ASUS Rolls Out Prime TRX40-PRO S Motherboard
47,166 (7.56/day)
ASUS today rolled out the Prime TRX40-PRO S socket sTRX4 motherboard for 3rd gen Ryzen Threadripper HEDT processors. This board is part of a mini-refresh of the company's sTRX4 product-stack, beginning with the ROG Zenith II Extreme Alpha, the more recent ROG Strix TRX40-XE Gaming, and now the Prime TRX40-PRO S. Launch of the three boards is triggered by the niche of enthusiasts that likes to overclock their Ryzen Threadripper 3990X 64-core/128-thread processors.
While the older Prime TRX40-PRO is perfectly capable of running- or even overclocking the 3990X, the new PRO S is better suited for the task, and comes with bolstered 16-phase CPU VRM with 70 A power stages, same ones found on the original ROG Zenith II Extreme, while the Extreme Alpha has been amped up with 90 A power stages. ASUS upgraded the ROG Strix TRX40-XE Gaming the same way. The board's feature-set is otherwise identical to that of the original Prime TRX40-PRO. The Prime TRX40-PRO S is expected to be priced around the $430-mark.
1,432 (0.65/day)
SortOfGrim
System Name Merc v8| Project DRS
Processor Ryzen 7800X3D|5800X
Motherboard Gigabyte X670 Gaming X AX|B550 AORUS ELITE
Cooling Noctua NH-D15|Arctic LFII-360
Memory 2x 16GB-6000|2x16GB-3600
Video Card(s) MSI RTX 4070 Ti SUPER|RTX 3070 Ventus
Storage Solidigm P44 1TB & 2TB, Crucial MX500 2TB|2x1TB SSD
Display(s) Acer Predator XB271HU|LG 34GP950G
Case Caselabs Mercury S8|Phanteks G500A
Audio Device(s) Schiit Magni & Modi, Edifier S351DB|DT 770 PRO headphones
Power Supply Seasonic Vertex PX-850|Prime TX-750
Mouse Logitech G600
Keyboard Epomaker F75|Logitech K400
Software W11Pro
Erm, an M.2 'stand'? :wtf: Where does that go?
Edit: Nevermind, found it.
8,970 (3.31/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
On the 3rd "DIMM" slot right of the CPU socket. It is ac tually an add in card (pretty swanky too).
6,136 (1.52/day)
Over here, right where you least expect me to be !
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
Perhaps I'm missing something here, but except for cooling purposes or just to have a 3rd one, why exactly would I want an m.2 drive sticking upwards from my mobo, where 1 slip of the hands could result in a destroyed drive and/or socket connector ??????
88 (0.01/day)
Cheltenham, England, UK
System Name ASUS Vivobook Pro 15
Processor AMD® Ryzen™ 9 7940HS Processor 8C/16T 4.0 GHz (16M Cache, up to 5.25 GHz)
Cooling Dual Fan 3 heatpipes
Memory 16GB LPDDR5X 7500MT/s CL20-16-19-37
Video Card(s) NVIDIA® GeForce™ RTX 4060 8GB GDDR6 128-bit 3072 SM TGP 75W @ 105W
Storage WD Black SN850X 2TB NVMe
Display(s) 15.6" FHD 144Hz (1920x1080) 16:9 IPS
Power Supply 200W
Keyboard Backlit
Software Windows 11 Home 64-bit
I like the fact that they didn't put a stupid whiny fan on the VRM, instead they made it optional, and include a bracket for it. M.2 stand seems weird though.
8,970 (3.31/day)
Cooling In Win SR36
There is also the fact that the WiFI M2 module seems to sit in front of the PCiex8 slot.
2,014 (0.33/day)
Processor RyZen R9 3950X
Video Card(s) RTX 3050
Storage Samsung 2TB SSD
Case Zulman MS800
Audio Device(s) On Board
Power Supply Seasonic 650W
Software Windows 11 64bit
It's more then likely that Asus did it as a means to conserve space on the motherboard with respect to the features they wanted to pack in to the form factor. Asus could also have just went with something like extended ATX. Its not the first time Asus has done this BTW. They have probably been doing this M.2 riser for a couple of years now on select boards.
Why anyone would want this type of M.2 riser, I couldn't say,.....
6,136 (1.52/day)
Motherboard AZW SEI
I would'nt want it as is, but if it was in different location on the mobo, out of the way where it would be less likely to get fubarred, it might be ok...
I may be wrong, but wasn't this the intended mounting method for those so-called "U2" drives & connectors, the ones that never gained any ground in the consumer pc market ???
Personally, I think a pcie adapter card is a much better solution, even though it would use up a slot, but still....
And IIRC, some mobo mfgr's have included those with some mid-to-higher-end boards here & there, yes ?
19 (0.00/day)
Out of curiosity if one of the M.2 drives has to be mounted vertically on a bracket what is the height? I am planning on mounting this or a gigabyte MB which doesn't need to do this, in a 2U server enclosure so can't afford it to hit the cover.
1,432 (0.65/day)
SortOfGrim
Mouse Logitech G600
Software W11Pro
It looks to support the 22100 so it's a little bit over 10cm tall.
19 (0.00/day)
Thanks makes sense. Guess I'll be mounting my m.2 non 22100 without the bracket. Hope that's not going to be a n issue.
emil729
1 (0.00/day)
Hi everyone.
What is the difference between ASUS PRIME TRX40-PRO vs ASUS PRIME TRX40-PRO S?
ASUS PRIME TRX40-PRO is 269$
ASUS PRIME TRX40-PRO S is 469$.
Please reply me till the price increase.
14,056 (3.84/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
The "S" and $200 :laugh:
