Building my first pc! Need advice! Am I in the right forum???
Shake_nBlake
2 (0.00/day)
First and foremost, please let me know if im in the wrong forum. Thanks!
I'm building my first pc and im not very sure what parts are the best. The idea is to build a computer that can handle my everyday needs while double as a decent gaming pc but not like a heavy gaming pc. My budget is just over $1000. Here is what i have so far.
Any advice would be helpful. Please let me know what you would do better, if there is anything missing, or something unnessassary i have listed. Thank You so much!!!
1,278 (0.29/day)
Motherboard MXI APEX
Storage 660P 1TB, 860 QVO 2TB
Case Open Benchtable V2
Audio Device(s) SB X-Fi
Power Supply MSI A1000G
Mouse G502
Keyboard G815
Software Gentoo/Windows 10
$400 for 2060 super seems steep. You may want to hold off until prices drop when new cards release next few months. Aim for about $250 new or second- hand.
11,046 (1.75/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
Not bad!
Some comments
1. you need a case.
1.5 you need a power supply
2. you don't need optical drives
3. get rid of the barracuda and get an ssd (don't use spindles if you don't need to)
4. get 3600 mhz memory
5. don't spend $85 on a cooler for that chip
6. Don't spend $108.78 for a windows 10 license, you can get a license from a graymarket site for like $10
7. Upgrade your monitor to 1440P
1,645 (0.98/day)
hdd and dual optical what is this 2003 xD
On a more serious note: You didn't select a case, didn't select SSD; selected a cooler that's way overkill (well, if you plan on upgrading I guess), and a poor gpu given context (2070 costs the same as 2060S, but is better). Oh, the B450 is obsolete now there's B550.
1,470 (0.21/day)
Processor Ryzen 1600AF @4.2Ghz 1.35v
Motherboard MSI B450M PRO-A-MAX
Cooling Deepcool Gammaxx L120t
Memory 16GB Team Group Dark Pro Sammy-B-die 3400mhz 14.15.14.30-1.4v
Video Card(s) XFX RX 5600 XT THICC II PRO
Storage 240GB Brave eagle SSD/ 2TB Seagate Barracuda
Display(s) Dell SE2719HR
Case MSI Mag Vampiric 011C AMD Ryzen Edition
Power Supply EVGA 600W 80+
Aside from gaming you haven't specified what you're going to use the computer for so it's kind of hard to recommend or comment on your build, what I would say is an ssd drive is a must for the os, do you really need 2 dvdrw drives? I haven't used one in years.. You have no power supply listed also
Not bad!
Some comments
1. you need a case.
He might have a requirement for the odd's which is why I also questioned them though by and large they are outdated and not really required by most people these days
Why not keep the hdd storage and get a 512gb ssd OS drive, I doubt a 2tb ssd will fit into his budget
+1 on the windows license
those gskill rams should be able to overclock to 3600 so depending on the cost of 3600 ram if its any more than 20/30$ then I personally wouldn't bother
2,261 (0.98/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
get your self a good PSU. its the most important piece of your rig and the best investment try for a make like seasonic at least 500w if you can get them near you. and goodluck, some fine parts you have picked i think you will have a nice rig when your finnished
Shake_nBlake
2 (0.00/day)
Thank you for the advice!
Not bad!
Some comments
1. you need a case.
Thank you for the advice, and i will change my selection accordingly! and yeah i am worrying about the interior before I select a case and such, prob should have mentioned that lol.
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
Display(s) DELL U2311H
Keyboard Microsoft Wired 600
I do consider this as the worst advice ever.
While Microsoft will not solve any of your problems because you will become an OEM license owner.
The legal operating system this will keep you away from the dark internet.
The most wise choice this is getting RETAIL version of windows, and this will reactivate if you switch a motherboard or five motherboards.
183 (0.08/day)
System Name My PC
Processor AMD 2700 x @ 4.1Ghz
Motherboard Gigabyte X470 Aorus Gaming
Cooling Zalman CNPS20X
Memory Corsair Vengeance LPX Black 32GB DDR4
Video Card(s) Sapphire Radeon RX 570 PULSE
Storage Adata Ultimate SU800
Case Phanteks Eclipse P500A
Audio Device(s) Logitech G51
Power Supply Seasonic Focus GX, 80+ Gold, 550W
Keyboard Roccat Vulcan 121
You can also get retail key for cheaper from online re-sellers.
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
As second recommendation, if Win10 graphic interface this is a source of evil to you.
You may get Win7 Pro Retail as used from eBay, box and DVD media and license, the complete blue box.
I did that too, but I do care for productivity than making decisions in favor of Gaming compatibility.
1,470 (0.21/day)
Dark Internet? Woah slow down I think he was referring to the key sites that advertise on tpu, not getting on tor and buying underground body organs with stolen credit card details :eek: :laugh:
313 (0.10/day)
Binghamton, NY
System Name The Final Straw - The ANTI "A.I" movement build.
Processor Intel i7-7700
Motherboard Asus Prime H270M Plus
Cooling Arctic Liquid Freezer II 120
Memory G.Skill 32GB DDR4 2400 - F4-2400C15D
Video Card(s) EVGA GTX 1660 Super SC Ultra 6GB GDDR6
Storage WD Blue SN550 512GB and 1TB M.2 + Seagate 2TB 7200 SATA
Display(s) Acer VG270U P 2k
Case Thermaltake Versa H17
Audio Device(s) HDMI
Power Supply EVGA 750 white
Mouse Logitech
Keyboard Logitech
VR HMD Why?
Benchmark Scores 3DMark06 = 33,624 / Fire Strike = 12,690 / Time Spy = 5,465 as of 7/16/2024
Making a note of how I get Windows 10 in the USA:
Get a LICENSE KEY from SCDKey ( or whoever TPU may promote ) and I pay with Paypal. NO CREDIT/ DEBIT CARD NEEDED! Less then $20.
Then:
Optical drives are outdated. Unless you have games on disk. But why two?
Are you going to be playing any games that require a Ray Tracing card?
M.2 SSD NVMe drive is missing in your pick list.
Seagate 7200 RPM drive, great for game storage. Not so great for loading Windows.
That Ryzen 5 3600 should already have a Wraith Stealth cooler, so you wouldn't need to spend extra on the be quiet! unit.
You can get by with just 16GB of DDR4 RAM. Upgrade to 32 GB later on.
600 watt 80 PLUS GOLD Certified Power supply with 5 year or more warranty.
8,917 (4.03/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
The free cooler that comes with the R5 3600 is fine, you can always upgrade later if you disagree with me, but you definitely don't need an $85 cooler for a 3600.
Buy an A520 board instead of a 2-year-old B450 board at this point. They're functionally similar but the A520 will likely support newer processors if/when you come to upgrading. You should be able to find a decent A520 board for $100 with a VRM heatsink and 4 memory slots.
Ditch the Seagate Barracude and replace it with a 1TB NVMe M.2 SSD. WD Blue SN550, Kingston A2000, and Sabrent Rocket are reasonable budget options. By the time you run out of space 4TB SSDs will probably be affordable, or you can always just buy a mechanical drive and add it in later if you really need more space.
Don't buy a retail Windows 10 license for $109. Microsoft give it to OEMs for next to nothing and you can buy a grey-market OEM license for $6 that is every bit as genuine as the $109 version. TPU even runs ads for a couple of companies selling those licenses about once a week on the front page feed.
If you still have DVDs now is the time to rip them to disk and abandon optical media for good. Optical drives are becoming extinct and the media itself degrades over time. Unless you are very careful about how you store your discs, you may find that many of the discs you burned as recently as 5 years ago are already unreadable.
4,895 (1.50/day)
Processor Core i7-13700
Cooling Cooler Master RGB Tower cooler
Memory Crucial Pro 5600, Corsair Dominator RGB 6000
Storage 970 EVO NVMe M.2 500GB,,WD850N 2TB
Case Corsair iCUE 4000D RGB AIRFLOW
Audio Device(s) EVGA NU Audio, Edifier Bookshelf Speakers R1280
Power Supply TT TOUGHPOWER GF A3 Gold 1050W
Software Windows 11 Professional v24H2
Does a A520 board allow running IF/RAM/Memory controller above 2933/3200 MHz?
8,917 (4.03/day)
Case Veddha T2
Mouse MX Anywhere 2
All the motherboard vendors are claiming DDR4-4400 or higher on their A520 product specs.
As for FCLK speeds, I'd assume A520 supports 1:1 all the way up, but don't actually know for sure. I'm guessing yes though - DDR4 clock and FCLK are linked. It would be weird to put a limit on one and not the other.
9,921 (1.82/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
it's like the other has answered the question, now how much you gonna spend for your pc
since you said that it's your first pc, you gonna build it by yourself or you gonna give it to some one to build it
if you gonna build by yourself and it's your first build i suggest back to basic first although it looks easy in reality you may find it little bit difficult and there always a risk you "kill" your hardware by mishandling it
3,687 (0.84/day)
GMT +2
System Name Red Radiance l under construction
Processor 5800x
Motherboard x470 taichi
Cooling stock wrath
Memory TridentZ Neo rgb 3600mhz (2x8 kit)
Video Card(s) Sapphire Vega 64 nitro+
Storage 970 evo nvme
Display(s) lc27g75tq
Case tt core x5 tge
Audio Device(s) sennheiser's pc323d usb soundcard
Power Supply corsair AX860i
Mouse roccat burst pro
Keyboard roccat ryos mk fx
Software windows 10
1,470 (0.21/day)
You won't get higher then 3933 1:1 on ryzen 3000 any higher ram than that and you will have to decouple the if to run at a lower ratio than the ram with a loss of performance
9,828 (3.46/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
I would change the HDD to even an off brand 1 TB SSD.
