Regeneration
NGOHQ.COM
- Oct 26, 2005
- 3,134 (0.45/day)
The following eBay merchant sells cheap Samsung DDR3 1600MHz 4GB memory modules:
https://www.ebay.com/itm/Lot-RAM-1G...AM-DIMM-Intel-240Pin-for-Samsung/132426515500
Despite no heatsink and incomplete SPD, those are genuine Samsung modules, capable of 2000MHz+ CR1 with manual timing. Tested on M378B5273DH0-CH9.
Use the following timings as reference:
@ 1200 MHz 9-11-11-31 (CL-RCD-RP-RAS) / 42-193-3-7-16-10-10-28-7 (RC-RFC-CR-RRD-WR-WTR-RTP-FAW-WCL) *1.65v*
@ 1000 MHz 9-11-11-31 (CL-RCD-RP-RAS) / 42-193-2-6-16-9-9-28-7 (RC-RFC-CR-RRD-WR-WTR-RTP-FAW-WCL) *1.55v*
@ 800 MHz 11-11-11-28 (CL-RCD-RP-RAS) / 39-128-5-12-6-6-24 (RC-RFC-RRD-WR-WTR-RTP-FAW)
@ 761 MHz 10-10-10-27 (CL-RCD-RP-RAS) / 37-122-5-12-6-6-23 (RC-RFC-RRD-WR-WTR-RTP-FAW)
@ 685 MHz 9-9-9-24 (CL-RCD-RP-RAS) / 33-110-5-11-6-6-21 (RC-RFC-RRD-WR-WTR-RTP-FAW)
@ 609 MHz 8-8-8-22 (CL-RCD-RP-RAS) / 30-98-4-10-5-5-19 (RC-RFC-RRD-WR-WTR-RTP-FAW)
@ 533 MHz 7-7-7-19 (CL-RCD-RP-RAS) / 26-86-4-8-4-4-16 (RC-RFC-RRD-WR-WTR-RTP-FAW)
@ 457 MHz 6-6-6-16 (CL-RCD-RP-RAS) / 22-74-3-7-4-4-14 (RC-RFC-RRD-WR-WTR-RTP-FAW)
Some voltage boost may be required. Test stability with MemTest64.
