Best Power Supply Buying Guide (Jun 2020)
7,412 (2.67/day)
Poland
System Name Purple rain
Cooling Noctua D15S
Benchmark Scores A LOT
166 (0.09/day)
System Name A bomb
Processor AMD Ryzen 7 3700X
Motherboard MSI B450 Gaming Plus
Cooling Corsair H115i PRO + 4x Noiseblocker eLoop push-pull
Memory 2x8GB G.Skill TridentZ 3600MHz 19CL @ 16-20-20-36
Video Card(s) MSI GTX1060 3GB Gaming X
Storage Intel 660p 1TB QLC NVMe SSD (yeah, it's really that slow) + Seagate Exos 10TB HDD
Display(s) AOC C24G1 24" FullHD 144Hz VA
Case Phanteks P400S + P400A mesh panel + 2x140mm & 1x120mm be quiet! Shadow Wings 3 + 1x120mm Noctua NF-F
Audio Device(s) Corsair HS50
Power Supply Corsair RMx v2 (2018) 750W
Mouse Corsair Harpoon RGB Wireless in wired mode (wireless mode is bugged ...)
Keyboard A4Tech generic-ish membrane office keyboard (yikes)
Software Windows 10 x64 1909
Benchmark Scores OVER 9000
is this the whisper m you're talking about ? seems a lot cheaper than others
Yep, it looks kinda funky but it's almost the same thing (and really the same thing as Deepcool DQ-M) inside as Corsair RMx, very similiar platform, there are some minor difference in ripple (due to in-cable caps on Corsair) and noise output (Corsair has a bit smarter fan controller but Whisper is very quiet too) but as you see it's often very cheap and sells like a hot cakes in Europe (it's very hard to find anywhere else).
7,412 (2.67/day)
Poland
Cooling Noctua D15S
166 (0.09/day)
System Name A bomb
they seem loud tho.
In fact, it's even quieter than Whisper M, no idea why (550W version were completely fanless in Aris review even, maybe they've fucked up fan controller in that batch).
Edit: side note on Formula and Whisper, 450/550W SKUs had some reports of shutting down with high-transient load GPUs on them. Probably due to too sensitive OCP on single GPU rail available on 450/550W versions which kinda confirmed by no such occurences with 650W+ versions which have two rails for GPU connectors and hard mod you can still do on 450/550W versions to add a second cable on second rail still present physically. So if anything, aim for 650W+ versions of them.
you think superflower leadex gold I've had from Nov 2014 is due replacement ?
Eh, if you're content with it's performance (acoustic mostly as you don't see electrical but it should be fine) then i see no reason for that, it's a good PSU with quality components.
7,412 (2.67/day)
Poland
Cooling Noctua D15S
I mean the whisper series is loud,take a look,the 850w one ramps up to 1500rpm at 100w
SP11 plat spins at 400rpm up to half power
166 (0.09/day)
System Name A bomb
These graphs you see in manufacturer marketing materials are useless as modern fan controllers don't account only for load but temperature too and how the load changes, you need to look at actual reviews. And Aris have reviewed both lineups.
7,412 (2.67/day)
Poland
Cooling Noctua D15S
dunno,rm650x kinda checks all the boxes,10 yr warranty including
is this the right 2018 version ? I saw more than one
166 (0.09/day)
System Name A bomb
Doesn't matter, both 2015 and 2018 versions are practically identical in performance. But yes, that's 2018 version (you see *2017* in the model number, where as 2015 version had *2009* there, SKU project start date i assume).
7,412 (2.67/day)
Poland
Cooling Noctua D15S
never had a multi rail psu before,if my 2070S has two 8 pins they both plug into vga 1 ?
166 (0.09/day)
System Name A bomb
My rule of thumb, if your GPU needs two PCI-e power connectors then you need to use two separate cables (not one Y-split, except for rare instances where a cable with two connectors on GPU end actually has an appropriate amount of pins on the PSU end), but if you don't have problems running it with two cables from one rail (only VGA 1 or 2) then yeah, it's fine, if it would trip OCP (which would require cycling the PSU power switch if it really have tripped, if it just restarts that not a PSU) then you can split the load to two rails but i'm sure that wouldn't be needed for RTX2070 Super.
7,412 (2.67/day)
Poland
Cooling Noctua D15S
so better run one from vga1 and another one form vga2 ?
166 (0.09/day)
System Name A bomb
No, try running from separate cables but from one rail, if PSU trips (highly unlikely with this GPU) then split the load for two rails.
7,412 (2.67/day)
Poland
Cooling Noctua D15S
why not just split it in the first place ? the gpu is not a power hog,but overclocked it can probably hit ~250w.isn't it too much for a single rail ?
166 (0.09/day)
System Name A bomb
You can, but you lose the purpose of multi-rail - lower OCP trigger point to potentially save your equipment with higher chance should a short occur (on GPU cables or in the GPU itself).
7,412 (2.67/day)
Poland
Cooling Noctua D15S
oh,I didn't think of that.multi-rail is not really that popular these days.
2,196 (0.34/day)
Darkness
System Name Unreal Machine IV
Processor Ryzen 7 5700X
Motherboard Asrock 570X Taichi
Cooling Noctua U9S
Memory Team UD4-4000 @4000 CL18 1:1
Video Card(s) 5600XT Red Devil
Storage Kingston SSD 240GB + WD RED 4TB + WD Blue SN 550 Nvme 1TB X3
Display(s) DELL U2417H
Case Old school Termalthake xaser III black with lots of noctua 80mm fans
Audio Device(s) Creative SB X-Fi Titanium Fatal1ty Champion + Creative Inspire t7900 7.1 + Sony MDR-1A + AKG K-240
Mouse Logitech G502 hero SE
Keyboard Logitech
Software 10 pro
Benchmark Scores Cinebench R23 Multi ~15k 4.4Ghz all core Cinebench R23 single 1.5k 4.65Ghz
From what little i know, it never was, enthusiasts always preferred single rail but at one point for safety reasons psus had split rails, like my former Zalman, it had like 6 split rails combining over 60 amps, a little over my current Seasonic with 63 amp single rail irc...
The most power hungry GPU I had was a radeon 2900XT no issues ever with psu...
7,412 (2.67/day)
Poland
Cooling Noctua D15S
I just thoght of sth else - wouldn't splitting the load keep the temps a little cooler ?
166 (0.09/day)
System Name A bomb
No. You already split the load using two separate cable and connector sets. Using two separate rails doesn't change much in this regard as all modern multi-rail units are physically single-rail in fact, with just a set of additional 12V traces (which are usually there anyway on single-rail units, just bridged) and multi-channel supervisor IC.
7,412 (2.67/day)
Poland
Cooling Noctua D15S
thanks.
would getting a 850w instead of 650w improve noise output tho ? I mean at gaming load on my 2070s,not 100% ?
166 (0.09/day)
System Name A bomb
thanks.
With gaming load - not really, you'll be hitting about 300W sustained which would be in the idle/zero RPM area anyway both on 650W and 850W SKUs.
7,412 (2.67/day)
Poland
Cooling Noctua D15S
on BF whisper ? I thought it's not semi passive.
166 (0.09/day)
System Name A bomb
It's not but fan speed at sub ~50% load is flat ~400 RPM for 550W unit and ~700 RPM for 850W unit, might vary by revision but it seems that 850W SKU is actually a bit less quiet than 550W one at idle (probably because of higher maximum RPM fan at 850W SKU which can't sustain RPM that low), so go for 650W one.
7,412 (2.67/day)
Poland
Cooling Noctua D15S
It's not but fan speed at sub ~50% load is flat ~400 RPM for 550W unit and ~700 RPM for 850W unit, might vary by revision but it seems that 850W SKU is actually a bit less quiet than 550W one at idle, so go for 650W one.
couldn't find this data.
166 (0.09/day)
System Name A bomb
7,412 (2.67/day)
Poland
Cooling Noctua D15S
thanks, you've been a lot of help.
dunno how much longer I'll stay on my sf leadex,it's good but elctronics and fans don't last forever,better be safe than sorry and do your research on a new psu before.
