be quiet! Dark Power PSU Owner Reports Melting of 12VHPWR Connector
43 (0.06/day)
It dont matter if they sold 100.000 PSU's and only one report, or 10 reports. One is too many knowing it can set your house on fire.
These things are extremely sensitive.
It does matter every device has a failure rate and return rate.
Even a car can randomly be set on fire or even explode (the electric ones) it doesn't mean we should jump to conclusions and stop using all of them.
If there was real or high fire hazard I'm sure proper safety certification organization wound ban selling those PSUs. An bequit or any other company would have to recall them.
I have a 4070ti that I put super glue on the power connector. Sure its not as hot as 600w 4090 but the sudden connector power melting drama got me scared that time.
If this is not a joke you actually increased fire hazard since super glue is flammable.
I really don't get why we do not get lower power rated cables with those PSUs or GPUs. I mean only 4090 actually needs 600W cable.
Other cards could use 450W or 300W cables and therefore power would be limited by PSU itself and GPU driver.
Lower power, lower electric current, lower heat on connector, lower fire hazard.
WTH happened with this idea?
3,476 (2.54/day)
Processor Ryzen 5 5700x
Motherboard B550 Elite
Power Supply MSI 750w
Mouse G502
No, you know why electric cars immolate themselves, there is always a risk and the causes are investigated, failures happen on any part.
But if a single cable was the cause of several fires i can guarantee you that cable you'd be discontinued, recalled and the matter would be investigated. And if the company knew and continue to sell them them were in for a bad time, including jail time.
54 (0.02/day)
System Name The Berserker Armor
Processor Ryzen 7 7700x
Motherboard Asus TUF Gaming X670E Plus Wifi
Cooling CORSAIR ICUE H150i RGB ELITE
Memory Corsair Vengeance DDR5 2x16GB 6000mhz
Video Card(s) ASUS TUF Gaming RTX 4070 Ti
Storage Samsung 980 Pro 1tb, Samsung 980 1tb
Display(s) LG 27GL850-B 144hz
Case Corsair 5000D Airflow Black + 3x SP120 fans
Power Supply Seasonic Focus Gold GX-850
Mouse Corsair Harpoon Rgb Pro
Keyboard Corsair K60 Rgb Pro
GG, now you can't pull it out when it does melt :roll:
I hope not. I think I still can be pull it out with a slight force. I'm not that stupid enough to pour a lot of glue on it. Just a tip in corners to prevent them being push out by itself. :laugh:
No joke I was really scared since its the most expensive GPU I ever bought. I think its fine I didn't pour all over it. Just a tip in corners.
129 (0.06/day)
Processor i9 10900K
Motherboard ASUS Z590 E-Gaming
Cooling CPU AIO - EVGA Liquid cooled GPU - Air cooled
Memory 32GB
Video Card(s) Zotac RTX 3090 Ti Holoblack (NTK female pins in the cable that came with the GPU)
Storage Too many to list here !!!
Display(s) 32" Samsung 4K (Smart Monitor)
Case Obsidian 500D
Audio Device(s) Monitor - see above
Power Supply EVGA 1000 watt
Mouse EVGA X17
Keyboard EVGA Z15
Software Win 10
That idea is used, but also abused, only need to ground the sense pins GPU side to trick (allow) the full wattage (600 watts), the GPU will pull what ever it needs at that point up to it's max limit from any PSU, as in the case for the RTX 4090 FE - thats 600 watts as defined in the BIOS, as for all other cards that's dependent on the limits set within the BIOS for the GPU as well, but I've seen GPU's pull over that max limit in some cases as well.
As for the pure 12VHPWER cable designed for / come with ATX 3.0 PSU's that actually have the 12VHPWER connector, that will also depend on how those sense pins are wired to both connectors (GPU side to PSU side), most will be wired to allow full wattage (600 watts) as these PSU's are supposed to have the logic circuit built into them.
DarkChib
4 (0.00/day)
Yeah I get it that its likely consumer error but if the damn design is soooooo crappp that this can happen...
Well its a shockingly bad design that these events can happen from just being 1 or 2 millimetres not homed into the socket
Cant say I have ever had any issues with other prior lead designs like they are having with this one in the near 29 years of building and maintain PCs personally and professionally.
1,399 (0.81/day)
Too little connector, too thin metal parts for 600W; they heat up, how much - depends on design or being plugged in properly. Not worthy of being part of any standard really.
7,686 (1.78/day)
You don't have so many issues with heaters(radiators?) consuming 2kw+ in homes! Nvidia should provide an additional "kit" for fireproofing with everyone of these :slap:
337 (0.23/day)
This problem highlighted something I couldn't belive. No youtubers and no websites are telling the truth while the reason is known to even a 10yo with basic electricity knowledge:
THERE IS MORE POWER GOING THROUGH SMALLER/LESS CABLES=MORE HEAT=NEEDS MUCH MORE PRESSURE TO HAVE A TIGHT CONNECTION, AND MORE MEETING SURFACE.
the_finn
1 (0.00/day)
I have a Be Quiet atx3.0 PSU and in the manual it says "Do not bend horizontally" and "do NOT bend less than 40mm" when using the PCIe 5.0 cable... Just saying....
807 (0.66/day)
People's Republic of Banania
Processor Threadripper 3955WX
Motherboard M12SWA-TF
Cooling Arctic Freezer 4U SP3
Memory G.Skill Trident Z DDR4-3733 (2x8GB)
Video Card(s) 5700XT + 3x RX 590
Storage A lot
Display(s) ViewSonic G225fB
Case Corsair 760T
Audio Device(s) Sound Blaster Z SE
Power Supply be quiet! DPP12 1500W
Keyboard IBM F122
Software 10 LTSC
free extinguisher with the purchase of any 4000-series graphics card!!!
119 (0.13/day)
Not surprised at all that this is happening with a beQuiet PSU. That company produces nothing but garbage and is one of the most overrated gigs in hardware land.
3,497 (1.11/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
I am furthermore unconvinced that this is widespread or even a cause for concern, statistically speaking.
Widespread no. Cause for concern? Yes, undoubtedly everyone who buys a card with this connector should be ensuring that they seat it fully as it is known to be hard to plug in all the way. By definition it is something of concern people need to take in mind to ensure special care. The current statistics already include the fact the people who are purchasing these cards are already taking precautions to ensure, more so than other connectors, that it's fully plugged in. Any statistics already have have a level of concern for this connector's unique issue baked into them.
In addition, we still don't know how many of these instances we'll see when the market fully saturates with this connector and how many of them fail as their wear increases. As of right now the current failure numbers are a best case scenario for this connector. People are taking pre-cautions to ensure it's fully connected because it's mostly enthusiasts that purchase the card and these connectors are brand new with no wear. Obviously the total number of burned up connectors will increase as saturation increases but it'll be interesting to see if the rate increase as wear and less savvy users get their hands on the cards.
It's a known issue with the connector due to the way it's designed. Unfortunately a lot of people are not going to care about that or don't have a choice due to case restrictions. Not sure if bending alone can cause the connector to burn up but then again the PSU should be robust as it typically lasts multiple platforms.
Based on the tests Igorslab and GamersNexus did, yes, I believe so with the cables being AWG16.
Yep, the cables aren't the issue. It's litteraly just the pin design and locking mechanism that are the problem here. Intel has suggested a version with an updated pin design but they should also improve the locking mechanism as some users have reported the cable backing out over time even when they fully clicked it in.
807 (0.66/day)
Storage A lot
Case Corsair 760T
Keyboard IBM F122
Software 10 LTSC
#61
Bad connector is bad, such wow. Sometimes size does matter, oh and pins should be round and solid instead of square and hollow.
262 (0.30/day)
Do Intel Arc GPUs even use the 12VHPWR?
A case of Intel saying to nVidia "here, take this and run" and nVidia dying on the 12VHPWR hill instead of Intel?
This might do for a funy SNL comedy sketch.
129 (0.06/day)
Processor i9 10900K
Memory 32GB
Case Obsidian 500D
Mouse EVGA X17
Keyboard EVGA Z15
Software Win 10
Yes, but not on their consumer class cards right now, but that could change with their next gen card, just the data center side for now (see article below for info on that).
2,488 (1.17/day)
Olympia, WA
System Name Sleepy Painter
Processor AMD Ryzen 5 3600
Video Card(s) MSI RX580 8GB
Case NZXT Gamma Classic Black
Audio Device(s) Asus Xonar D1
Mouse Logitech MX518 Legend
Keyboard Red Dragon K552
Can't wait for 'adapters' to hit the market that plug into the 12VHPWR, provide 'battery terminals' and include 0000 AWG copper wire leads.
:shadedshu:
ARF
4,670 (2.53/day)
Ex-usa | slava the trolls
I think the most normal thing is that nvidia gets sued. And the court investigates the issue, and sets a multi-billion fine, and bans the said connector. Which is anything but connector. It's a crap..
321 (0.15/day)
No.
This only happens in lala land where you live, since lalaland is devoid of fact or reality.
ARF
4,670 (2.53/day)
What is your "fact" ? :D :kookoo:
If you, by any sad chance, have got a "diploma" in Electrical engineering, you must throw it in the trash. NOW!
410 (0.46/day)
If the cable is the issue then how did Cablemod drop the ball and have 20 reported cables burned on record?
The only fix I see is to have a cable with thermal sensors on both sides with color coded and or digital user feedback etc etc. Thoughts?
138 (0.02/day)
Türkiye
System Name Revenge of the Strix
Processor Ryzen 5800x3d
Motherboard Asus Strix-e x570
Cooling Corsair H150i pro xt
Memory Crucial Ballistix 32 GB DDR4 3600 MHz CL14
Video Card(s) Red Devil 7900xtx
Storage Adata S50 1tb gen4 - WD Black 1tb gen3 - Seagate2tb SSHD - WD 2tb
Display(s) Dell G3223Q
Case Asus Helios
Audio Device(s) X-fi + Bose Companion 50
Power Supply Seasonic Focus GX 750w
Mouse Asus Pugio II
Keyboard Asus Falchion
no suprise here. never accept this 5.0 standart anyway. 2019 seasonic gold FTW and phanteks version of course. using 2 focus an a amp! 750w for years. 600w with single cable? yeah sure brilliant!
129 (0.06/day)
Processor i9 10900K
Memory 32GB
Case Obsidian 500D
Mouse EVGA X17
Keyboard EVGA Z15
Software Win 10
There are plenty of reports on the internet with this melting issue with the 12VHPWR connector, and if you delve in deep enough you will see that it's mostly related around the version of female pin with dimples that is used, CableMod, a 3rd party that makes cables and special connectors are not the only ones that have made the "mistake" with using the wrong female pins in the connectors for the 12VHPWER products, below is an image of their right angle adapter, it's using the female pins with dimples as does their other cables with the 12VHPWER connector (not sure if they changed over to the correct pins here).
Because they also screwed up and used the wrong pins for their cables and adapters, you can see the pins are the ones that have dimples in the image below and elsewhere on the internet if you look for them.
These pins with the dimples (ASTRON) are not up to the job and should not be used in the connectors, they don't provide enough surface area for power to flow with those dimples for 600 watts.
The image below shows the female pin from ASTRON, they are not ideal for the job, they are weak due to the two slots in it for a start vs the NTK female pin.
The NTK pins allow for more surface contact on the male pin when they are connected together and allow better power flow and reduce the heat, the pin does not have the two open slots to weaken it either (splay apart), I have not seen any GPU with melted connector using these pins (RTX30x0 FE, RTX3090 Ti, RTX 4090 FE, RTX 4080 FE).
This is not going to happen, it's not an Nvidia issue, they did not design this power connector standard.
3,497 (1.11/day)
Mouse PMM P-305
VR HMD Valve Index
Software Win 10
Did you read my comment? I specifically said the cable WAS NOT the issue.
Yep, the cables aren't the issue. It's literally just the pin design and locking mechanism that are the problem here.
There are multiple instances of me pointing out that the connector is the source of the issues throughout my comment. I even specifically point out the pin design.
ARF
4,670 (2.53/day)
They must take the responsibility for using it. It is very unsafe, and could lead to your PC components on fire.
AMD is wiser. AMD doesn't use it. Do you know why?
129 (0.06/day)
Processor i9 10900K
Memory 32GB
Case Obsidian 500D
Mouse EVGA X17
Keyboard EVGA Z15
Software Win 10
It's not an Nvidia issue, the 3rd parties are not following the specs / guidelines for this connector, and Nvidia did not design it, Intel designed it.
