ASUS Released Non-Reference Radeon HD 4870 with Expanded Power Circuitry
5,250 (0.85/day)
IRAQ-Baghdad
System Name MASTER
Cooling Corsair H100i
Video Card(s) 2X EVGA GTX680
Case CoolerMaster Chosmos II
Software Win7 64bit Ultimate
is this fan enough for high overclock , i don't think so
43,712 (6.78/day)
If Intel sells a QX9770 without a stock cooler (assuming anyone who buys a $1500 CPU would use aftermarket cooling), they might as well start selling video cards sans coolers. Unfortunately, installing a aftermarket cooler (before which, finding one that fits perfectly, cools well) is cumbersome. So they have to provide cooling that is sufficient. Going by the 4870 'fiasco', definitely OC'ed RV770s don't do well with even double slot cooling. Like what originally came up with SuperRV770 specs only cards with water-blocks or pre-fitted WC solutions can tame a RV770 at 850+ MHz.
Not to mention Most companies wont cover cards that have been modified (aka aftermarket cooling) your best to keep the stock cooler around incase of total failure.
PCpraiser100
1,062 (0.18/day)
System Name REBEL R1
Processor Core i7 920
Motherboard ASUS P6T
Cooling Stock
Memory 6GB OCZ GOLD TC LV Kit 1866MHz@1.65V 9-9-9-24
Video Card(s) Two Sapphire HD 5770 Vapor-X Xfire'd and OC'd (920/1330)
Storage Seagate 7200.11 500GB 32MB
Case Antec Three Hundred
Audio Device(s) ASUS Xonar D1 PCI Sound Card
Power Supply OCZ StealthXStream 500W
Benchmark Scores 16585 Performance Score on 3DMark Vantage
With this extended power usage, you don't really need to risk it all with VoltMods (sorry W1z), especially if you are dealing with a good $300-$400 video card. But personally, I'm still disappointed about the power usage. But not for long, I hope. I am getting rumors in other forums that as referring to the 22nm Phenoms coming in mid/late 09', admins and co-workers from AMD are saying that they've noticed a lot of energy-efficiency in mind to the engineers OUTSIDE of the CPU-engineering department, which is not referring to the upcoming HD 4000 siblings. Could there be an upcoming power-saving revision to the present HD 4000 series, or are they just making more efficient chipsets for the next iPhone revision?:laugh:
As for this card, I;m still very impressed with the voltage. Get a Viva cooler from Coolermaster and you got yourself a $400 overclocking video card that will last for more than 6 months.
2,792 (0.39/day)
Tre, Suomi Finland
System Name Ladpot ◦◦◦ Desktop
Processor R7 5800H ◦◦◦ i7 4770K, watercooled
Motherboard HP 88D2 ◦◦◦ Asus Z87-C2 Maximus VI Formula
Cooling Mixed gases ◦◦◦ Fuzion V1, MCW60/R2, DDC1/DDCT-01s top, PA120.3, EK200, D12SL-12, liq.metal TIM
Memory 2× 8GB DDR4-3200 ◦◦◦ 2× 8GB Crucial Ballistix Tactical LP DDR3-1600
Video Card(s) RTX 3070 ◦◦◦ heaps of dead GPUs in the garage
Storage Samsung 980 PRO 2TB ◦◦◦ Samsung 840Pro 256@178GB + 4× WD Red 2TB in RAID10 + LaCie Blade Runner 4TB
Display(s) HP ZR30w 30" 2560×1600 (WQXGA) H2-IPS
Case Lian Li PC-A16B
Power Supply Corsair AX860i
Mouse Logitech MX Master 2S / Contour RollerMouse Red+
Keyboard Logitech Elite Keyboard from 2006 / Contour Balance Keyboard / Logitech diNovo Edge
Software W11 x64 ◦◦◦ W10 x64
Benchmark Scores It does boot up? I think.
What is the difference in PWM block here PowerColor HD4870 PCS+ and here Powercolor HD 4870 1GB and finally stock here Sapphire HD 4870 . Asus are a bunch of greedy people.
There is no difference.
PowerColor HD4870 PCS+ is identical to Powercolor HD 4870 1GB , they're both AMD reference design upgraded from 3 to 4 phase vGPU as the reference board has an option for that.
(...) I am getting rumors in other forums that as referring to the 22nm Phenoms coming in mid/late 09', (...)
:roll:
No need to worry about AMD 22nm coming in 2009... Try year later than Intel 22nm @ 2012.
blaxez
1 (0.00/day)
does this card has the same bios as the asus reference cards? apparently when i flashed mine with the normal reference bios, my card doesn't work anymore.
maxor1980
5 (0.00/day)
France
System Name W7 X64 Ultimate Mat'x
Processor Intel Core 2 Quad Extreme QX9650@ 4.4ghz
Motherboard Asus Striker II Extreme
Cooling Watercooling
Memory Gskill pc14400 @ 1800mhz GT1 Series
Video Card(s) XFX 5850 (with Asus Bios) 850/1200mhz
Storage Seagate Barracuda 500gb x2
Display(s) Futjitsu Siemens 22' 5ms
Case ANTEC Skeleton
Audio Device(s) Supreme FX II
Power Supply ANTEC True Power Quattro 1000W
Benchmark Scores 3d Mark 06=} 23121pts 3d Mark Vantage=} 16879pts
Hello everybody i have a big problem, i have buy the eah4870 D5 for my crossfire just the second one, and i have flashed my card and finaly the bios is die. I need the original bios of this card to reflash this one. contact me please.
thoughtdisorder
1,818 (0.29/day)
Just South of Mars
System Name Decent Lappy
maxor1980
5 (0.00/day)
France
Case ANTEC Skeleton
Is it for new card 4870 from Asus?
maxor1980
5 (0.00/day)
France
Case ANTEC Skeleton
After flash it's not the good bios, i need the last bios of the new card at page 1 first message.
