Burning smell
31 (0.01/day)
My computer just suddenly shut off while i was playing a game and there's burning smell coming out from my computer
And also the computer doesn't turn on.. It tried for a split second but then nothing .. I opened the case but can't seem to track the smell and the capacitors seem to be ok
I5
R9 280x
4gb ddr3
525W psu 2 years old EX2 coolermaster
3,505 (0.60/day)
Well, first thing: open the case and track the smell and check to see any visible sign of stuff going in flames. It is likely PSU but could also be a lot of other things like naked wires shorting out.
21,795 (3.41/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 128GB (4x 32GB) G.Skill Flare X5 @ DDR5-4000 (Running 1:1:1 to FCLK)
Case Thermaltake Core X31
Software Windows 11 Enterprise
12,062 (2.57/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
Anytime I see someone list a PSU without a brand, I'm kinda scared.
Any idea what it is?
Agreed. We need the make and model of the PSU. 525W sounds suspicious to me. Sounds like you cheaped out on the most important component in the whole build.
peche
Thermaltake fanboy
6,709 (1.78/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
i really doubt about that psu ... im pretty sure that isn't cooler master v525 or antec earth watts 525...
  • Like
Reactions: xvi
31 (0.01/day)
It's a coolermaster EX2 525
2,344 (0.44/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
Swap out PSU for another of larger size with friend, about 650w. If all is good buy another PSU.
31 (0.01/day)
So if it's the PSU the problem : i just bought an apple keyboard and just then my computer fried .. Could a keyboard cause an overvoltage?
2,344 (0.44/day)
Keyboard Dell
31 (0.01/day)
What psu would you guys recomend me one that would do the job and that is not to expensive ? Wallet's empty due to the holidays :(
peche
Thermaltake fanboy
6,709 (1.78/day)
System Name Athenna
2,344 (0.44/day)
Keyboard Dell
Where do you live, country?
2,344 (0.44/day)
Keyboard Dell
peche
Thermaltake fanboy
6,709 (1.78/day)
System Name Athenna
1st get a psu to try your system to see if everything works well...
then fill all your specs so we would know what to advise lad...
2,344 (0.44/day)
Keyboard Dell
Great recommendations although 140 is a lot for my budget , should i go for something around 80$ or am i dreaming ...
$120 after rebate either version.
At $80 I'm afraid you won't get quality or longevity.
Newegg.ca does not have the same variety as USA. I looked at other units at Bronze level and I don't feel comfortable with recommending anything less.
  • Like
Reactions: xvi
Kursah
Super Moderator
14,735 (2.20/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
$40 PSU http://www.amazon.com/dp/B00H33SFJU/?tag=tec06d-20
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438016
EVGA 500W, it's not the best, but I've used dozens of them for office PC's, low-end gaming PC's, and not a single one has failed yet. I stopped using Antec because of failures.
EVGA makes nicer PSU's as well, but with that system this 500W unit should suffice if money is tight now. It'll do a fine job, keeps cool, I've pushed an i7/16gb ddr3/3XHDD/GTX770 with OC's on that PSU and it didn't even budge...voltages stayed well within limits, and it never even got hot...barely warm in all honesty.
It only has a 3yr warranty, but for a budget PSU, I'd look nowhere else than this in my experience, not saying I've tried them all. I also have had good luck with a 1st gen Corsair CX430, but I have been told the newer ones aren't as reliable and solid...mine is pushing 5 years old and hasn't faltered yet (see specs in sig).
There are some decent budget PSU's, but there's so many PSU's in the budget range it is tough to find the good ones sometimes, but this PSU I have no problem standing behind based on experience. :toast:
Frick
Fishfaced Nincompoop
19,852 (2.86/day)
north
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
That PSU has a three year warranty.
Mussels
Freshwater Moderator
58,412 (7.85/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
other thread deleted, stick with this one.
One thread per problem is enough.
21,795 (3.41/day)
Olympia, WA
System Name Pioneer
I would try a warranty return of the existing PSU. Why not?
EDIT: Nvm, a quick google reveals the PSU may not be worth trying to RMA. Sounds like a crap unit in general.
I'd go with the EVGA above as well.
12,333 (2.24/day)
Oregon
Keyboard EVGA / Logitech K400
If its the PSU you should be able to smell it and tell. Pull the PSU out and take a smell of it
4,666 (0.70/day)
Washington, US
System Name Rainbow
Processor Intel Core i7 8700k
Motherboard MSI MPG Z390M GAMING EDGE AC
Cooling Corsair H115i, 2x Noctua NF-A14 industrialPPC-3000 PWM
Memory G. Skill TridentZ RGB 4x8GB (F4-3600C16Q-32GTZR)
Video Card(s) ZOTAC GeForce RTX 3090 Trinity
Storage 2x Samsung 950 Pro 256GB | 2xHGST Deskstar 4TB 7.2K
Display(s) Samsung C27HG70
Case Xigmatek Aquila
Power Supply Seasonic 760W SS-760XP
Mouse Razer Deathadder 2013
Keyboard Corsair Vengeance K95
Benchmark Scores 4 trillion points in GmailMark, over 144 FPS 2K Facebook Scrolling (Extreme Quality preset)
+1
Take a whiff of one of the vents. You'll know for sure when you've found it.
Edit: Might want to check the motherboard on the 20/24-pin ATX and 12v EPS connectors for scorch marks too.
rtwjunkie
PC Gaming Enthusiast
14,030 (2.32/day)
Louisiana
Processor Core i9-9900k
True. It could easily be a misplugged connector. I once had smoke and flames because a card reader which used a floppy plug for power was plugged in on only 2 prongs instead of all. The result of me trying to plug it in by feel. (walks away sheepishly).
