BIG Problem - Antec 900!
457 (0.07/day)
System Name The Terminator.
Processor Intel i7 950 3.06Ghz.
Motherboard Asus P6X58D-Extreme
Cooling Stock.
Memory Corsair 6GB (3x2GB) DDR3 2000MHz Dominator-GT Memory Kit CL8 (8-9-8-24) 1.65V
Video Card(s) Sapphire HD 6950 2GB GDDR5.
Storage WD 1TB 3.5" SATA-III 6Gb/s / OCZ Vertex 120GB SSD.
Display(s) 24'' Widescreen Samsung 1080p.
Case Antec 1200 Gaming Case.
Audio Device(s) Realtek.
Power Supply TX 650W Corsair
Software Windows 7 Enterprise 64 bit
For now you can leave the cable under the vid card ,BUT when you have the $$ buy the extension , really don't like "between the ram stix" :shadedshu
AS for the Harddrive and 4 fans all running off one molex power cable :eek::shadedshu
run the Hdd on it's own Please;)
Hehehe, well its not between them, its actually round the side of the ram stix, in the space between the CPU cooler and the ram slots. The wire is under the end of the X1900XT (So just touching the plastic) but isn't tight round it. The end of the wire is just bent round the CPU fan and into the slot. I will have pictures soon hopefully.
Thanks for your advice Frogger and thankyou ALL for helping me out, im sitting here now with my Antec 900 purring (Quite loudly might i add) with a graphics card and CPU 10*C cooler at idle, i just gotta work on those Vregs. :ohwell:
39*C GPU Idle
44*C Vreg idle
30*C Motherboard
24-27*C CPU idle
What do you think of those temps guys? My X1900XT is not overlocked or anything, should my temps be better or are they good? Just need that last bit of reassurance that all this has been worth it so let me know what you think d00ds!
Thanks a lot all, :D
Hux.
457 (0.07/day)
Cooling Stock.
Must... Revive... Thread...Thread...Dying... Must...Know...If Temps...Are good... :D:pimp:
Hux.
DOM
7,628 (1.11/day)
TX, USA
Processor Intel i7 4770K
Motherboard Asrock
Cooling Water
Memory Team Xtreem LV 16GB (2x8GB)
Video Card(s) EK Full WB HD7970
Display(s) CROSSOVER 27Q LED-P 27"
Case Danger Den Torture Rack
Power Supply CORSAIR Professional Series Gold AX1200
Software W 10 Pro
Yes there good :toast:
457 (0.07/day)
Cooling Stock.
