He offered me one but i refused
Now you are teasing me
![Big Grin :D :D](https://tpucdn.com/forums/data/assets/smilies/biggrin-v1.gif)
but i will wait patiently for the details
Here it's
View attachment 111958View attachment 111959View attachment 111960
I couldn't wait and removed the Drivers Bay
Wooooooooooooooooooooooooooooooo!
![Clap :clap: :clap:](https://tpucdn.com/forums/data/assets/smilies/clap-v1.gif)
The internal volume of that chassis must be what? 200Liters? Did you simply email Lian Li and request the largest case available? lol
Can you mount (2) 480mm rads in the basement under the floorboards? OR only (1)?
What’s the aluminum feel like? Thick thin fit and finish... Is it a brushed surface?
I can already envision a multitude of tubing runs and the many gallons of “swirly fluid”. If you want to go inaudible, I can show you how to isolate your D5 pump(s), it’s not difficult, only a few extra steps to absolute silence, say at 2-4inches of operating distance from your ears and beyond. You will always pick up some minor auditory output if your ears are positioned directly on top of a fan or pump, the coolant flowing through the loop and the gaseous air volume moving over the radiator fins can never be moved into the range of inaudibility. Luckily those sonics only travel a very minor distance from the source if pump and fans are well isolated and rpms managed.
Yep, you might want to consider some wheels to move that monster around, it's going to be very heavy when filled up with water parts.
swirly fluid = nanoparticle coolant
PM is on the way bro...
Going ahead and purchasing BOTH the Maximus 11 Apex and the EVGA Z390 DARK. Not certain which will end up as primary board in the Batman work build, yet the competition for that spot should be EXTREMELY INTERESTING, if you know what I mean.
Spoke with the Silicon Lottery guy and he's also picking up both motherboards - obviously for business reasons. But I wanted to make certain he had the EVGA Z390 DARK in hand - in house, just in case I need a wingman for support. lol
![Smile :) :)](https://tpucdn.com/forums/data/assets/smilies/smile-v1.gif)
You know a new bios to navigate through. IF I get stuck during setup or while overclocking.
Whichever board doesn't make the prime spot will go into the 2ndary "everything but work" build, most likely splitting hairs really, both motherboards seem so beyond amazing, over-engineered and overkill for the designated purpose? Most likely. Then the Apex 10 from 2017 will move into a tertiary build, quite certain that learning computer I've been wanting to put together for the little one. Was going to order a white and pink CaseLabs S8S for the learning build, but well, looks like that's not going to happen, although I still have a strong feeling CL will return in some form by this summer.
This AMD HHHL workstation card (below) will also move into "parts" for the learning computer, since AMD should be announcing the new Vega-based lineup any day now. Believe they are only moving the nomenclature by a single digit so the replacement workstation card will be the WX-4200. AMD is retaining the YInMn Blue aesthetic. These smaller inexpensive workstation graphics cards are for light-duty rendering projects, AMD doesn't tell you they also generate the clearest cleanest crispest TEXT on planet Earth, and the fan can be easily dialed down to inaudible using MSI Afterburner, which I was surprised recognized a workstation card.
An engineering buddy from college clued me in on that minor factoid.
