ASUS ROG CROSSHAIR X870E HERO AMD X870E Power Connection Question
Apollyon622
5 (0.04/day)
Hey everyone. I am interesting in this motherboard for my Ryzen 9950X build. Problem is, I have no idea what the power connector is next to the 24 pin main power connector. Do I need to plug a power cable to that connection? Or will the 24 pin be fine? My Corsair HX1000i might not have that cable for it.
ir_cow
4,710 (0.79/day)
USA
It's auxillary power for M.2 and PCIe slots. If you fully populated the motherboard, it will be too much for the 24pin.
Just need a spare 6pin pin PCIe cable. Doesn't the HX1000i have 6?
43,454 (6.76/day)
Your your motherboard manual out and read it, that will tell you what you need to know
