt as admin):
regsvr32 "LOCATION-TO\RtkApi64U.dll"
Masum Hasan
17 (0.03/day)
i see your post before, but if you have video tutorial that easier for me. :) :clap:
50 (0.09/day)
The Netherlands
Processor AMD Ryzen 7 5800X3D
Motherboard ASRock Fatal1ty X370 Professional Gaming
Cooling Noctua NH-D15 SE-AM4
Memory G.Skill Trident Z F4-3200C14D-32GTZ
Video Card(s) Inno3D RTX 4080 16GB X3
Power Supply Corsair RM1000x (2021)
Another potential option: EqualizerAPO. May need to install as SFX/EFX (option in the Configurator), but it's an excellent tool and you don't need to mess with any drivers. You can use the Peace GUI to make it a bit friendlier.
If you boost any frequencies, be sure to set a pre-amp lowering system volume by the highest boost value; that'll ensure you don't get distortion. As an example: If your highest boost is upping 125Hz by 5dB, set up a -5dB pre-amp.
(yes, I know, suspicious first post -- been lurking for a while!)
Masum Hasan
17 (0.03/day)
i used it, it’s good, but need to install separately, also need time.
I want realtek one, it’s best ever i had use
Can you help me with teamviewer
3,052 (2.05/day)
United Kingdom
I could, but I cant confirm that specific driver will give you the effects you are looking for, although it should. I will be around later, message me a good time.
Masum Hasan
17 (0.03/day)
Currently my offcial realtek audio driver is V6.0.9448.1,
I need just enable realtek audio effect
Masum Hasan
17 (0.03/day)
I have free time now,
if you can give me sometime on teamviewer
dhrus786
2 (0.02/day)
Hey man, I know this is a relatively old thread but I'd really appreciate it if someone could help me with this. I have an Asus TUF Gaming B760M-PLUS motherboard and this same issue on my PC. I tried to follow the written instructions but the Realtek Audio Console is not opening for me (RPC error). Could you please help me out as I'd really like to get the old Realtek Equalizer effects back? It might also help other people if you share what you did to get those effects back in the B660 motherboard.
LFL
1 (0.01/day)
Help me too,
I have a TUF B550M-Plus with DTS Custom and it does a terrible job with music, I don't play games and I would like the speaker equalizer to work with the Realtek one. I see the equalizer in Asus Realtek Audio Console, but only in the Realtek Digital Output section, so it doesn't work. Help me see the equalizer in the speaker section too.
Thanks in advance
