Cant read/flash bios of Asus RX 6700 TUF with amdvbflash
13 (0.00/day)
I am trying to fix my GPU which have stability problems (Showing artifacts) at low voltage, but I cant change or update the bios, I keep getting errors and GPUZ
If I read the bios using techpowerup GPUZ I get this bios https://www.techpowerup.com/vgabios/258315/258315 but I presume I should expect https://www.techpowerup.com/vgabios/231517/asus-rx6700xt-11264-210122
Does that mean my card have been flashed manually before (I bought it used)?
amdvbflash errros after running AMDVBFlashDriverInstaller with install:
GPU-Z
14,431 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Why are you trying to flash the GPU, both the linked Vbios's are the same, flashing will not make a difference.
43,998 (6.81/day)
Return the card for money back
13 (0.00/day)
I have artifacts when my computer idles/simple games, but nothing when I play AAA games, so I want to raise the minimum vcore, so I would like to modify the bios, I tried using MorePowerTool to apply it, but could not get that to work either
The problem only started recently, if I could I would have.
43,998 (6.81/day)
Replace thermalpads and paste then.
You haven't flashed your card yet correct?
13 (0.00/day)
Already tried repasting, didn't change the thermal pads though! But I cant see how bad thermal pads would make this error though, why does it work when the card is hard pressed and warm, but not when cold, I would expect it to be opposite to be the case then :/
43,998 (6.81/day)
Find a pcb repair station like northridgefix then
