BSOD or something like that! Determine cause? Help me forum friends
156 (0.04/day)
System Name 2022 PC / 2020 PC
Processor Ryzen7 7700X / Ryzen7 5800X
Motherboard ROG X670e EXTREME / ROG Crosshair VIII Hero
Cooling Rog Ryujinn II ARGB / Capellix H100i
Memory F5-6000J3636F16GX2-TZ5NR X2 / Trident z Royal 3200Mhz Cl14
Video Card(s) Zotac AMP Triniti RTX 4090 /EVGA FTW3 ULTRA 3080
Storage Kingston 2TB Fury Renegade / Aorus PCIE4 1TB
Display(s) S95B / S95C
Case anidees AI Crystal PC / Infiniti 2
Power Supply Thermaltake Toughpower GF 3 1000W / TT Toughpower GF1 ARGB 850w
Mouse Razer Basilisk V3
Keyboard Asus Animate ii/ Corsair KG100
Software windows 11 X2
*** if the post is in the wrong forum please move it***
I will try to be quick. At the end of 2022 I decided to make an uber PC since we know consumption is a form of therapy. Got an RTX 4090 and an ASUS ROG X670e extreme!
i have had various issues with this build primarily to Asus bioses (hot zen4) bad software (armory crate not working at ALL!). i have made my PC with these issues and I have been using my PC and gaming was a blast at least.
For the last 3 days I have had a very curious issue and I need to determine the cause. While I was gaming a not extremely heavy game (Star wars battlefront ii) for the first time my PC had a black screen and all the fans (or some of them cannot determine) started firing on all cylinders and making huge noises like they were spinning at 100%. this had never happened before so I ignored though I got a bit curious. 2 days later (without gaming at all) it happened while I was on the desktop doing nothing PC intensive just browsing. Unfortunately, I tried to game today and after 15 minutes it happened again. So 1 time is random 2 times is a warning, 3 times is a problem
The screen (TV) turns black and says there is no signal and the fans start running like crazy.
how to determine what;s the cause? Motherboard or GPU? i have contacted my PC retailer but I want to be able to pinpoint the cause! I cannot think of anything else! I undervolt my CPU (since Asus bios suck and it runs my CPU mostly at 1,35v and over) so it shouldn't be an overheating CPU.
i am thinking of doing a fresh install of windows 11 but before that, I want to check my PC.
Any advice is welcome. i have gotten a lot of help the last years while on this forum
3x0
955 (1.31/day)
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550I Gaming Edge Wi-Fi ITX
Cooling Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
Memory 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
Video Card(s) PowerColor Radeon RX7800 XT Hellhound 16GiB
Storage Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
Display(s) Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
Case Cooler Master NR200P ITX
Audio Device(s) Altec Lansing 220, HyperX Cloud II
Power Supply Corsair SF750 Platinum 750W SFX
Mouse Lamzu Atlantis Mini Wireless
Keyboard HyperX Alloy Origins Aqua
If you have any .dmp files in C:\Windows\LiveKernelReports or C:\Windows\Minidump zip them up and upload them here.
156 (0.04/day)
Thank you.
Mindump was empty. livekernelreports had watchdogs(the game?)
  • WATCHDOG-20230703-1115.zip
3x0
955 (1.31/day)
The crashes are all related to the GPU. If you bought the PC prebuilt/in one place, I'd tell the retailer to check if replacing the GPU fixes the issue.
Watchdog is a debug feature of Windows, not related to Ubisoft :D
156 (0.04/day)
how can you know that? is there something I can do? i didn't buy it prebuilt but at least I bought the GPU and mobo from an established retailer with whom my employer has a long standing business relation
3x0
955 (1.31/day)
Bugcheck code 141 is pretty much always related to GPU issues.
Apart from slightly underclocking the card, changing the display cables, trying a different PSU or trying a different display there's nothing much you can do. Either way, it's easier if the retailer checks if the GPU exhibits instabilities on their test system.
156 (0.04/day)
I just did some test. i used OCCT and test my GPU VRAM. same result BSOD!@
4,990 (3.86/day)
Colorado, U.S.A.
Software Windows 11 Home
The latest NVIDIA driver was about 3 days back; did you update?
402 (0.52/day)
Some Where On Earth
System Name Spam
Processor i9-12900K PL1=125 TA=56 PL2=288
Motherboard MSI MAG B660M Mortar WiFi DDR4
Cooling Scythe Kaze Flex 120mm ARGB Fans x1 / Alphacool Eisbaer 360
Memory Mushkin Red Line DDR4 4000 16Gb x2 18-22-22-42 1T
Video Card(s) Sapphire Pulse RX 7900 XT
Storage Team Group MP33 512Mb / 1Tb
Display(s) SAMSUNG Odyssey G50A (LS27AG500PNXZA) (2560x1440)
Case Lan-Li A3
Audio Device(s) Real Tek on Board Audio
Power Supply EVGA SuperNOVA 850 GM
Mouse M910-K
Keyboard K636CLO
Software WIN 11 Pro
Get Hardware 64 and see what the power supplies voltages levels and thermals are doing during a stress test (You may even want to have HW64 logging while your stress testing your system in case it BSOD's). I would also look over all of your power connections to make sure that they are not starting to melt (12VHPWR Connector).
My best guess is your power supply is starting to go flat on you or the 4090 is starting to have assembly/thermal issues.
41,476 (6.58/day)
Update complete system specs
156 (0.04/day)
41,476 (6.58/day)
HI i updated them.
Do you think it can be a power supply issue? i took the pc to the doctor clinic :)
Remove the gpu and run it using the igp for troubleshooting, with it being a 4090 you may need a Higher Quality Wattage Powersupply so instead of 1000 more like 1200+
bailmage
1 (0.00/day)
I recently did an RMA for a 4090 with this same issue. When I got the new one the issue persisted. As it turns out the GPU wasn't seated correctly due to the bracket lifting it ever so slightly out of its slot. I took the three screws out of the bracket that hold the GPU to the case and I layed the case on its side and reseated the card and boom! Issue gone!
