- Sep 20, 2006
- 457 (0.07/day)
System Name | The Terminator. |
Processor | Intel i7 950 3.06Ghz. |
Motherboard | Asus P6X58D-Extreme |
Cooling | Stock. |
Memory | Corsair 6GB (3x2GB) DDR3 2000MHz Dominator-GT Memory Kit CL8 (8-9-8-24) 1.65V |
Video Card(s) | Sapphire HD 6950 2GB GDDR5. |
Storage | WD 1TB 3.5" SATA-III 6Gb/s / OCZ Vertex 120GB SSD. |
Display(s) | 24'' Widescreen Samsung 1080p. |
Case | Antec 1200 Gaming Case. |
Audio Device(s) | Realtek. |
Power Supply | TX 650W Corsair |
Software | Windows 7 Enterprise 64 bit |
Okay, so i got my Antec 900 yesterday evening but was up all night trying to assemble it, right now im on another computer since its still out there, i gave up.
I've encountered serious wiring problems.
Problem: I have a Type R 580W PSU which i assumed would have no problems whatsoever since its a bloody good PSU and the measurements seemed to work out. After a hellish hour of getting all the wires setup in a vein attempt to utilize the wire straps to 'neaten it up', i came across the ATX_12V power connector...
I cant get a picture of MY case so im going to use Techniks tp help illustrate my problem, if he doesn't mind!
The Blue line is the cable and the red circle is the socket it has to reach. The problem is, this cable is now stretched tightly over the edge of my graphics card and tucked under my CPU cooler, resting on the lower heatpipes of my Arctic Cooler Pro 7, which is the same as Techniks in the picture. This is the ONLY way i can get that cable into the socket but im pretty sure that wire will obstruct the heat synk and graphics card like that.
Basically my system is near enough the same as Techniks except the motherboard, hence the awkward ATX socket! Not to mention the limited space and horrible awkward wiring i've got down the right side which is almost rendering this case useless.
What shall i do? Is there any way i can sort all this out without having to buy MORE stuff?
I'll appreciate ALL help, that damn case had me up for hours!
<--- My specs.
NOTE: The picture is NOT my system, im only using someone elses to illustrate my wiring.
Cheers,
Hux.
<--- My specs.
Cheers,
Hux.
