Bios Rtx 3080 ti Zotac amp holo help
browey
15 (5.00/day)
Hello, does anyone have a BIOS for the RTX 3080 Ti Zotac Amp Holo that doesn't consume so much power because when it reaches 70 degrees the fans go to 100%? The way I have it is with Undervolt but there's no way to do it with a BIOS. Regards.
42,953 (6.71/day)
Gpu-z screenshot and a picture of the white sticker model/part number sticker please
browey
15 (5.00/day)
Where do I see that in the example model please, thanks
42,953 (6.71/day)
42,953 (6.71/day)
browey
15 (5.00/day)
I bought it a few months ago and it looked like this. I did maintenance on it with thermal pads and thermal paste.
42,953 (6.71/day)
I hope you used the correct thickness of the pads, also thermal pastes being replaced by pads now too
Does the card look like every picture here?
42,953 (6.71/day)
use 2mm artic and artic mx4 thermal paste
Did you use a metric gap gauge, also known as a feeler gauge? What about a micrometer caliper?
If a pad is too thick a board can get flexed possibly breaking the bga and trace/smd bonds after several heat and cold cycles occur
42,953 (6.71/day)
Forgive my ignorance, what is that?
Since you are asking that, it means you didn't use those tools or even know what they are, to measure the gap clearances between the ram, vrms and gpu die with the heatsink mounted with nothing on it.
42,953 (6.71/day)
I just changed the thermal pad and thermal paste, I bought it almost new.
So i wrote a question with a link, does the card match the link above?
42,953 (6.71/day)
if it is that is it
The bios on your card states LHR and LHR and non LHR are not interchangeable, so the cooling looks like that?
42,953 (6.71/day)
42,953 (6.71/day)
Heres the rest that match your dev id ssid.
change the bios?
is using the second
No dont change it, nothing you flash will change anything, i looked at the files.
They all have a target tdp of 350 and max of 385.
350.0 W Limit: 385.0 W
42,953 (6.71/day)
You could maybe try this since it states LHR on the gpu identifier.
and what can I do to download it and fix it?
There is no modifying bios files now as it breaks the signature, which would make the driver not install, you could try the file below but with bios flashing you risk a brick, so unless if you have a igp/apu or a spare card, i wouldnt flash it.
browey
15 (5.00/day)
It doesn't let me with that BIOS. I tried it and nothing comes up with this ERROR: GPU PCI Device ID mismatch.
42,953 (6.71/day)
Only other solution would be to sell the 3080ti and get the Sapphire Radeon 6900 series which have a lower tdp.
